Everything posted by Mayner
I finally got around to publishing a Facebook page https://www.facebook.com/jmdesignmodelrailways.
Tempting but it would be safest to check that the diameter of the Lima OO gauge wheels and the HO scale wheels and axle lengths match before buying. A 33" American freight car wheel works out at approx. 9.6mm, the typical CIE 3' coach wheel at 12mm in OO which would lead to problems in matching coupling and ride heights. Hornby or Bachmann wheels may be too large in diameter as it looks like Lima OO stock was designed around an 11mm diameter wheel. Markits produce replacement wheels for Lima http://www.markits.com/MARKITS_Price_Guide_2013_09.pdf MRJ11/b-3Rmfd 11mm T/Disc 24.5mm Axle ('LIMA') £2.00 MRJ12Do/b3Rmfd 12mm T/Disc (LIMA) 24.5mm Axle £2.00 These may be available through DC kits or other UK suppliers
Merry Christmas to all and a Happy New Year. Santa arrived early signalling a possible change in direction with a vintage Unimat & a kit for a large scale T&D inspection railcar.
Going off thread a little some of the older companies had nicknames the DSER was known as the Slow & Easy & the unfortunate SLNCR The Sow Lazy and Never Clean. Wonder if there were nicknames for the liveries. The Waterford and Tramore seems to have remained in an 1850s time-warp with ancient but highly polished locos and colour coded 1st & 3rd Class coaches. In the 19th Century wit the exception of the WLWR most companies seem to have some variety lined green locos and "lake" or dark red coaches. In the early 1900s loco lining became more simplified, the Midland tried Royal Blue locos with blue and white coaches, green gave way to lined black on the Donegal, DSER, GNR (I), GSWR, Midland, SLNCR. Grey replaced black on the GSWR during WW1 and became the standard for GSR & CIE steam locos and now IE 071s. Most companies stuck to some form of red for coaches. The DNGR stagnated & stuck with LNWR "Plumb & Custard" for its coaches until closure, the NCC followed on where the WLWR left off following Midland (UK) and LMS practice in terms of locos stock and livery under LMS & BTC management until subsumed into the UTA. For a time Donegal even painted coaches its coaches black before adapting the highly colourful "Geranium Red for its loco with red and cream (Blood & Custard) for railcars and coaches in the 1930s. The GNR followed suit with colourful liveries in the 1930&40s with its "Sky Blue"& Red for its top link & U Class locos, with "Oxford Blue" & cream for its buses and railcars. Unlike the Donegal the Swilly saw its long term future as a road operator and was cutting back on rail operations by the mid 1930s. Despite this steam locos seem to have been well maintained and nicely turned out in lined green up to abandonment of the remaining rail services in 1953, in later years the remaining increasingly shabby coaches were painted grey like the wagon stock. The Swilly developed a stylised LSR diamond logo in the 1930s that was applied to some of the 4-6-0T, 4-6-2T & 4-8-4T locos and even some of the coaches rather than the L&LSR or L&BER initials.
Yes 221Sa was bought in a swap meet in the Hotel Victor near Sallynoggin and a great example of what can be achieved with an indifferent model and a lot of hard work. Although out of my modelling era I could not bring myself to dropping the Sa suffix or re-painting the loco as a B201. While the re-motored C Class were mainly known for their work on the Dublin suburban, they regularly worked bagged and bulk cement trains between Platin and Dublin, they also regularly worked Dublin-Limerick through passenger services via Nenagh and the Direct Curve, Cement and goods trains in the Limerick area, the Loughrea mixed and even a brief spell in express passenger service between Dublin-Cork. A radical change from their C Class days pottering around in a cloud of smoke on branch line trains and pilot duty.
Ben That's one hell of an interesting photo 984 is a Class A tank wagon probably used to carry petrol. A hose is being used to syphon out the contents into the road tankers by the signal cabin. Bitumen tank wagons have an insulated tank barrel hidden by sheet metal cladding, with flat or slightly coned ends like the wagons in the Paul Burnett photos http://paulbartlett.zenfolio.com/essobitumenvb/h3c469d01#h3c469d01. The ESSO tank wagons were basically the first modern design of tank car built in the 1950s made redundant with the introduction of 35T & 100T air braked tank cars in the mid 1960s. CIE introduced its own design of saddle mounted bitumen tank wagon for County Council traffic based on the then standard 10' wb unfitted underframe in the late 50 early 60s. Earlier bitumen tank wagons were built by Charles Roberts and other companies in the UK based on traditional tank wagon design with cradle mounted tanks. The tank wagons imported from the UK in the late 60s were owned by ESSO and were built by Charles Roberts in the late 50s. The most noticeable visual differences from the original was the fitting of spring dampers and later the fitting of a reinforcing plate between the tank barrel and solebars. CIE may have had to widen the underframe by up to 6" to run on the Irish gauge, the Airfix/Dapol underframe works fine for OO but needs widening by 2mm (6") for 21mm gauge
http://catalogue.nli.ie/Record/vtls000304941 Are these the ones John? The wagon on the left looks suspiciously like one of these http://paulbartlett.zenfolio.com/essobitumenrebuilt/h1acfab4e#h1acfab4e. The basic design appears to be the same as the Class A tank wagons imported from the UK lagged to carry hot bitumen. The angular shape of the tank barrel is a give away for this type of wagon. Its possible that the lagging was removed and the wagon(s) converted to carry fuel oil or diesel once bitumen traffic was containerised. Irish Bitumen had a few internal user tank wagons up to the end of rail operation in its yard near the end of the Alexandra Road tramway. The tank wagons were on the rail but did not seem to leave the yard. Bitumen was usually transported in ISO tank containers mounted on 4w container flats. Bitumen traffic was fairly light with one or two wagons attached to the Sligo Oil train and CIE Liner Trains.
Is that mixed standard and broad gauge track? I managed to fit in some gricing during holidays in NSW & Tasmania but never managed to get outside of Melborne Airport
Servicing Locomotives: 141 181 and Woolwich
Mayner replied to DiveController's question in Questions & Answers
Just like the prototype different makers locos have their own quirks some makes including Bachmann are more high maintenance than those of Japanese or German manufacture. I have two relatively new Bachmann large scale locos stopped for spare parts while much older LGB locos continue to run reliably. Plastic gears in the final drives on Bachmann large scale locos tend to split from being forced on to splined axles, power pick up design and quality of wiring has not kept up with other manufacturers notably Kato. -
You it the nail on the head Magpie stated about 20 years ago along with a pair of GSR standard opens while living in the Ochiel foothills village of Alva. Interestingly I based the model on a photo and some known dimensions which somehow or other matched up with the late Padraig O'Cuimin's drawing. Going back to tank wagons it looks like ESSO/CIE had some relatively modern bitumen tank wagons before the traffic was containerised. At the time I was mainly interested in the old Mex Class A tank wagon, but the wagon on the left looks like a modern bitumen tank wagon. Does anyone have a clear photo of an ESSO bitumen tank car?
221Sa builder unknown from a Q Kits B201 I bought this from the "Belfast Caboose" at a Hotel Victor swapmeet about 15 years ago, really captured the look of these loco in their last years, passed on an MIR 071 detailed and finished to a similar standard. Chassis from a shortened Athearn F7 one bolster moved back to shorten wheelbase, flywheels removed. I still have to finish re-wiring from a decoder. Walthers/Lifelike Proto 1000 F7 chassis might be suitable.
Personally I would have reservations about using Tenshodo SPUD motor bogies in a mixed traffic loco like a B or C Class. I have tried the bogies in a railcar and a number of small diesels and ended up replacing the units with Black Beetles or my own drives. The Tenshodo bogie is designed as an underfloor unit for railcars and trams, but will only runs reliably at high speed (small fast running open framed motor & (15:1) gearing) the bogies are difficult to control at low speed and while accelerating have little low speed torque. The standard Backbeetle is marginally better with a high quality Mashima motor and metal gearing (still 15:1), the 25:1 option would give much better running across a wider speed range. The other issue with a two power bogie drive is whether to treat each bogie as an independent unit and risk stalling due to poor power pick up or to wire the bogies in series or parallel and risk surging (jerky running) due to the back EMF from the motors when running down hill with a heavy train. I found this to be a serious problem with locos with two motor drive in G Scale whether the motors are wired in series or parallel. This potentially could results in de-railments and accidental uncoupling due to coupler snatching in OO & N. While I would prefer a centre motor with flywheel drive to both bogies, the Hornby Railroad Deltic is probably the simplest and most cost effective compromise for a batch-built A Class.
It looks like Sligo Goods possibly 1980s. CIE introduced tractor and trailers in the 1970s to replace horse drawn trolleys in the for urban deliveries in major cities and towns.
- 14 replies
- fendt
- dublin port
(and 1 more)
Tagged with:
Worsley Works produce a set of scratch-builder parts for two types of laminate coach the 64 seat Standard Open (one lav) and the main line Brake Standard Open. I built a couple several years ago http://www.worsleyworks.co.uk/4mm/4mm_Irish_Standard_Gauge.htm. Although quite basic the parts build into quite nice coaches. The main challenge is in forming the roof. I widened a Comet roof extrusion, while, Popeye scratch built a roof in plasticard for his Park Royal.
Dave Did you ever come across the all whitemetal version of the A Class? I built one from a kit suppled by MIR about 20 years ago a very trying experience. The roof & bogie sidefame castings very similar or the same as your loco. The end casting were not quite symmetrical giving the impression the loco was trying to wink.
The ESSO Teo tank wagons appear to have been imported from the UK in the late 60s most were Class B which had a longer tank barrel than the Dapol model though a few Type B appear to have been imported. The fillet between the tank and chassis was a feature of most CIE tank wagons built/introduced in the 1970s, eventually applied to the ESSO tank cars. Its fairly simple to convert the Dapol kit to a Type A by splicing sections from another kit on to each end of the barrel and sanding smooth. Its probably better to look out for un-built Airfix kits of these wagons on e-bay than attempt to build the current Dapol version. Its difficult to build a chassis that runs well as the solebars of the Dapol version tend to warp and twist, combination of being wrapped in a bag and the soapy nature of the plastic.
Great to see the amount of carriagebuilding this thread is bringing out of the woodwork. Probably going a bit off topic its important to remember that in the 50 & 60s uniform rakes of coaches were rare, particularly with loco hauled trains CIE regularly ran mixed modern and older coaches in the one train. Pre & post amalgamation coaching stock built in the 1920s relatively modern but dated in appearance was still in top-link service in the 1950s The green Models/Bachmann coaches would make a reasonable rake of these vehicles. The new coaches probably displaced some of the older bogie coaches from main line service, in turn to replace (but not completely) 6 wheelers on branch and suburban duties. Some of the classics include a new Composite and a GSWR 6w 3rd brake at Loughrea and a steam hauled Thurles-Clonmel train with an ancient looking bogie coach sandwitched between a MGWR 6 w caboose Brake 3rd and a silver heating van. Possiby a Waterford-Limerick train with two of the newer coaches, a GSWR coach and a string of vans. What looks line a Kingsbridge-Tralee express leaving Mallow, modern CIE coach possibly composite or 1st, Pullman Dining car and a rake of early GSR/late GSWR corridor coaches. I could not resist this one powerful Coey 4-4-0 with a tin van, GSWR bogie coach and MGWR brake van probably Thurles-Clonmel branch train. Some of the Clonmel trains connected with Dublin-Limerick (via Nenagh) trains at Ballybrophy with a featherweight load and a high speed run down the main line to Thurles.
As far as I recall the Ammonia tank wagon chassis were on lease the tank barrels owned by IFI (ICI). Like the ESSO tank wagons the Ammonia tank wagons were scrapped converting a small batch of low-capacity wagons to run in Europe or the UK would have been uneconomic. The obsolete nature and high average age was probably the most noticeable nature of the IE wagon fleet, the cement bubbles and tank wagons lasting the best part of 50 years in service, in contrast the GSR inherited a more modern wagon fleet from the pre-amalgamation companies, the CIE built H vans barely lasted 25 years.
Unlike BR CIE went through 4 distinct design stages with its coaches up to the arrival of the Cravens in 1963. After building the Park Royals & Laminates CIE reverted to traditional wooden framed construction for the final batch of Inchacore designed coaches Bredin MK3? SO 1497-1503 & FO 1145-1146. These coaches had the squarer profile of the MK2 Bredin SO 1356-1371 built in 1953.rather than the tear drop profile of the laminates. Generally CIE SO had 2+2 seating for 64 passengers arranged in 8 seating bays & one toilet , the main line Park Royals & 1429-1443 Laminates originally had 3+2 seating for 70 passengers in 7 seating bays and two toilets. There were basically four types of laminate coach 70 seater SO 1429-1443, 64 seater SO 1449-1496, 40 Seater BSO 1909-1913, non-lavatory (suburban) SO 2162-2171. The Laminate suburbans were converted into BSO 1914-1923 in 1970.
Nice to see photos of the E401s used to look out for them shuttling around Heuston from the upper deck of the 23 Bus as a teenager on the weekly Saturday morning trip in to town to check out Southern Sothern Model Railways, Terry's Toy Shop in Georges or Henry Street, a record in Dolphin Discs and more trains in Monck Place no similar delights n the way home on the 22 or 50. Introduced in silver the E401s were basically Southern locos working on ex-GSWR lines in the Dublin area, Cork & Tralee. There I a photo of a silver on somewhere shunting Fenit Pier, one was also tried on the Courtmacsharry line that twig off the Clonakilty branch of the West Cork. In addition to shunting and banking E401s were used to work the heavy Heuston-North Wall transfer freights. These trains required banking in each direction to the summit at Cabra. Loads were reduced and B101s took over after a number of run-aways when an E Class did not have enough brake power to control a loose coupled train on the grade from Cabra to Islandbridge Junction. In later years some of the E401s lost the exhaust silencer housing on top of the bonnet, the build up of oil in the silencer tended to catch fire when the loco was worked hard.
Generator cars for irish coaching stock - specifically HLV
Mayner replied to Junctionmad's question in Questions & Answers
3223 is a great example of CIEs make do and mend approach to running the railway in the 70s ad DCDR ingenuity. Originally built as a main line composite she was rebuilt into a 2562-2591 series luggage brake with a central guards compartment and two large luggage compartments for parcel and mail trains in the early 1970s. Converted into a Brake Generator Steam Van and re-numbered 3223 around 1980, she appears o have regained her passenger accommodation at Downpatrick and converted to a Brake Second Generator Steam Push-Pull Driving Van -
MGWR Meat Van The hopefully final test etch arrived today so should be able to release the kit in February I hope to release the container flats mid-2015 once I have sorted the masters for the springs, buffers & container cuplocks.
Does anybody remember the model shop in D'Olier Street 1970s?
Mayner replied to Noel's topic in General Chat
Mark took over management of the Southern Model Railway business in the Grafton Arcade some time in the late 70s. The move to Dolier Street and change from a specialist model railway to a hobby shop probably saved the business. The Grafton Arcade shop always seemed to be quite more a place for regulars to meet than a thriving business. The change was quite abrupt existing magazine orders were cancelled without notice one day it was Eddie Elliott and business as usual next day it was Mark. The move to Dolier Street took place before 1980, I was building an N gauge layout at the time Peco points were scarce and I managed to pick up enough to complete the layout during a visit to Dolier Street. -
Dart Castings have added some Irish items to the MJT range of detail castings website. http://www.dartcastings.co.uk/mjt.php#WagonComponents-Axleboxes & Springs. The castings were commissioned for the forthcoming JM Design MGWR Horse Box and Meat Van due for release in February 15. The springs and axlebox may be suitable for other companies rolling stock.
