Old wagon photographed in Cavan
Wexford70
The GNR & SLNCR were the main users of peak roofed Railbus/Railcar trailers in Ireland. The main challenge is building the railbus/railcar to haul the trailers.
Neil Ramsey has mastered the art in 15mm scale and David Holman 7mm scale SLNCR railbus and trailer has appeared on his Workshop, Arigna & possibly Belmullet layout threads.
Neil Ramsey's SLNCR railbus and luggage trainer appears at approx 1:47 in his Irish Broad Gauge Diesel railcar video
Edited by Mayner
Thanks for the mention, John.
Alphagraphix do a 7mm scale card kit of the Sligo railbus, which I used as a drawing when scratchbuilding my model. Last time I looked, I think it was four quid. Not for the faint hearted though, all those angles and complex curves make for a very challenging build.
 The issue with the trailer is that, whatever scale you do it in, the W iron/spring/axlebox units are very small, so ordinary wagon ones look too big. When I did mine, decided it was important to fit pick ups to the trailer, but this compromised the ability of the single axle bus to haul it and ensure the trailer wheels rotate. On reflection, fitting a motor bogie type mechanism in the trailer might be a better solution, but hiding the gears would not be easy.
 Now then Angus, how about a 2mmFS one???  😇
