Everything posted by Darius43
That’s Tamiya masking tape for you - always works well.. Cheers Darius
Lamp irons and cab handrails fitted. Also fitted a fan beneath the fan grille. Cheers Darius
Primary painting completed. Cheers Darius
The Lima chassis had been somewhat hacked about but needed further modification to enable it to fit properly. The main issue is the chassis being 6mm too long for the MTK body, which necessitated removing a 6mm slice from the centre and rejoining the subsequent chassis halves. Plasticard stiffeners were also glued in place. The body now fits a lot better than before. Cheers Darius
First time reading this thread. Just a few days ago I repainted one of these coaches into UTA livery. Cheers Darius
Roof fan aperture drilled out. I used an A1 Models etched Class 37 grille - after all it’s an EE locomotive. I also added A1 Models etched horn grilles to the nose. Cheers Darius
Actually this is fairly straightforward. The hardest one was the Class 55 - straightening up the original banana-shaped body was certainly challenging. Cheers Darius
Fettling, filling and sanding. The original paint finish must have been brush applied judging by the finish. I filled the gaps and sanded them along with the paintwork generally. I added strips of thin plasticard at cantrail level to provide a neat roof to bodyside interface. One coat of primer later… Cheers Darius
Obtained from eBay and in need of some tlc. The body is mounted on a Lima chassis that has been modified to kind of fit… The chassis is longer than the body - one of them must be wrong… In any event the chassis will need to be shortened to fit so that the fronts of the bogies don’t stick out past the nose. Some of the roof parts are sitting too high. These parts were held in place by single dabs of solder, which were carefully ground away using a Dremel enabling them to be easily removed from the body. Sanding and fettling followed to improve their fit. Cheers Darius
MTK locomotive roster. Classes 40 and 44 to follow… Cheers Darius
3rd Corridor coach completed Cheers Darius
All 3rd corridor interior cut and shut from spare interiors. Cheers Darius
MTK Corridor Third on the bench. Cheers Darius
Hi Patrick, I use HMRS pressfix lining decals. You cut out and peel the lining away from the backing sheet and place it sticky side down where you need it. After that you apply water with a brush to the tissue paper covering and peel it off leaving the lining in place with no carrier film. It’s a lot easier and much less stressful than using waterslide decal lining. You can make sure the lining is straight and in the right place before applying the water. I used pressfix lining for this Ratio LMS coach. Cheers Darius
MTK LMS corridor brake coach kit built as a UTA (ex NCC) coach. Repainted Dapol LMS suburban coach. Plus an MPD… Cheers Darius
- 7 replies
- 16
Lining decals and light weathering to finish. Repainted and finished a Dapol Suburban coach at the same time. Cheers Darius
Interior made from cut and shut spare corridor coach seating. Cheers Darius
Dunglazin. Cheers Darius
Primer on. Cheers Darius
