Soldering Irons for model railways
8 answers to this question
Also depends on the type of tip that will suit the soldering you plan to do. Working with PCBs and thin wire probably a pointed tip, but if mainly soldering wires to track or fishplates a chisel tip is better.
As others have said, depends what you want an iron for. If it is just electrical connections, then a 15-25 watt iron and 240 degree multiple solder will do you fine. However, if you are starting on kit building, then a 40 watt iron, flux of some sort and a mix of 140 and 180 degree solder, plus the 240 is required to cover a variety of tasks.The
 As ever, start simple, and build up your skills. There are plenty of online tutorials that a quick internet search will help you with.
  • Agree 1
Answer this question...
