'Silver' carriages
I have been trying to work out which CIE carriages carried 'silver' (more accurately aluminium) livery. I'll start with this lovely 1959 photo from Ernie of the 'space-age silver' TPO, luggage van and carriage contrasting with an ancient 2-4-0 kettle and an equally ancient wooden van:
CIE 1958-09-15 Sligo G2 655 z095
I think I've worked out the following:
  • Carriages built up to 1953 on the traditional underframe and GSR-style bogies were green with black underframe (matching the AEC railcars).
  • Carriages built in 1954/55 on the triangulated underframe and commonwealth bogies were green with silver underframe. This includes the Park Royals.
  • Carriages built from around 1956 to 1958 were all silver (matching the newly delivered Metrovick locos). This includes:
    • 1429-1443 and I think 1444-1448 standards (7 bays of 10 seats)
    • 2162-2171 composites
    • 2700-2765 4w tin vans
    • 2962-2971 4w TPO (but with black underframes, and silver carried up onto edge of roof)
    • 2972-2978 TPO (but with black underframes, and silver carried up onto edge of roof)
    • 3101-3141 4w heating vans
  • Buffet cars 2419-2422 were also built in this period but I'm not sure whether they were green or silver? I haven't found a photo of a silver one.
  • The carriages introduced from mid-1958 onwards reverted to green livery with black underframe (as did the diesel locos). These included the later-built laminates and tin vans:
    • 1449-1496 standards (8 bays of 8 seats)
    • 1909-1913 brake standards
    • 2172-2179 composites
    • 2549-2558 bogie brake/luggage vans
    • 3142-3152 4w heating vans
  • After that, I think it was black and tan.
So, to the questions:
  • Have I got this right? If so, then there weren't actually very many silver passenger carriages - only about 30 of them. Many more vans of course.
  • Were all the silver carriages true 'laminates'? The TPOs in particular do not have the normal bulbous 'laminate' cross-section.
  • Some of the silver carriages had their numbers and class designations in red. Was this true of all of them?
  • Were any older carriages repainted or reclad in silver/aluminium in this period? Asking because the 1331-1334 series GSR suburban composite, nearest carriage in Ernie's photo below, looks rather silver! (note - there is a silver laminate towards the rear of the train for comparison)
CIE 1959-05-17 Killiney 2619 JGD
Thanks to Ernie and IRRS, a couple more images of silver carriages, mostly in colour, just to make sure I've illustrated all six types listed above:
CIE 1959-05-16 Dun Laoghaire 260 JGD
https://www.flickr.com/photos/irishrailwayarchive/54257008899
CIE 1960-09-12 CorkMail van 2973 DT16-14 CIE 1961-3 ca Roscrea 125 xing A16 yj205 Youghal 3106 img326
Nice mix of 3 silver and 4 green carriages here, with a black and tan 141 on the front:
https://www.flickr.com/photos/irishrailwayarchive/54257002708
https://www.flickr.com/photos/irishrailwayarchive/54257198895
15 answers to this question
2 minutes ago, minister_for_hardship said:
Open to correction, but I recall it was coaches in as-built bare aluminium sheet rather than being painted silver.
Yes, you're correct for the bodies. The underframes were steel so they must have been painted. Most people describe the livery as 'silver' which is why I used that term.
It looks like some Bredin Coaches dating from the 1930s and non-Laminate stock appeared in silver.
1. The 1st  'silver coach' in the railcar set in the Killiney photo appears to be a Bredin Suburban coach (rainstrip & window/door arrangement main spotting feature). These coaches were built with steel body panels so possibly a re-paint as Bredin coaches which passed to RPSI retained their steel body panels until withdrawn from service in the early 1970s.
2. The coach behind 260 appears to be a Laminate Suburban coach which were converted to Brake Stds during the early 702
3.The TPO (built late 50s) appears to have aluminium body panels on traditional timber body framing. The body sides would have had to be near vertical above the tumblehome for the mail sorting racks, the 4w PO vans had a similar body profile, while the Tin & "Hooded Vans" had the teardrop body profile similar to the majority of Laminate coaches.
Main spotting difference between Liminate and conventional timber framed stock, was the Lainates were built with full height body panels (which included windows) with vertical coverslips between adjacent panels, without the horizontal coverslip at waist height used on conventionally built stock.
Many thanks John, that's useful to understand the differences in the panelling.
1. I agree that the 'silver coach' in the railcar set in the Killiney photo is a Bredin, it's a 1331-1334 series GSR suburban composite, and the particular spotting feature is that the end doors open into a seating bay (with a small window each side of the door) whilst the middle door has a vestibule. I can't decide whether it's really silver but it certainly looks that way. There's another colour photo in one of my books of a GSR suburban brake standard in the late 1950s, which also appears to be silver.
2. Agreed, it's a 2162-2171 series composite.
3. The TPOs are interesting, they are definitely a different body profile and I think you've hit the nail on the head for the reason why. Here's another of Ernie's photos with a closeup of one of the 4-wheel ones in silver:
CIE 1959-06-28 Mullingar 604
That photo and this IRRS one clearly show the cover strip at the waist:
Somewhere I have some photos of the interior of one of the preserved bogie TPO's, I'll have to dig them out and see if the framing is visible.
This photo of Ernie's dated 1959, and the IRRS one linked below it dated 1960, I think prove that the later laminates, specifically these two batches delivered in 1958-1960, were painted green from new:
CIE 1959-xx-xx Dublin - Belfast nameboard in English
https://www.flickr.com/photos/irishrailwayarchive/53499133230
The first photo also nicely illustrates the lack of horizontal strip at the waist as you mention.
Hmmm - 1910! This became the "Loughrea Coach" in 1963, with storage heaters added!
  • Agree 1
Silver composite in a mostly black'n'tan rake in 1963, just a couple of greens in there too:
https://www.flickr.com/photos/irishrailwayarchive/54419680764
https://www.flickr.com/photos/irishrailwayarchive/54418626222
Another mixed livery rake - 2 silver seconds and a van, with 3 green coaches and a van, black'n'tan loco, also in 1963:
https://www.flickr.com/photos/irishrailwayarchive/54419866190
Silver loco and tin van, with coaches in dark green, light green and black'n'tan, one of each! 1962:
https://www.flickr.com/photos/irishrailwayarchive/54419876190
https://www.flickr.com/photos/irishrailwayarchive/54419876160
This is precisely why I like this period as a basis for modelling. You can run steam alongside B101, B121, A, C, E401 & G601 class diesels up to the start of 1963; and while the steam disappears after that, the B141s enter stage left.
Wagons - old GSWR & GSR, with an extremely occasional DSER or MGWR type, may all be seen together wearing darker or lighter grey; the former with painted pale green or qwhite snails, latter with stencilled white snails. (No brown till a decade later). But in addition, all the new standard CIE types from Bullied opens to "H"s.
Carriages - you've old wooden stuff from GSR, GSWR, MGWR and a (very rew) ex-DSER or CBSCR in both green liveries, plus in the first three categories some in black'n'tan too. Amongst these are new CIE stock in silver, or lighter green, or black'n'tan; plus ex-GNR stock either in GNR brown, GNR navy & cream, CIE light green or black'n'tan. Add the tin vans in green, silver or black'n'tan.
At no point before or since was it possible to get a mix like that. The reality was that at the very point when motive power was changing from steam to diesel, the railway had gathered together the last few of a myriad of different types of everything, which were now being added to and gradually replaced by brand new stuff; and in the midst of all of that, the railway had five diesel loco liveries and four for carriages all at the same time, as WELL as "imported" GNR types - blue or blaxck steam engines, and two GNR liveries.
And it was not even a case of "all old carriages are green, all new ones black'n'tan". Some older vehicles, built in the 1910s or 20s, were newly turned out in black'n'tan, while a "new" coach (say, a laminate built in 1958) was still green.
A final twist to the tale with the six-wheelers. These, within that period, still held sway on a handful of branch lines, all being the lighter green by then. Early 1963 saw the end of any passenger six-wheelers, but as we know from the Hattons release, three or four six-wheel full vans remained in traffic after that, until the late 60s, and were painted black and tan, and therefore will have seen use alongside Cravens! The latter, otherwise, would never have run with any six-wheelers.
Incidentally, this is why only the six-wheel full brake is offered in black'n'tan - in green, it ran with passenger-carrying six-wheelers, but in black'n'tan it would only have run with bogie stock. No passenger 6 wheeler was repainted black'n'tan. A pity, perhaps; sheer curiosity makes me wonder what a Midland 6-wheel third would have looked like in that guise!
On the question of numeral/lettering colour on the silver carriages.
‘Irish Railways in the 1950s and 1960s’ (McCormack) page 102 features a colour photo of a pristine silver coach, which may be one of the 2162-2171 series composites but I’m not 100% certain.
The coach number and class digit are undoubtedly red, as is the dimension plate on the end. Everything else is either unpainted aluminium (bodyshell including ends and roof) or painted silver (bogies, underframe, battery boxes).
I must say that in pristine condition it looks extremely smart. The photo is dated 26/03/1957.
I am still hunting for other colour photos of silver carriages that are clean enough for the numeral colour to be determined. Such photos are hard to find as they got dirty so quickly and in most cases the numbers are too small to show up in a photo of a train.
Did all the silver coaches have red numbers, or did some have green numbers as the silver locos did?
I’m still hoping that IRM have some silver coaches up their sleeve to go on the Park Royal underframe. If not I can foresee that I’ll have to do some etches…
Edited by Mol_PMB
Doubt over coach identity
Further on the 'Silver Princess', and additional to the thread linked by Mogul, there is an article with drawings in N.I.L. 3.6 (November 2004) available here:
https://newirishlines.org/archive/
There is a good broadside view of it in original condition in Harris's book on BR MK2 coaches.
Also here in a photo from Robert Carroll's collection:
Silver-Princess_LeithCentral_22-5-48
The Fry model collection includes several silver carriage models which must have been built about the same time as the real thing.
Interestingly there are 3 different lettering styles/colours on them. They also include a silver Park Royal - did this ever exist in full size?
I've been having another trawl through the IRRS photo archive, predominantly for wagons but I've picked out a few silver carriage photos too.
It's not often you see a consistent silver train, without light green, dark green or black'n'tan carriages. But I think this counts - and it's the Loughrea branch train:
https://www.flickr.com/photos/irishrailwayarchive/53447303315
It's even got some silver Bulleid wagons at the back, though I confess there are some grey ones too.
This photo shows three tin vans of the steam-heating variety, two brand-new and one which looks like it may have caught fire. These are all of the first batch with full-depth profiled doors:
https://www.flickr.com/photos/irishrailwayarchive/54252968221
I have read that these vans were originally designed so that their boilers could be removed in the summer months and the boiler space used for luggage. While that would be technically possible it seems unlikely to have been done regularly in practice. Does anyone have any more info on whether this actually happened?
An interesting photo showing what is presumably the Ballina branch train formed predominantly of silver vehicles - a filthy A9 and THREE tin vans. Other liveries represented by the solitary passenger carriage (a composite in green) and a horse box:
https://www.flickr.com/photos/irishrailwayarchive/54253391500
See, IRM, people do need more than one tin van per train, a model might be worth it!
Fresh out of the box, a tin luggage van in 1957:
https://www.flickr.com/photos/irishrailwayarchive/54253212254
This is an interesting one - a tin heating van, with the bottom of the (body-profile) doors shortened, and looking very clean silver (apart from the roof), in 1958. Perhaps was one of the 1955/56 batch which had been overhauled, the doors modified and the sides heavily cleaned? However, others receiving the same treatment seem to have been outshopped in green. I don't think it's one of the later 1959/60 batch as they had recessed doors and I think they were delivered in green (and after the stated date of the photo).
https://www.flickr.com/photos/irishrailwayarchive/54253198373
A nice contrast in 1957 with a brand-new silver carriage formed into a rake with ancient 6-wheel and bogie stock:
https://www.flickr.com/photos/irishrailwayarchive/54252116022
Another contrast in shape, showing the difference in profile between the 4-wheel TPO and luggage variants of the tin van:
https://www.flickr.com/photos/irishrailwayarchive/53527763295
Looking through the photos again has led me to wonder whether any of the CIE-built TPO vehicles carried green livery in service. I know that one was painted green when preserved around 2000, but I have yet to find a photo of any of them (bogie or 4w) in green in the 1960s. I suspect they went directly from silver to black'n'tan. Can anyone prove me wrong? Is this another example of a preserved vehicle being painted the 'wrong' colour?
