Everything posted by Noel
Yea potatoe patayto transit transport. Many journo's and researchers seem to only spend 90 seconds on google to research anything instead of speaking with qualified sources. Wiki is taken as gospel truth.
Park royals yehaw!
No the announcement about the Park Royal was well received and a welcome addition, at last some coaches for the silver, black, green and B&T livery A class to haul. The 3D sample looked great.
Honoured to be exhibiting Gort at Wexford Model Railway exhibition over the weekend. Arrived at 6:30, superb organisation at the venue. Unloaded and setup in one hour thanks to help from my glamourous soul mate and the organisers. Excellent venue. Looking forward to the next few days.left the signals in the car. Will put them up tomorrow.
- 329 replies
- 12
Measure twice cut once was the best bit of advice I ever got. Best wishes on what sounds like a fascinating project. Enjoy it and don't rush it.
- 58 replies
- 3
- 1950s to 1990s irish railways
- harcourt street line
- (and 3 more)
Loaded into trailer. Gort ready for her first public outing, ready for trip down to wexford tonight.
How to fix Kadee no 18 couplings on an IRM Cement wagon. Same method applies to the Ballast, Gypsom, and magnesite wagons. Glue No 18 kadee to the underside of the NEM pockets. Gently sand or file the underside of the NEM pockets (ie to get good glue bond later). On one you will need to file away the IRM logo which is in relief to make the surface flat enough to get a super glue bond. Gently file the tongs of the Kadee coupling (ie to rough surface for better bond). Superglue the Tongs of the Kadee coupling to the underside of the NEM pockets and leave for 10-20mins before use to allow bond to cure hard. Ensure the flat inside of the knuckle coupling is level with the external edges of the buffers. Gluing the Kadee's to the underside of the NEM pocket ensures perfect and correct height of the coupling as per kadee height guage and all other IRM wagons. The wagons can then be automatically uncoupled using kadee uncoupling magnets and interoperate with other wagons and stock (eg IRM 40ft, MIR Cement Pallet wagons, MIR Cement Curtain wagons, Bachmann H-Vans, Dapol H-Vans, etc). Another benefit is the wagons are coupled closer together. Be careful handling these gorgeous wagons, they are very fragile as there are so many details parts fitted to the underside.
Goods yard. Supplies ready for loading onto wagons ready for the 18:35 passing pick up goods train to Ennis. There'll be one wagon of cattle loaded here also. Yard crane handy for loading the larger boxes into the corrugated open wagons.
Some CIE era trains on the move. How on earth will I get enough poetic license to run 22k along side these? May need a Tardis.
I must have been lucky with Hattons this past 18 months. No Delay's no glitches, no additional duty nor vat to be paid. Their DDP (ie Delivery Duty Paid) seemed to work like clock work. Because of DDP Hattons is the only UK retailer I still use. Everything else has been direct with German online retailers in the Eurozone so no hasssle.
That country side is so evocative and so like Co Galway the wonderful goods train above from Du”Gort” harbour could be on route to pass through Gort ending up in Claremorris.
Drool, I nearly fell off my perch looking at those wonderfully crafted scenes. Stunning in the extreme, atmosphere, reality and nostalgia for the pinnacle of a bygone era.
Got two items lightly weathered this evening for use on Gort SilverFox Tin Van - Not quite as grubby as JHB might like, but enough perhaps to get the idea. Irish Freight Models - CIE Laminate Coach. This is grubber than they would have ever looked. Back in the day CIE kept the black and tan coaches pretty clean, unlike IR in the 1990s who let the mk2 and mk3 stock go to pot as well as the few remaining B&T coaches. Ready for Wexford, well ready enough.
Just keep doing what you’ve been doing it’s superbly effective. Foam sheets, pva, plaster bandage, hot wire cutter, static grass and javis fine granite ballast (N gauge), sculptamold, and imagination inspired by reality.
I bought a Chinese static grass applicator a few years ago on eBay for €24. Worked as well as the Noch for 1/5th of the cost. Btw Dugort harbour scenery is stunningly Irish and realistic
Ah great you sourced the horse truck (ie Lorry)
Cheers watched it. Ultimately if Ireland upgraded Cork line to a high speed (eg TGV, ICE), by continental standards Cork should be 90mins away by rail. Great to hear diesel is going to be phased out in the not too distant future and replaced by electric trains. Enjoyed tonights programme, can be watched back on RTE Player for anybody who missed it live.
Thanks Niall. She sounded great. Hope its not too long before She is ready to haul RPSI Craven Set to Wexford. AAMOI, How will they move her into service when the time comes, as the track she is on is no longer connected to the main line? IMG_1702.MOV
- 1 reply
- 1
Stunning. Reeks of atmosphere. Love it
Thanks. Curiously suppliers have run out of 6mm Birch Ply as it normally comes from Russia. No more baseboard modules for now due to sanctions. They've offered me 12mm but that's just too heavy and too thick for modular baseboard. Time Travel Gort 1969 to 1975 - some modern era fitted wagons visit Gort. Weatherd IRM Cement Bubble + Ballast Wagon, in the long siding awaiting kadee couplings being glued on.
Impressive engineering
Gort extension commences. One more 5ft x 2ft baseboard module assembled today. Hot glue gun makes the process very quick, no screws, nails nor stables, nor PVA. WMRC birch ply baseboard design constructed entirely using only hot glue gun, later joints reinforced with glass tape and PVA. Cross bracing gives the boards torsional stability so they will not warp or bend. I will paint them top and underneath with a grey undercoat to ensure they are moisture sealed forever. Also the grey paint is a good base to stick scenery and track bed to, and underneath a good surface to screw and glue DCC + point motor cabling. Ready for Painting This board will house part of the future fiddle yard hidden behind the back scene
No probs, we live in a free enterprise market. https://www.youtube.com/watch?v=R1ZU6UMDfgY
