Broithe, thanks for that.
I am setting out curves using a trammel on a layout that will be primarily all goods wagons during the steam era. The curves are of a radius of 550mm and upwards.
Yes, Jason it helped. I now have three sides of the shed well advanced in the planning. The problem I have at the moment is bringing four lines at the Goods Shed into two and easing them into the curves at the opposite end to form the return. Shouldn't be too much trouble. Thanks
Just spent the morning going through the text and pictures David, an amazing wealth of modelling expertise you have shared with us here. It just takes you back to rural Ireland during the Clogher Valley era. A superb reference. Thanks
The Goods Store in Omagh was huge, measure well over 700mm in scale length. I would rather not start shortening it and narrowing it but I have considered the possibility of modelling it on a curve. Would it look awful?
I have 5 x Peco SL-E198 Large Radius Y points as new £40 (postage not included) and
5 x pack of Gaugemaster Point Motors (unopened/unused/new) for £20
No longer available
I have about six maybe seven Peco electrofrog Code 75 Y points for sale. They are used because they were connected to a layout for testing but neither soldered or pinned.
They are like new in original packing.
PM if interested
Tony
Previous efforts at shunting layouts have led to complex pointwork and wiring. This created much frustration especially when locos had nowhere to travel.
thanks
Sounds good.
Apart from the complex point work at Omagh Goods Yard when the line left the station area, in either direction, there was nothing but a single line of track all the way to the next stop. With this in mind, I think there is a need to raise the entire track enough all round to form embankments and bridges to give an illusion of reality. Therefore, i'll be keeping the area off the station area very simple. No point in complicating things.
Thanks
David, thanks. I get you. Mainline with passenger stock to the back scene and wagon stock to the inside of the baseboards where curves are tighter. Correct?
At the moment I have two options that raise some thought.
Moving my goods yard into the right corner (in bottom picture) and running the main line across the front of the baseboards,
or I can move the Goods Yard buildings to the small unpainted triangle on the left and run the continuous main line behind it along the walls.
Whats the best way to do this. The first option is set out roughly at moment, below.
Finally made the move and made a total restart in the shed, below you can see that I am now using all four walls of the shed and want to see those GNRi locomotives moving with lots of goods on board.
Ultimately I want two lines to allow continuous movement around the shed with sidings at various locations.
So I’m back at the design stage, again but much happier with the baseboards now. The board at the shed door lifts in and out easily.
Since there is nothing on in the North of the Island I would make a point of calling at Headhunters Museum, Darling Street, Enniskillen if you are in the area. Also, Transport Museum, Cultra, Belfast. That’s two days out anyway.
