murphaph Posted May 6, 2023 Posted May 6, 2023 Hi all, Does anyone have any 201 spares? I am specifically looking for the pipework running along the side and bogies side frames. Feel free to send me a PM if you can help. Cheers! 1 Quote
DJ Dangerous Posted May 6, 2023 Posted May 6, 2023 I wonder if there will be spares available from Paddy when the new run of 201's arrive. Could be a while, I know, but he may surprise us! 1 Quote
mmie353 Posted May 8, 2023 Posted May 8, 2023 https://www.ebay.ie/itm/134564547082?hash=item1f54ac0a0a:g:YDoAAOSw8oZkWQJk https://www.ebay.ie/itm/134564550799?hash=item1f54ac188f:g:SkUAAOSwdWNkWQWS Marked as spares but not sure if the parts you need are on either of them 1 Quote
Horsetan Posted May 9, 2023 Posted May 9, 2023 7 hours ago, mmie353 said: https://www.ebay.ie/itm/134564547082?hash=item1f54ac0a0a:g:YDoAAOSw8oZkWQJk https://www.ebay.ie/itm/134564550799?hash=item1f54ac188f:g:SkUAAOSwdWNkWQWS Marked as spares but not sure if the parts you need are on either of them Very curious - no prices or starting bid showing up on either chassis Quote
DJ Dangerous Posted May 9, 2023 Posted May 9, 2023 1 hour ago, Horsetan said: Very curious - no prices or starting bid showing up on either chassis If viewing on a mobile device from outside of the .ie cachement, you need to change the .ie to .co.uk in the url. https://www.ebay.co.uk/itm/134564550799 https://www.ebay.co.uk/itm/134564547082 I'm sure that Wiggy is actually the chap from Wheeltappers. Neal or Neil? Quote
DJ Dangerous Posted May 9, 2023 Posted May 9, 2023 What ever happened to @wiggy? He deleted loads of his own forum posts about ten years ago and kind of vanished off the forum. Quote
gph2000 Posted December 26, 2023 Posted December 26, 2023 Does any of you know where to get buffers or the tension lock couplings for an MM201? Quote
Robert Shrives Posted December 27, 2023 Posted December 27, 2023 The couplings are standard fishtail NEM couplings IIRC and so any Bachman/ hornby/ dapol would fit. check with a coupling off a wagon? robert Quote
WRENNEIRE Posted December 27, 2023 Posted December 27, 2023 Years ago I bought buffers from Peters Spares They were for a Lima 201 Not sprung but had the right profile Class 66 I think Quote
gph2000 Posted December 28, 2023 Posted December 28, 2023 On 27/12/2023 at 11:23 AM, Robert Shrives said: The couplings are standard fishtail NEM couplings IIRC and so any Bachman/ hornby/ dapol would fit. check with a coupling off a wagon? robert Thanks Robert. On closer examination, I realize that the pocket was attached to the coupling and the chasis that needs couplings also needs pockets! It was only when I looked up fishtail that I noticed that it must be a two part assemby. Quote
