kevrail Posted February 1, 2013 Posted February 1, 2013 Guys has anyone used these static Grass Applicator. If so what do you think of them? Your thought and comments appreciated please
0 Flying Scotsman 4472 Posted February 1, 2013 Posted February 1, 2013 I have used the one pictured above and the Noch Grassmaster. Although the Noch is more expensive if you want the proper results its the way to go as for the cheaper system you will get certain results but it ain't got the power of the more expensive system and won't give you as good of results. Also the cheaper system struggles to cope with longer grass fibres. At the end of the day it's what you can afford and what results you want to achieve.
0 Garfield Posted February 1, 2013 Posted February 1, 2013 There is another DIY grassmaster design that is essentially identical to the one Noch makes, and can be made for a fraction of the price. I can't find the link to the instructions for building it, but it's the same one Everard Junction uses:
0 Barl Posted February 1, 2013 Posted February 1, 2013 I bought one the same as that shown in the picture above and, although it could have just been my operation of it, I didn't get great results and just reverted to the static grass shaker bottle which gave better results. It can also give you a nasty shock which wakes you up a bit
0 Flying Scotsman 4472 Posted February 1, 2013 Posted February 1, 2013 It can also give you a nasty shock which wakes you up a bit You want to get a shock from the Noch now that really makes your hair stand on end
0 Dave Posted February 1, 2013 Posted February 1, 2013 All Scales Models do them, I haven't used them myself, worth a try.
0 Broithe Posted February 3, 2013 Posted February 3, 2013 The Flock.It was being demonstrated at Stafford yesterday and seemed to work quite well. http://www.dccsupplies.com/shop/product_info.php?products_id=4310
0 Noel Posted February 13, 2017 Posted February 13, 2017 (edited) Picked this static grass applicator up on eBay two years ago for €15. Worked a treat tonight. Don't forget to ground the mesh when finished and it's turned off to discharge the remaining static electricity or you might get a nice little shock that makes a cattle fencer seem like a tickle Edited July 21, 2017 by Noel
0 David Holman Posted February 15, 2017 Posted February 15, 2017 Beg, borrow or steal because static grass is a huge improvement over scatter in 4mm scale or larger. The Flock it is the top of the range machine and superb. However, smaller, cheaper versions are not to be sniffed at while the Noch puffer bottles are extremely good for tight corners.
0 Noel Posted February 15, 2017 Posted February 15, 2017 Beg, borrow or steal because static grass is a huge improvement over scatter in 4mm scale or larger. The Flock it is the top of the range machine and superb. However, smaller, cheaper versions are not to be sniffed at while the Noch puffer bottles are extremely good for tight corners. Yes static grass is a new experience for me. Very impressed with the whole concept and was surprised how well it worked. The €15 Chinese rip off I bought on eBay has worked well so far and it is about the same size as the €150 noch. I knew it could have been a risk but worth a punt at that price - and it works.
kevrail
Guys
11 answers to this question
