Noel
Everything posted by Noel
  1. Hi Railer, do you have a link? Thanks. Noel
  2. Dilemma - I have prepared replacement bogies sides for recent SF C class project, but I am thinking of leaving the donor loco bogies in place because the SF ones look hideous compared to the quality of Bachmann or Hornby! Dilemma is put very poor looking but prototypically correct MV bogies, or leave the donor bogies because they look great despite being the wrong bogie sides. I just prefer the look of the wrong sides on the model. All the gubbins and stuff!
  3. { Thud } That was me falling off the back of my chair looking at this stunning layout. Superb scenes. Lucky for me the A class was not in Black'n'Tan livery or I might have fainted.
  4. Great achievement to be a pioneering trail blazer, and go through the ranks from catering to a passenger locomotive driver in 8 years. IE were perhaps little behind change considering Aer Lingus's first female pilot started in back 1978. It took strong, dedicated and talented personalities to 'break through' barriers of a distant past.
  5. Done. Good luck with your Thesis. An important flight safety issue that has probably at one time or another effected many reading this thread without them ever being aware. I won't post any comments on the survey content so as not to distort other respondents answers.
  6. Noel
    NCC Jinty
    Thanks, that's very interesting stuff guys. One question, did operators using oil not put in place procedures to raise boiler temps more gradually when using oil to bring locos up to operating temperatures, and therefore avoid the problems highlighted above? Only reason I posed question about oil/kero was as an option for preserved steam locos in light of perceived high coal costs.
  7. Noel
    NCC Jinty
    Hi JB. Please forgive my total ignorance, but could boilers in steam locos be heated with oil/kero rather than coal? Cleaner and less expensive if they can get high enough temps? Running for cover now. Noel http://www.greatwestern.org.uk/m_in_gwr_oil_fire.htm
  8. Noel
    Class 121
    Thanks Graham. I've come close to getting a LokProgrammer, but getting access to Irish diesel loco horn and whistle sounds and the steep learning curve has put me off. I'd love to try 'rolling' my own sound project where one could switch from 'Full Throttle' mode to auto notching at will, and add other tracks such as rail clack nose at various speeds, brakes for an entire rake, etc. As its pure software I would hope it is possible anyway to have a project that can be switched via function from 'normal' to 'tired' engine mode on the same chip without needing to reflow it. Noel
  9. I love his honest comment: "Throw out the buzzwords 'prototypical scale model' and remember that these are toy trains. So play with them."
  10. Noel
    Class 121
    So existing 141 sound projects will do perfectly for early 121s and existing 181 sound projects will do for later 121s. Special 121 sound projects NOT needed at all at all! I can't tell any difference listening to dozens of youtube clips.
  11. Noel
    Class 121
    ROFL - Can I come too!
  12. Noel
    Class 121
    So it looks like two versions of 121 sound chips may be needed to cover most options. One for original 567 engined locos such in delivery grey/yellow, black'n'tan and early supertrain liveries, and one for 645 and 645E engines used in later era IE/IR livery locos. Are we at risk of nit picking?
  13. Noel
    Class 121
    Hi Graham, I don't know to be honest. They supply normal, tired and overhauled engine sound variations for 141s and 181s (i.e. 6 variants with PD and 6 without PD). All I know is their LokSound projects sound better than the authentic recordings made here from actual IR/IE prototypes. I've a mix of PD and non-PD LokSounds, but to be honest I prefer driving the non-PD versions, just simpler to operate. Zimo/RealDrive remains my favourite to drive but the 141/181 sound is not as good as ESU, so I've gone ESU. Jeepers we are spoiled nowadays with sound options for Irish diesel models. Noel
  14. Cheers guys. B233 is really an MM/Bachmann 141 with a C class body on it. No sound yet Popeye, what you heard was a 181 pilot in the background waiting to shunt. Might post a clip of it later hauling IRM ballasts. Now have to turn my attention to finishing B121.
  15. Noel
    Class 121
    Thanks guys, that is great information. I will go with a EMD 567 sound project for my B121 project which ran in 1960s in B&T livery.
  16. C class B233 video clip of chassis trials today on the layout (work in progress). Silverfox kit paired with a Bachmann/MM 141 chassis. The 141 chassis was a near perfect fit with minor modification needed. I will replace the bogie sides later this week once the chassis trials are ok. When I started out the 141 donor chassis was destined for a 121 project which would have required a major cut'n'shut to shorten the metal chassis, so I completely dismantled the chassis, which proved unnecessary as I decided to use it in the C class instead. However putting 'humpty dumpty' back together again proved quite difficult and I misplaced one of the motor shims which is causing a slight vibration and noise that I will have to rectify. Initial tests suggest sacrificing the 141 to get a good quality AWD/AWP centre drive chassis for the C class was worth it for slow speed running quality and shunting of loose coupled goods wagons. It will need more work to finish.
  17. Thanks for the info Richard. Personally so far I have only tried beat wagons and a 121 body, but keen to hear how others found 3D especially for 00. I wondered why some model bodies are not printed in multiple pieces instead of one, as it may use less material and reduce surface 'stepping' on curved areas of some models. 3D still seems a long way behind injection moulding for quality, but offers reasonable enough quality depending on the design for some models not available as RTR.
  18. Great bit of model engineering Eoin. The bogie sides look alsolutely superb.
  19. Looks fabulous. Excellent
  20. Noel
    Class 121
    Thanks Patrick. So in the 1960s B&T 121s would have had the original 567CR. Noel Thanks Fran.
  21. Noel
    Class 121
    Interesting info Dave. So would Black'n'Tan 121s during 1960s have had 567CR or 645 engines? Wheeltappers (http://www.wheeltappersdccsounds.co.uk/styled-5/index.html) have 6 variants for 141s and 181s (normal, tired, overhauled engine), with or without PowerDrive mode (PD) which is their implementation of LokSounds Full Throttle mode. I understand they plan to release a number of 121 variants. I have both PD and non-PD versions of their 141 and 181 and they sound really well. Will be changing the chip in my B121 later this week.
  22. That pic no #125 of 078 hauling the mk3s is a super shot. Nice to see a proper train
  23. Nice video Kieran. Your diverse range of rolling stock looks really great. The 3 IRM ballast wagons blended nicely into your own rake. Liked the subtle weathering on the IR/IE autoballasters.
  24. Hi Robbie, Nice job they look great. Are the chassis less fiddly to work on then the single beats? Noel Prototypical colours seemed to vary greatly anyway from various shades of grey, bauxite, brown, etc
