Sean
Everything posted by Sean
  1. Sean
    Marks Models NCC Jinty
    I would not mind the cheaper tooling as long as its reflected within the price. If we ended up with railroad tooling for non railroad prices then people should have a right to give out. Good luck with the CN22 @DJ Dangerous
  2. they look to be the same type of NEM pockets that are on the MM 121's and some more recent accurascale wagons.
  3. Do you mean the Chain links?
  4. lol nobody guessed that. Probabaly not for me, although im sure this just about confirms beet doubles in the very near future, of which i will buy many and of course the inevitable flat version of the chassis too. then again by the time they are out i will probabaly have impulse bought a load anyway LOL
  5. Youll have to go and find out DJ
  6. that was only cos they forgot about the bus.
  7. who buys wedges from mcdonalds??? really now??
  8. only 18 more minutes until people can wibble about it not being what they expected.
  9. wont be long now
  10. Riveting stuff
  11. not me anyway They are also selling a used switch for more than the price of a guarenteed one from cex? lol
  12. On a more serious note,I see CIE Grey(or an engineering sample), and its a whole new range, so some sort of steam is highly possible. however i also see a black buffer beam and a little hump on top so it could just as easily be some sort of 4w tank car at an unflattering angle. ALSO Were we not promised some sort of elusive foot bridge way back when? squint or youll miss it
  13. thats literally only a photo of half an item, that or its the detailing pack from said item or somthing silly like that
  14. Are we there yet? I am officially excited now.
  15. Looks like I laid some of that track......
  16. A great addition to the upcoming RPSI set for generator car duties, Picked one up around a month ago for that reason.
  17. Get yourself onto addresspal, its the only way to deal with these clowns, it GBP2.85 if hes sending it to a uk address and then 6.50 to addresspal compared to the 18.45 he just made up in his head.
  18. "OLD Renfe BOYS"
  19. and a narrow gauge one!
  20. Ehhhhh would it not be more like this one?
  21. Maybe ill buy it.
  22. is the current microphone the built in one or an external one? In the current recording if the wind noise isnt too bad you could try adding a high pass filter to the audio track however this may also affect the noise of the locomotive if you need to use it heavily. to be a bit more surgical about it, run the audio track through a spectral analyser and then use an EQ to pull out the frequencies where the loudest wind is occurring, again your milage may vary. of course if the noise is BAD then your only solution will be to go and record again with the mic sheltered. I have software capable of doing all of the above if you havent got a clue what im on about. id be happy to take a a look for you. hypothetically speaking, if you had a portable digital audio recorder separate to your camera you could place it in close to the locomotive and sheltered from any wind but focused on the prime mover as @Broithe suggests. this would free you up to record the video from anywhere on the train and you could also use a second microphone and deadcat plugged into your camera with the gain turned down and have it pointed down or backwards. ie not directly into the wind. this mic would record the general atmosphere and the sound further back in the train like the rumble of the coaches as they go along. you would then syncronise the sounds in your video editing software and the final audio track would be a mixture of the two that you will have slightly more editing control over. this would sum together to make a very nice overall sound but may be overkill and would require 2 people to carry out properly.
