jhb171achill
  1. Now, I've done a bit of delving. As airfixfan says, there were several types of vans between all three NCC narrow gauge lines (excluding Derry - Strabane). You had the Cushendall line with its unique bogie No. 333, you had the Ballycastle Railway Co., The B C R B R, and the B & L R. Then, on top of that, NCC alterations. Most narrow gauge railways had no two guard's vans EXACTLY alike! On the Ballycastle and remainder of the B & L in the post-1940 period, any guards vans used on passenger trains on the Ballycastle line were bauxite brown. Without knowing exactly what vans were actually in use as such, and which weren't, I can't give numbers. Other vans were grey, like all other goods stock, as were all on the Larne - Ballyclare line. I will post below some illustrations which illustrate several other points too. You mention markings. I have uncovered about half a dozen pictures of your type of model. You'll be pleased to hear that lettering is not something you need worry about, as all photos showing these vans in the brown livery have NO markings, and indeed all but one of any grey ones I've ever seen pictures of, have no markings either, other than the vehicle number on the ducket. So the full correct livery is: body bauxite brown. Roof mid grey. Chassis almost certainly* brown, as ironwork on the body is brown too, as it was grey on grey wagons. Like black chassis, picked-out black ironwork wasn't the norm in Ireland. Couplings black. If you've an interior door open, interior a dark cream colour, as befitted interiors of NCC guard's vans in general. (* I qualify this, as main line bauxite wagons sometimes had black chassis if they were to be used in passenger trains, but NOT otherwise; for example, all of the so-called "brown vans", without exception, always had black chassis in any of their liveries - brown, later green, or maroon). For your info, though, about NCC narrow gauge wagons in general. As I mentioned earlier, there were many subtle differences between the 4ft 8 1/2 LMS and the NCC in liveries. I mentioned that while on British carriages, crests were the norm on most, crests were NOT the norm on most here, and many including narrow gauge had none of the very nice lining. If you look at wagons, while i am not an expert on LMS liveries, I believe that at quite an early stage they made a distinction between fitted wagons (bauxite brown) and everything else (grey); this being carried on into BR days. Here, the GNR started painting fitted wagons brown at some stage in the 1950s, and the UTA seems to have done so. On the NCC, I can establish this. Everything on the ex-Ballymena & Larne section remained all-grey until the end. Passenger services, of course, were long gone by then. On the Ballycastle line, vans as mentioned above; all other stock apparently grey - by this stage, standard LMS wagon grey as used on LMS stock in Britain. Lettering.... the BNCR used evenly spaced letters, quite small. Once the BNCR was eaten by the Midland Railway (of England), they got in large font M R, and under this in smaller letters, N C C. But the BNCR had a unique way of numberings wagons. Most companies either put a small cast plate on the chassis, usually with, but sometimes without, a painted number on the sides and in some companies, ends too. Others just painted numbers on. But the BNCR used cast iron plates, with "B N C R" and the wagon number underneath, attached to the wagon side. Usually, whetever side the plate was on, the lettering was on the other, as per the very rough drawing I'm about to post. Once the MR NCC took over, they continued this tradition, with new wagons having the same plates but with MRNCC instead of BNCR on them. Once the LMS took over the MR, they did the same, and wagon plates had LMSNCC and the number in a more plain block font. Same on the 5'3"; the breakdown train had vehicles with such plates into the 1980s. It would seem that in the mid to late 1940s, the "LMS" ended up being the same size lettering as the "NCC". Again, see illustrations below. The attached pics are not from my own collection, but if anything turns up there I'll post that too. They are all from books.
  2. Your vac one will be bauxite, yes. Thr chassis colour was one of a few matters in which the NCC differed from the “narrow gauge” LMS across the pond, where just about everything had a black chassis. I suspect that the NCC followed the more Irish tradition of the BNCR. As I gradually go through Senior’s pics, many of which I’m posting here by degrees, I’ll see if anything illustrates this. As you say, colour pics just ain’t gonna happen! While a tiny few exist (GNR in particular) in the late 1940s, both Ballycastle and Ballyclare were, of course, gone by 1950. The NCC had two distinct lettering styles, depending on when..... they used a different font from the early 1940s. Which period is your model - pre or post 1940? As an aside, the most obvious ways in which LMS (parent) and NCC liveries differed were lettering on tenders, and on carriages, many more secondary ones here than in Britain had no crests*, no lining or neither. (* particularly in the last 5-10 years)
  3. You’re getting warm..... that general area.
  4. Mark I’m unaware of any wagon stock list but I will delve and if I find out anything I’ll get back to you. No, not all vans had ploughs - the plough van was a different animal and would have only been out with ballast trains.
  5. I’ll do a diagram of the lettering later on and post it here. The chassis would be the same bauxite colour. Any of these that were unfitted were grey all over; fitted grey or bauxite. Beautiful model by the way!
  6. Quiz question; it’s the late 1930s, but where are we?
  7. Now that's a good point, NIR. After the Shore Road motorway was built, with the stuff that the last few "WT" class tank engines hauled down from Magheramorne, there were further movements out of there, using diesels. I have seen a pic of a Hunslet with a string of spoil wagons behind it and while I could be mistaken, I don't think it was a ballast train. I also seem to recall being told of the little Hunslet 0.6.0 shunters hauling them about somewhere, but that probably WAS ballast. Any ideas? As Michael Caine, or Trumpty Dumpty might say, "Not a lot of people know that"!
  8. Wow!! What is that? Is it the RDS show about the turn of the last century?
  9. I wonder is this thing N, H0 or 00? https://muy.spraytanfresno.com/index.php?main_page=product_info&products_id=30283
  10. Actually, you're right - I see that now!
  11. Yes (and the C & L, a century ahead of their time, painted at least a couple of open wagons YELLOW for ballast trains!), the beige colour would have been current in 1900-05. Certainly after 1925, but possible as early as the mid 1910s, they became standard grey with white lettering. It would seem that they had black lettering when beige; I do not know whether the chassis was the same beige, or black. It was usual, as well known, for Irish companies to paint wagon chassis the same as the body colour, but there some exceptions. As for the lettering, I cannot be sure, but it is possible they only had the normal "M G W (number)". Most old photos of most maintenance vehicles I've ever seen tend to have "P W DEPT." rather than "Engineering" - and in a model I'd be more inclined to go for that - or, even, only use "M G W" and a number, pending anything more specific turning up. Sorry that's the best that I can do! I assume a ballast plough would be the same beige, or possibly the brown that some vans were then. It would not be green. I will have a poke about tonight and see if I can find anything else.
  12. Correct - the pic was some time in the mid 30s - after 1940, any "shiny" engines would have been in the unlined black livery too. I would certainly think it's one of the 1924 stock. Hard to make out 100% though. I noticed a white patch on the smokebox door - anyone have any ideas as to what that might be? I don't. That would be a typo - very definitely 2nd!
  13. Fifty years ago to the day, today, NIR operated the last ever steam train in service with a company-owned locomotive in Ireland. I was there to see it. Over thirty years earlier, also on the NCC, Senior spotted a gleaming maroon just-out-of-the-paint shop U2 hurrying itself along. Location unknown, but would appear to be either between Belfast and Whitehead, or more likely Belfast - Ballymena, as I think his earliest spin on the NCC was on the main line. I
  14. I will still state that the most comfortable railcars are the old GNR / CIE AECs, providing we're talking original seats here, of course, and the modern NIR 4K and 3K types. And the worst by far were the MEDs and "Castle (Cattle) Class" or 450s of NIR. Ghastly things, both of 'em. Warb, is that an MIR kit for the 80 class? Very well made.
  15. I am not known for my joy at seeing modern railcars, but I have to say from recent jaunts on the Cobh line over the last half-dozen years, they've grown on me a bit - and I did like the 2700s, strangely enough. The noise a 2600 makes going up the tunnel en route to Mallow is something else - so many suburban railcars don't ever get a chance to properly stretch their legs!
  16. Nothing was scrapped in this way as Eoin says. If ever Fry scrapped anything, it would have been because he dropped it on the floor and it bent while he was building it! And given his levels of skill and care, that's unlikely.
  17. Bianconi, Annaghmore, Cork City, Bessbrook, Giant's Causeway and Lucan were the ones I had in mind. I did not count Belfast (or Dublin, other than Lucan!) And not the LUAS either.... naturally, by Irish standards, all of these are narrow gauge too! I have an idea there was some sort of short-lived thing out in the wilds of Leitrim or Longford or somewhere - I remember reading of such a thing years and years ago. Must look it up.
  18. 3ft gauge. One of the few electric narrow gauge lines. Quiz question: how many narrow-gauge electric lines were there, including tramways? I can think of six.....
  19. We’re up north today. A Giants Causeway tram awaits departure from Portrush station, and a strange vehicle is parked up at the depot nearby. This was a wagon for inspecting overhead wires. These pictures were taken in 1939.
  20. It’s grey now. Last yellow / black / silver one was about 18 months ago.
  21. Ah, that. I thought the comment referred to maybe hooks for holding the ropes of the tarpaulins. I have no idea what the above castings were. As you say, probably too small for grain, and I think in any case it’s almost certain that bulk grain wasn’t carried in vehicles like these.....
  22. Ah, I was imagining you only had a very small space. You'll pack in a full terminus station on that size of board.
  23. Which photo? I think I know what you're looking at but can you confirm....
  24. The A and C class were all cream inside. 121s were very light grey as were any 141s I was ever in. I don't remember what B101s were like inside as I only ever had one footplate ride in one. I have pics of the inside of a C somewhere, but I will have to search. If and when I come across them I will post them. I have a notion that the very oldest ones, the B113 duo, had cream upper and mid brown lower, like the cab of a steam engine, but again I would have to do some considerable delving! The G class were light grey lower, cream upper, as at Downpatrick, as far as I remember. E class - I'm not sure, but the DCDR could help - I think light grey. Again, I've a photo SOMEwhere!
