GNRi1959 Posted December 10, 2021 Posted December 10, 2021 I have managed to foul the spring of a Peco point. The point will switch one way but will not return to the opposite side. Is there any way of repairing this?
Broithe Posted December 10, 2021 Posted December 10, 2021 Is this the biasing spring? Or one of the "switch blades"?
GNRi1959 Posted December 10, 2021 Author Posted December 10, 2021 2 minutes ago, Broithe said: Is this the biasing spring? Or one of the "switch blades"? Yes, the spring is banjaxed!
Broithe Posted December 10, 2021 Posted December 10, 2021 (edited) 20 minutes ago, GNRi1959 said: Yes, the spring is banjaxed! Broken - or distorted? If it's distorted, can you re-bend it to shape? If it has dislodged, can you replace it properly? There are lots of videos on YouTube, depending upon what the problem actually is. http://2.bp.blogspot.com/-cDTLbJzBnZM/VLASkU2wZDI/AAAAAAAAHvc/ARdk83mBTns/s1600/Peco%2BSL-8352-1mc.jpg Edited December 10, 2021 by Broithe
GNRi1959 Posted December 10, 2021 Author Posted December 10, 2021 (edited) I just ordered a new one, to be honest, the spring was bent so I chucked it. Christ but modelling doesn’t half eat up your pocket money! Edited December 11, 2021 by GNRi1959
Broithe Posted December 10, 2021 Posted December 10, 2021 Depending on how you are operating the point, you may not actually need the spring to be there at all.
spudfan Posted December 13, 2021 Posted December 13, 2021 You do not need the spring. The point rails will catch on the little lugs attached to the outer rails. You can bend them up if the point will not catch and stay put. I changed over to Peco Electrofrog when I rebuilt the layout over twenty years ago and those points are still in use and none have needed to be replaced. 1
Mayner Posted December 14, 2021 Posted December 14, 2021 At one stage Peco supplied the "Over center spring" as a (possibly free?) spare part. They would send an envelope full of springs if you contacted the Peco Technical Advice Bureau https://peco-uk.com/pages/help-advice It might be worth sending an e-mail.
Robert Shrives Posted December 16, 2021 Posted December 16, 2021 Do not junk the point - cut in half before the crossing and you get a double bladed trap point for end of loop - fixed to suit route out if needs be - fitting a little spring from a coupling or perhaps a biro might give enough "locking." Robert
