Could try http://www.matts-place.com/intermodal. Has a good range of pictures of containers of all shapes and sizes..
30ft Bulktainer
http://www.matts-place.com/intermodal/part4/belu0035974.jpg
http://www.matts-place.com/intermodal/part4/belu0036266.jpg
standard 40ft
http://www.matts-place.com/intermodal/part1/images/belu4285441.jpg
Not bells but the containers used for ore and grain in the 90s
http://www.matts-place.com/intermodal/part2/images/opentops/amfu2951450.jpg
TPWS is the signalling equipment used on NIR, nothing to do with push-pull.. Although does mean 209 will hopefully be returning to more regular use on her home patch..
It would be heated to reduce its viscosity and then pumped through pipework into the terminal.. Not sure if the IE wagons had electric heat or burners though. Also the tanks were insulated so would retain some of the heat..
Found this on youtube, has the jumbos on the back of a liner.. Can't make it out but the first tar wagon has something written in the bottom left corner. It nearly look like the BRT logo from the UK, anyone know what it says??
Yeah there pretty common, if you look at videos of the DFDS a lot of them carried 30ft UBC/IBC bulktainers which as best I can find out carried asbestos mixed with peat from the former Asahi plant in Ballina.
The 40ft beet containers had an extra door to the side of the wagon and the Iso container end doors were kept closed. To discharge the side door was opened and the water carried the beet out the side same as with the two wheelers.
If I was unloading the Grain I would make it either end tipped (end doors open and lift container up) with a special road trailer or else unloaded using a grab but not sure which was used.
To load in Waterford the wagons were put under chutes and the grain dropped in. There's a picture of the set up in the feb 2004 IRRS journal. While Dublin and Foynes both seem to have involved a road shunt.
In the uk and europe their special grain wagons had doors on the bottom like the HOBS and the grain was tipped into a pit between the tracks and then carried out and up using an auger system.
Heard mention of this when I was working actually, A session between the parties was due to take place the week after I left.. Would have been interesting to sit in on..
Found it, Div 42 isn't one of the perway ones listed though.. Could be a new works division?? or else my list is out of date... 1 to 28 only with no 4 or 20
Is that not a test train though as opposed to a service train, the one for the NI science park or a univerty to measure the effects of heavy passing trains on instruments in the 80s?? Nice pic too though Anto
I'm guessing it has something to do with the fact if one fails in a big way it can't be brought back to York road too easily except by low-loader.. Whereas 112 working at the other end of the line can easily be hauled back to York road and a NIR 201 or maybe 071 substituted. Don't think 071/111s are allowed work in multiple trainman..
I think the wednesday working is Ballina-NW and then Thursday is NW-Ballina.. Same pattern as when the DFDS ran with the wagons stabling in Ballina during the week..
It is indeed, the rail line serves the ship-to-shore cranes which isn't done in Dublin Port or any other port for that matter.
Videos from the port co at:
You should be right about the timber trains as the Coillte plant is in the port industrial estate but the cost of a rail spur has never been justified sufficiently for anyone to cough up...
