461 run to mullingar
couldnt help it...[ATTACH=CONFIG]12525[/ATTACH]
It's OK - risks have to be taken.
Children are quite easily replaced - video opportunities are far more important and potentially unique.
i fear you shall burn in hell for that remark!:rolleyes:
I know of a few spare in case you run out, children that is PIMP
It's a perfectly simple self-assembly replacement procedure - it's then just a matter of waiting for the materials to cure - sometimes takes months, I understand.
this puzzles me....thought all tenders were filled from the top, not the bottom as in the pic......
[ATTACH=CONFIG]12527[/ATTACH]
The filler pipe was moved to that location to prevent any potential H&S problems when filling the tender under the wires in the DART area.
Correct, and there is still a filler on the top of the tender for use with water towers
