Noel Posted November 13, 2014 Posted November 13, 2014 Look forward to your video Noel.The way the new speaker fits into the loco sounds a great idea. To avoid duplicate posting here is a link to the post with the video of the new 141 sound chip by Mr Sound Guy. http://irishrailwaymodeller.com/showthread.php/3707-Which-DCC-sound-chip-for-MM-141-181?p=58930&viewfull=1#post58930 Cheers Noel
Irishrailwayman Posted November 15, 2014 Posted November 15, 2014 (edited) To avoid duplicate posting here is a link to the post with the video of the new 141 sound chip by Mr Sound Guy. http://irishrailwaymodeller.com/showthread.php/3707-Which-DCC-sound-chip-for-MM-141-181?p=58930&viewfull=1#post58930 Cheers Noel Mr Soundguy has kindly provided me with an advance version of his 071 soundchip and here is a video of Murphy Models 086sa fitted with a Bass Reflex speaker on Ballybeg. https://www.youtube.com/results?search_query=071+loco+realdrive Thanks to Eamonn for the video. The chip uses F4 for brake raising the revs per the prototype (see as loco grinds to a halt), F9 for flange squeal, F2 for short horn, F3 for longhorn plus all MM lights work as plug and play. The RealDrive may be turned off using F5 to give a more DC type immediate response to acceleration/deceleration. Edited November 15, 2014 by Irishrailwayman
enniscorthyman Posted November 15, 2014 Posted November 15, 2014 Mr Soundguy has kindly provided me with an advance version of his 071 soundchip and here is a video of Murphy Models 086sa fitted with a Bass Reflex speaker on Ballybeg.https://www.youtube.com/results?search_query=071+loco+realdrive I really like the realdrive aspect of this chip. The Rev up coming into a Station is nice.
richrua Posted November 15, 2014 Author Posted November 15, 2014 just a quick novice question. To what extent if at all are sound chips automatic ? for example, if i power forward do the engine noises automatically come on or do they need to be switched on everytime?
BosKonay Posted November 15, 2014 Posted November 15, 2014 Sound chips mean you drive the loco like the real thing. You start the engine and move off. The engine revs and notches matching your speed and brakes squeak when you slow and stop.
DiveController Posted November 15, 2014 Posted November 15, 2014 (edited) just a quick novice question. To what extent if at all are sound chips automatic ? for example, if i power forward do the engine noises automatically come on or do they need to be switched on everytime? BK is right, but some of the thread has been devoted to how well the decoder will do this. It seems some sound decoders emulate what is happening with the loco well:trains: whereas others don't respond that quickly to what the locomotive is doing (you don't want the sound of a train at low speed if you have already accelerated halfway down the track, nor the squeal of brakes AFTER you've stopped) Other points raised concern manual notching of the engine (the ability of the operator to ask the sound chip to output the engine at high revs .i.e. high tractive effort, even when it is at low speed, e.g the loco is trying to start moving with a heavy train behind, or conversely is at high speed but you want the sound to diminish as it is coasting down a grade) More esoteric points concern the accuracy of the sounds produced for any particular loco, best listen to the gurus on here who have more finely tuned ears than me:disco:. Edited November 16, 2014 by DiveController
richrua Posted November 15, 2014 Author Posted November 15, 2014 ok thanks folks. i ve never tried a sound loco being only a recent convert to dcc itself.
Noel Posted November 16, 2014 Posted November 16, 2014 just a quick novice question. To what extent if at all are sound chips automatic ? for example, if i power forward do the engine noises automatically come on or do they need to be switched on everytime? They are fairly automatic. All you have to do is turn the sound on by pressing F1, the loco then goes through a 10-20 second engine startup (which can be bypassed). Once the sound is on the engine noise will automatically change based on throttle use, but the revs will notch up or down automatically to match the power the loco is requested to deliver, which may not be the same as speed (e.g: high revs as heavy train starts to pull away from a station despite low speed, lower revs once loco attains cruising speed, etc). The Zimo chip from Mr Soundguy has a nice coasting feature where the engine idles once throttle is set to 0, but the loco continues on at speed very gradually decelerating like the real locos coasting. To stop the loco brakes must be applied using F4. As the loco comes to a stop you will automatically hear break screech. You can manually invoke extra sounds such a flange squeal on bends or over points, guards whistle, short horn, long horn, coach door slamming, etc, by pressing relevant function keys.
DiveController Posted November 16, 2014 Posted November 16, 2014 ok thanks folks. i ve never tried a sound loco being only a recent convert to dcc itself. If you have a loco that is a equipped with a decoder socket, it might be worth swapping one out for a sound decoder to see if you're hooked
richrua Posted November 16, 2014 Author Posted November 16, 2014 Yea man it is kind of inevitable... !!! Weirdly though I am finding that since I have been dcc , a small section of my layout plus three chipped locos seems to keep me happy rather than vast runs in circles. Something to do with the control stuff...
DiveController Posted November 16, 2014 Posted November 16, 2014 Yea man it is kind of inevitable... !!! Weirdly though I am finding that since I have been dcc , a small section of my layout plus three chipped locos seems to keep me happy rather than vast runs in circles. Something to do with the control stuff... Suddenly a lot more to do ……and enjoy:-bd
richrua Posted November 16, 2014 Author Posted November 16, 2014 Totally. I hope to sound up a couple of 141s and an a class . I don't know how to do sound to an a class yet although I did upgrade it to an dcc chassis recently
enniscorthyman Posted November 16, 2014 Posted November 16, 2014 Totally. I hope to sound up a couple of 141s and an a class . I don't know how to do sound to an a class yet although I did upgrade it to an dcc chassis recently Rich,If you check out my workbench page 24/25,I have a bit on my A39 with sound chip.If you are ever Down Wexford way you are welcome for a demo of all the sound chipped locos incl 001 class.The 071 chip(Sound Guy) is by far the best,however the 201 will have improvments as well I am sure. Eamonn http://http://irishrailwaymodeller.com/showthread.php/45-enniscorthymans-workbench/page25
Noel Posted November 16, 2014 Posted November 16, 2014 Does anybody have a video clip of an A class model with sound? I'm very pleased with the updated 141 class sound chip from MrSoundguy. I have a sense that to compliment DCC sound from locos, it might be interesting to also have a permanent background noise track running from layout speakers powered by mp3 or laptop. This could have a mix of station noises, distant trains, passing trains Red shift effect, rail clinks, steam whistles, traffic noise, background platform/people sounds. I vaguely remember Noel Edmunds did a cassette sound track for hornby about 20-30 years ago with a similar assorted sound mix. With mp3 even better results could be played. An ideal candidate for a smartphone app.
enniscorthyman Posted November 16, 2014 Posted November 16, 2014 Does anybody have a video clip of an A class model with sound? I'm very pleased with the updated 141 class sound chip from MrSoundguy. I have a sense that to compliment DCC sound from locos, it might be interesting to also have a permanent background noise track running from layout speakers powered by mp3 or laptop. This could have a mix of station noises, distant trains, passing trains Red shift effect, rail clinks, steam whistles, traffic noise, background platform/people sounds. I vaguely remember Noel Edmunds did a cassette sound track for hornby about 20-30 years ago with a similar assorted sound mix. With mp3 even better results could be played. An ideal candidate for a smartphone app. The 001 chip is by Mr Soundguy,but is not available just yet.
Irishrailwayman Posted November 16, 2014 Posted November 16, 2014 (edited) Does anybody have a video clip of an A class model with sound? I'm very pleased with the updated 141 class sound chip from MrSoundguy. I have a sense that to compliment DCC sound from locos, it might be interesting to also have a permanent background noise track running from layout speakers powered by mp3 or laptop. This could have a mix of station noises, distant trains, passing trains Red shift effect, rail clinks, steam whistles, traffic noise, background platform/people sounds. I vaguely remember Noel Edmunds did a cassette sound track for hornby about 20-30 years ago with a similar assorted sound mix. With mp3 even better results could be played. An ideal candidate for a smartphone app. , When visiting Llangollen a few years ago I purchased two CDs with Diesel and Steam Railway Station background sounds costing £9.99 each. They are produced by Taliesin Studios qt 2 Meiron House, Tan-Y-Grisau, Blaenau Ffestiniog, Gwynedd, North Wales (UK) LL41 3SU.Tel 00-44-1766 830159 e-mail sales@taliesin-consultants.com. Edited November 16, 2014 by Irishrailwayman
