Everything posted by Glenderg
You're cutting the legs for a baseboard that you don't know what size nor design it is? I've proffered the "Lay track in haste, repent at leisure" but this takes the biscuit Slow down, stop cutting timber, measure the space available, and get out a wee notebook and start sketching a plan for track, baseboards and so on. Then start cutting legs etc. Rich.
Thanks lads, it means a lot, and I did think CIE were odd in the way they went about design - turns out our counterparts across the ditch have a similarly oddball way of doing things, which I find delightful and challenging all at the same time. A piece of rolling stock with 4 different buffer patterns? Yip, seen in the flesh several times. Or another with two different types of brake gear on it? And for a man who has an unhealthy interest in axleboxes, whoa-hoa, it's been a roller coaster so far - roller bearing - hooded and unhooded, grease box, LNER, GNR, sloped, no mind yer standard BR Timken's! Yes the OCD is strong on this adventure, but as Mies Van Der Rohe once said, "God is in the Detail" Rich P.S. the Irish stuff has not been put on any backburner either, we're "all ahead, flank speed" as Garfield might say.
Best laugh I've had in a while!!!
Jaysus, that shot would have been handy about 6 months ago!!! Got it figured out in the end tho. Love that Ballybeg layout too, stonking stuff. R
Can, fire me a pm if still interested. In other news... Colours used. Rock salt method used. Bit of downward action with wire wool before it dried. Onto powders, Mig Ammo are appallingly bad for railway stuff. It's powdered chalk dust, and doesn't stick. Back to AK Interactive. Should have left it at that, but was determined to get those powders to behave. It's sitting on makeshift 21mm track. I'm "idir eatherthu" about the finish, and I've probably given Wrenneire a hernia seeing a collectible in this way!! R.
36! I fondly remember 121's hauling them from the junction to Limerick and always it being around 24. Every days a school day!
Great to see you at Blackrock and have the craic, no less seeing your work back here with a bang. I think a lot of folk think you press a button behind yer ear and not only does an bottomless pit of time open up to do the work, but the experience and skill required to unf*ck some of these models (thinking shiteways resin) is slotted into a port on an SD card behind the other ear and off you robotically go. I think it explains why there are so few in this community doing this kind of "charity" work... R.
Same, love the bigger roundel and the font style (which isn't a font download either - every letter had to be drawn ) would loved the justification for 2 more in a pack, but shur.... R
You'll be needing a new smoke box door as JB says, but looks good.
Spot on, Andrew. Makes discharging contents easier as pipework closer together, less shunting. R.
There's a list as long as yourself to be done when making the GSV's, or any of the variants. My reply was for the benefit of the community, not just for this thread. I believe the photo below is from RedRich, and should be of use. R.
It's a bit myopic to replace the bogies and gangways, and yet leave the windows, battery boxes, v-irons, underframe gear all untouched, with big old chunky mullions on the windows in particular? There's some lovely step details too underneath the central door. Just if you're going to go to the time, sweat and expense, might be worth pushing the boat out, no? R.
@Garfieldsound, nah really sound, thanks for the reminder.
Very nice! I meant to sodding well buy one, pure distracted...
I've tried it and it doesn't work so good as it dries to a grey colour, like, uhm, cement The run off stuff on the prototypical wagons was that light foamy stuff, so if you were to mix it with joint filler or plaster 50/50, you're closer to the right finish. Mixed results with it, would prefer several coats of paint using a rock salt method, then powders to finish. R.
Kinda weird all right, keep seeing parts that could have been improved and then I start getting annoyed, the load itself in particular, but shur learning curve and all that. I'm going to do something special with my own rake; custom loads, etched brake levers and the guide, maybe even swap out a hopper for a curved version. Rp-25/88 wheelsets too, for a more finescale look. Bugger all else can really be done... Dcc operating hopper doors?!?! When the Chinese (great bunch of lads) cut the steel, for additional fidelity, and shillings, they can "Polish the tool".. snigger.. when the plastic is injected, it's near flat as glass and has an eggshell finish. As a wagon, trying to be impartial, it does take powders and washes exceptionally well as a model, and definitely benefits from a bit of distressing,especially to take that shine off. I've a pair of scrathbuilt E-classes on the bench too, both types, and hopefully a full build "splash" to go with, give yiz all a break from the IRM craic. R. Edit - I may have lied - there's the full range of MIG JIMENEZ weathering powders arriving at HQ and some models.... .. I may get distracted.
Just a quick snap of a weathered set of ballasts, chap wants DIV 42, despite being on a different running number. First project of the rebuilt and relocated "workbench"! Weathering powders and hand applied highlights only. R.
A model of a model? Hmm, a weird one all right. The Schrodinger's Cat paradox of the railway modeller? I'd say it's a first....
What foliage? That's the loco side panel in green - proper green, not jhb green. The texture appears to look like foliage, but that was the advanced paint, with weathering, that bullied used on these turf burning experimental locos... @Warbonnethave I said too much?
The Wanderer himself might be able to assist with seat count etc. I can only comment on the Cork-Dub services. All sets were formed of loco - genny - first class (a) - buffet - (b) Standard Open (c,d,e,f,g) I think that CityGold was for the express services early in the morning and in the evening for business customers, and the rest of the days service was just a "First Class" instead, a little red 1 on a gold coin logo on the doors. Executive coaches were for hire, motivational speaking, company outings, that kind of fare. I never saw one in service, and photos of them running on the network are rare as hen's teeth. R
South Dublin MRC Exhibition Oct 28th - 30th Blackrock College
Glenderg replied to Warbonnet's topic in What's On?
But what's the skinny on the catering facilities for the troops? Egg sangwidge and a flask of potato and onion soup in the rucksack, give it that "Warley" hummm....? -
Funny thing is that those two photos were heavily referenced throughout the process, along with another 217 more....Every photo on this site is valuable for this craic, and we don't forget those that post them either. You'll note that the two weld seams between the main cylinder and the "boobs" at either end have weathered heavily and are most prominent on wagons, whilst the quartering weld seams appear to disappear. Manufacturing means that the bubble is composed of several parts and there's a natural joint where that weathering takes place. Happy accident I reckon. Looking forward to get my hands on a set shortly, along with the full range of MIG weathering powders, to see if I can distress one of these ladies to match a scaled reality. I get the feeling I might be the only one brave enough (initially) to chuck crap at pristine models, but it's all for a good cause R
yeah, 5'7" ish isn't really enough to do omagh justice in 4mm. Can you post an ordance survey map or similar that can be scaled from, see how big it really is? Anyway, question I asked is do you want to play trains or shunt wagons on a scale diorama? R.
This amazing photo shows you, from 2012, what an "Irish Cement" branded wagon looks like....She was the last to be held at the sidings in Limerick, after all her sisters had been scrapped months previous, before she mysteriously "disappeared"... We've taken the dirt off her, btw
