GNRi1959
Everything posted by GNRi1959
  1. Its worked out fine, I need a pack to deck another small section of platform that I over-looked and this will be fine now. As for 'shortening a section of platform' I just wouldn't.
  2. I'll hold out, if a bit doesn't turn up I may ask Peco if they have any samples.
  3. PS. Does anyone know the internal sizes of the brick arches in Wills SS55 kit?
  4. Can anyone help with a small piece of Wils paving approx 90mm x 50mm. I've run out completely and don't want to buy a full pack. The photo will show what I need. This is the only piece of platform left in the layout.Please.
  5. Today the rewiring came to an end with all cables, terminating in small 'spade connectors' (that I soldered myself!) were labelled and connected up through the new switch panel on the front of the baseboard edge. I'm still trying to find six small screws to fix the DPDT slide switches to the perspex panel, probably need to use self tappers of tiny countersunk screws and bolts. The first of the platform ends were laid using Peco platform edging, faced with Wills course stone and paved on top with Wills paving. It looks really good and starting to look like a station. The track runs well and I'll have to start replacing any missing sleepers that were cut during the track laying process. It is coming together slowly and I am really enjoying the time I work on it.
  6. You're too sharp boy!
  7. Omagh North had a total re-wiring over the past few days. All cables were re-routed around the baseboard edges under bell-wire clips and away from paintwork. I am seriously considering the Megatracks point system that controls up to 12 points from one board. Tomorrow I have to make one final linking of cables to new front panel mounted board and I can start of the platforms.
  8. Sorry, I don't
  9. Leslie, heres one of your Inglis bread container in the siding at Omagh General Station.
  10. Yesterday Omagh North took a backward step, though for the better! I have repositioned my DPDT switches from the baseboard top to the edge of the framing out of sight. I filled the opening with a very neatly fitted piece of ply. This also means that I can erect a proper background, if I ever go public. During the process I decided that the wiring, which looked a terrible, should be stripped and a fresh start made. This time I want to route the cases along the inside edges of the baseboard frame before exiting at the front panel. The rewiring will be thoughtful and involve labelling everything for future movement. A box of cable clips will contribute to the tidy up. All areas under paintwork and track work will be left cable free for possible electronic point controls in future. Question: If I have fixed track work to a 3mm cork roll underlay, can my Peco platform edging strips be fixed to the cork also or do I need to fix to plywood baseboard level to maintain true scale heights?
  11. Kirley, amazing looking layout and models. The thing is, the more wagons you have, the better they look. Thanks for letting me view. Will this layout be at Bangor? Which paints did you use to finish?
  12. Theres so much happening at the moment with Omagh North. At one end its a partial build of Shed in goods yard to create a scenic break, points to be connected to some sort of levers, platform ends to form, water tower and plumbers store to scratch build. Other end I have a road bridge to scratch build and lot of trackside detail to study and source. Its nice to just work a little at a time and enjoy it.
  13. I received this demonstration piece today Andy and I really was impressed with it. It puts all out out of my mind that it is cheap yet effective way of controlling paintwork. I'd be really pleased with this system. I can't say thank you loud enough, it was a very nice thing to do.
  14. I really am sorry that a dear friend Norman Johnston wasn't still with us. He knew carriages like nobody. We used to leave Omagh at 4am to catch steam excursions regularly. He carried a notebook to record engine and carriage numbers. His knowledge was transferred to publishing books in latter life.
  15. Richard, sounds good. I think I would be scrapping the body and keeping the chassis only. I would do a total rebuild of the body. Plan is is to model things that aren't commercially available.
  16. So excited today after receiving my first GNR(i) wagon kit from Provincial Wagons. A great little kit that I'm looking forward to seeing on 'Omagh North' in due course. Thanks Leslie.
  17. Thanks Andy, very kind of you to offer.
  18. This is Market Branch Goods Yard which is the site of the new library. The buildings on the right have been renovated and exist today.
  19. Is there any published dimensions of goods shed clearance at opening such as this at Omagh. The opening is actually to the right of shot, the other one, facing camera, was not an engine access. I'm sure its all standard but don't want to guess. Need height and width for single line openings.
  20. Noel, interesting results. I used the 3mm cork which I bought off eBay in 2m roll x 500mm wide. The fine ballast looks superior and I'm returning to this thread when its time for me to ballast my own track, thanks.
  21. Don't know if this is the correct place to post this but on the subject of the Shell wagon heres a picture from Omagh Market Branch station and although side view, there are clearly both SHELL and ESSO Wagons in the sidings here.
  22. Sent a PM - thank you
  23. Switches set into small matt black perspex panel that was cut by laser. Just need a few very small screws to fix to plywood top, neat.
  24. Please excuse my ignorance of Irish GNR wagon detail but is this wagon chassis and brakes not something close to Irish? The wheelbase is only 8'6" but in terms of scale thats just 1.99mm of a difference. Unless there is something terribly wrong, that I don't see, would this be a pretty good starting point for a scratch built wagon?
  25. Andy, any photographs would help the description - and thanks to both yourself and Leslie for 'stepping forward'.
