Brendan8056
Everything posted by Brendan8056
John, That is again superb, the loco weathering and great camera angles make for an Oscar winning video. On Kadees, do not use the under the track magnets unless all rolling stock is fitted with non magnetic (eg, not steel) axles. I say from experience on an HO scale layout I built. I had one under track magnet and every time I tried to uncouple there the wagons would literally bounce back to where the magnet was. I replaced it with a through the track example, no more problems after that. Putting them in place with blue tack is a clever idea.
Irish Railway Models A Class Re-wheeled to 21mm
Brendan8056 replied to JohnMcGahern's topic in Irish Models
John, I have a few posts about trackwork, here is one relating to some points I built last year, I hope that is helpful. https://irishrailwaymodeller.com/topic/8752-freelance-mixed-gauge-handbuilt-trackwork/?do=findComment&comment=138410 -
Das Clay for surface areas e.g. depots and roads
Brendan8056 replied to dave182's question in Questions & Answers
I used Das on a small (A3 surface area) tram layout for a French Railway Society competition. I did small areas at a time and impressed the cobble effect while the Das was damp, blending sections in using nothing more than a finger and some water. 3 years later and there is no shrinkage that I can see. I used polyfilla many years ago and that was difficult to get a decent finish with. -
John, Your pointwork is so realistic, I have done plain track with C&L and Peco parts but still stick to copperclad for points, so they lack the detail of yours. Here is another picture of the gauge change to 21mm. I am doing an article for "New Irish Lines", those who have yet to subscribe should consider doing so, as it is an inspiring read for Irish modellers of all gauges and scales. -
John, That looks superb as does your trackwork. Phil, I have re-gauged an A using the original wheelsets and axles. It really was easy and the axle ends still rotate. The hardest bit was carefully taking out the wheelsets and re fitting the bogie sides afterwards. Also if fitted with the speedo cable (top left in below picture) make sure that wheelset goes back in the correct place in the bogie, as it has the rotating hub on one end only. -
You may want to see if local hardware shops stock Humbrol, or Revell tins of paint, or can get them for you. I am lucky as my nearest one stocks a selection of Revell tinlets and Richardsons, up the road in Feltham, stock the full range of Humbrol paints, as they have a model department as well as the main hardware/ironmongers.
Brendan8056 replied to jhb171achill's topic in Irish Model Layouts
Well done on purchasing the materials to become a fully fledged Irish Gauge Modeller. For the track I make I use just ordinary tin/lead solder, on a roll. A roll lasts years and I use it for wiring and track work. Track I made 30 years ago has no problems apart from an occasional dry joint or 3. -
Mayner is probably correct about the Murphy's bogies (on both the Cravens and AC stock). Using the brass bogie etch and existing centre casting to secure bogie to coach leave too big a gap. Replica Railways do some very nice plastic B4 and B5 bogie kits, and also sell the sideframes seperately, for a bargain price of 4 for £1. You could probably make up your own plasticard bolsters to go with these. The etched bogies have worked well on Lima mk1 steam generator conversions and should also work on mk2 or 3 coaches by Lima. -
I too did some etches many years back, originally for use with Lima sideframes. I converted a Murphys Cravens, but tried to keep the close couple mechanism, which meant I used smaller wheels to keep the ride height correct whilst resung the bolster. I would not use the same method again. The bogie is on a bit of 21mm gauge track. The concrete sleepers are C&L with Peco code 75 FB track and pandrol fittings. -
I have a variety of track gauges, including some of the washer type, some comercial ones, usually a single run of production only, and a friend with a lathe made me some brass roller gauges. The track gauge is 21mm, nothing more, nothing less. Build the stock to run on the track, not the track adapted to the stock. My wheel back to backs are not always spot on, as long as it runs I do not worry about a bit of variation. (P4 modellers look away at this point!). I am sure I read somewhere that britishfinescale was branching out to 4mm scale?
Robert, I am the author of the New Irish Lines article and also the re-gauging IRM wagons pics on this site. Do not confuse yourself about P4/EM/20.8mm, go for the easy option, the so called finescale 21mm gauge. All current RTR diesels can be re-gauged using their existing wheels, though needing new axles. I have just done a Murphy's 121, and an article will appear in New Irish Lines about that as well. I use templot for point plans and use track gauges for 21mm gauge, no problems. Make up a bit of plain track, re-gauge a diesel and some wagons, run them up and down, and you will never look back on the "narrow gauge". If you really do not like it after that you can just push the wheels back to 16.5mm gauge. Apologies, It is not Robert but Murphaph I should have replied too!
26mm is the common axle 00 gauge, as murrayec points out, there are exceptions. Lima wheels were on 24.5 mm axles, and so are Murphys Models coaches, both Craven and AC types. I assume this is because they are manufactured in factories that make HO scale coaches normally, where 24.5mm is the common axle length.
John-r--I have turned down the Lima pizza cutter wheels on HO scale Italian wagons and railcars. The wheels are made of an easy to turn metal (brass?). Just don't try it with Jouef wheels, they really are rubbish. I use a minidrill and some files (and eye protection of course) to turn the wheels down and make the flange more shallow. DiveController--A pic of the 21mm gauge bogie on the 201 class. I used the existing wheels and gears. for the axles I used spare Romford/Maygib axles with the pin point ends filed down. 2mm steel rod would do the job as well. I recall the gear was pressfit onto the axle and I used a toothpick to apply a bit of superglue to hold it more firmly in place. There is plenty of room between the bogie sides and I moved the dampers out by twisting them slightly as they fouled the wider gauge wheels. The Murphys 141 and 071 classes have similar design bogies and can be regauged this way as well.
After a failed regauging to 21mm gauge of a Lima 201 I was left with a bodyshell. I used a Bachmann class 66 chassis, which is a very good match and runs superb, and is easy to regauge to 21mm. The class 66 was a swap meet buy and I was able to sell the loco body on Ebay. I may at a future date make the lighting work. The pics tell the story.
Springside do nice levers as part of their signalbox interior kit. Dart castings do some good whitemetal castings of ground frames. I have used them in the past, link here to the page. Perhaps you could modify 2 of the 6 lever ground frames? https://www.dartcastings.co.uk/dartcastings.php
Freelance Mixed Gauge - Handbuilt Trackwork
Brendan8056 replied to RichL's topic in Irish Model Layouts
RichL, That looks a really good idea. The bit of track I pictured was part of a test track with a crossover, like you say, a way to test stock and techniques. I take no credit for the track cut and widen technique, that was used by Stephen Rabone , featured in a Railway Modeller article on his then Irish layout. -
RichL, I have taken a pic of the gauges I used for constructing the points. Some are out of production so the moral of the story is buy when you see them. The unknown make ones were purchased from Stephen Rabone, who now models S scale, so don't neglect secondhand sources, even for 21mm gauge. They are: 1. 3 point gauge by Jeremy Suter 2. Roller gauges, left , Jeremy Suter, right, AM Technical services. 3. Wheel back to back gauges, top unknown, bottom, AM Technical 4. Roller gauges with flangeway clearance, Unknown. On the track here is a pic of widened SMP track with gaps filled with car filler. This piece is over 30 years old. If done carefully it looks reasonable, but does not work with the Irish style cess in the middle of the track. Peco Streamline has been improved continuously over the years, the points are now very different. There is a story that Peco planned EM gauge track in the 1950s but the standards then changed to 18.2mm for the gauge and Peco gave up on the idea. Only last year did Peco finally do such track, funded by the EM Gauge Society. I would love to see ready to lay 21mm gauge track but the development costs would be great. Rapido Trains tried to do a new 16.5mm track a few years back but it just did not turn out well and they now say buy Peco. For the plain track I like the Peco Individulay wooden sleepers with Either Peco Pandrol fittings for flatbottom or C&L for bullhead fittings. I have also used real wooden sleepers and the C&L concrete ones, both with good results. Plain track is the same whether it is to P4 or just 00/EM fine standards. Both will look exactly the same and be the same 21mm gauge. A friend has some P87 Danish steam locos and they happily go along Peco code 75 track but the wheels will not go through the pointwork. On a sad note I think the dual gauge bit of the Vivarais did not re-open after the closure of the whole railway a few years back. It was a great ride, especially when an SNCF freight train overtook my train. -
I made a couple of 21mm gauge copperclad points last month. I used templot plans , one was for 21mm and the other for the 20.2mm. For both I used my 21mm gauge track gauges and both are consequently that gauge, with 1mm flangeways. The picture show the plans and the points. I always adjust the point a bit to get the stock to ride smoothly through the point, probably due to poor construction technique on my part. I use a "perspex wagon" with a pair of bogies as a test vehicle, one set has Maygibs, the other Romfords. All my wheels seem to go through with no problem, including a few wagons with P4 wheelsets. the others are as varied as Bachmann, Maygib, Athearn, Romford, Gibson, IRM and others I don't recognise the maker. Go for 21mm track gauge/EM standard wheelsets with the 1mm flangeways and you should have few problems. I am sure you will enjoy the look of Irish trains running on the correct gauge track.- 136 replies
- 12
Whilst I don't know where the picture of C214 was taken it does seem to be missing the correct screw couplings, that looks like a basic 3 link set.
It is a case of great minds think alike. I have just been finishing an article on how I modelled Bog Road, which I aim to send to New Irish Lines. A picture is attached.
Hello, I always keep a set of instructions, I have scanned them for you. Enjoy the kits, they are very good, Brendan MIRtara1.pdf MIRtara2.pdf MIRtara3.pdf MIRtara4.pdf MIRtara5.pdf
The Bachmann ones you mention are probably about 14mm size, whilst the B4/B5 bogies have smaller diameter wheels, nearer to 12 mm. Just to make it even more difficult Murphy's coach bogies that I have use an axle length of 24.5 (which is the standard HO European length) rather than the usual British 00 length of 26mm., so the Bachmann axles will be too long for the bogie. Gibson will do wheels at 24.5 axle length (this was used by Lima in their 00 coaches) so I would suggest you try that manufacturer. Hope that helps, Brendan
I received my Taras today. They are everything I have wanted from an Irish RTR wagon, and more. Not only do the axlebox hubs turn but they are even fitted as per prototype, from the underside of the bogie frame. But even better, using my old bicycle chain puller, I was able to easily convert them to 21mm gauge, using the existing wheelsets. This saves modellers like me money and allows me to buy even more IRM items! The pictures show how easy it is. Ease off the flat plastic plate below the axle hub. Pop the wheel set out, remove the plastic axle hubs. Then remove the insulated wheel and put the axle in a chain puller (or a very strongly built wheel puller) and push it out against the non insulated wheel until a couple of millimetres short of the narrowed bit of the axle. Put the insulated wheel back in place, also a couple of mm short, checking the gauge back to backs. Refit the plastic hubs and pop the wheel set back in place. Adjust if required, otherwise replace the flat plastic plates and there you have it. I have put a converted bogie beside a narrow gauge one to show the difference. Well done IRM team. I hope the A class will be as easy to do, Brendan
- 21 replies
- 10
Noel, I used Kadee number 5's as I had a lot of them in stock, purchased very cheaply at a swap meet. They are very reliable. They are easy to get the right height and length from buffers. I keep my number 18s for my HO stock and Murphys locos and coaches. Incidentally what has been said by others about 21 mm gauge is true. We are not all P4 modellers. I too model to finescale/EM standards and I was very pleased at Ally Paley show the other year when an 141 class I had re-gauged using the existing Murphy wheels with longer axles ran perfectly on Valentia Harbour. You should only use P4 wheels if you have track to P4 standards, otherwise the wheels may not go through points (though should be alright on plain track.) The flange and tyre widths on such wheels are very fine. Brendan
