Everything posted by Northroader
Interesting question, with those old Victorian 2-4-0s I’d never be to a tater about slight differences in wheelbase and so on. However, the LNWR Precursors were built as express passenger engines with 6’6” diameter drivers, and these are very noticeable in size. Now if they’d have done a Precedent with 5’6” drivers, the field would have been wide open. The only Irish ones near this were the GSWR 56-59 class, and the 64-65 class, both with 6’6” drivers, McConnell coming from Crewe, and his locos looking quite close in details, the main problem being the raised fireboxes. Then there’s the MGWR Mail engines 7-12 class with 6’3” drivers and flyaway cabs. As a pregroup Modeller I would enjoy titivating either job up, but the Inchicore engines went in the 1890s, and the Broadstone jobs around 1910. Now if they were in the 6’0” - 5’6” blockhole, you’d find some interesting ones lasting right up to the 1950s, which I fancy would have a much wider appeal for a lot of modellers. The other thing is how much notice you take of the tenders, things like narrow bodies and springs above the frames.
Shame to hear that, but you have gained a wealth of experience to make a success of the next one.
Do you reckon there should have been a DWWR branch to Glendalough?
Northroader replied to Glenderg's topic in Photos & Videos of the Prototype
She was only the platelayers daughter, but she knew the gangers length. -
Para Handy would say “Chuist pairfect”
Shaping up really well, just tell me the electrics all work o.k.?
I think a basic need is not to have the scenic background having a right angle in the corners where the back of the scenic section meets the ends of the section. I generally cut the baseboard to a curve of about 4” radius at the corner, and fit the scenery round this. I have tried making the back to fit a half ellipse, but this is wasteful of useful corner space. The actual backscene, printed or painted, needs support, and I do this with a 3mm hardboard sheet. At the curved corner you can curve the support to fit round the corner if you give the hardboard a prolonged soaking, then hold it to the required form and let it dry out. The other thing to watch is if the scenery has a straight horizon, to break it up with trees, buildings, or hills at the corner, or it does look odd.
The firebox does taper, sides and top, but the top looks as if it has a pronounced slant backwards, more pronounced than the real item, which isn’t too far off being flat. Is the front too high or the back too low, or some of both? I’m sure the model must have been made from the correct drawings, but the photos give an unfortunate appearance.
Everything looks so much better in colour, but I still love the last shot. Three brilliant shots there. -
How many AA size do you need to get to Sligo?
Good luck with the venture, thanks for your willingness to make your craftsmanship available in this way. Like Schwarzenegger says, “I’ll be back”.
And someone is asking after information on a GNR “J” class, now where did they go?
Agree fully with you, really good articles across quite a range of subjects and scales, then there’s questions such as why good layouts are being sold and what’s being planned, questions, questions?
If you’re joining two pieces together they need to be both at around the same temperature before they will join, so always have a bit of solder on the end of your iron which will help the heat to flow where it’s wanted. No solder and the heat won’t flow as well, besides the need to have some flowing into the join and filling the gaps. Another thing is if you’re having a long session, more than a few joins, switch the iron off for a while. The iron can get too hot and you’ll have more trouble getting a decent joint.
https://www.railforums.co.uk/threads/one-way-to-deal-with-asbestos-lined-carriages.32900/
I think it will look better with the shorter crane track. Your benchwork is so neat looking.
Just looking at your new trackplan set me thinking of Ruyton Road, an old layout at present getting a face lift. https://www.rmweb.co.uk/community/index.php?/topic/154530-ruyton-road-revisited-what-to-do-with-an-old-classic/#comment-3964744
- 91 replies
- 1975
- mixed livery
(and 8 more)
Tagged with:
The brass tanks look promising, what tools are you missing? All you’re short of is a small halfround file, it seems to me, which is cheap to get. Then you can fit the lower edge of the tank to go round the “bumps”.
Self propelled cranes and small coasters
Northroader replied to David Holman's question in Questions & Answers
You’re on your way to a J18/19 if you shorten the back end of a GWR 2251 0-6-0, which will give you the right chassis, as near as dammit. -
Wonder if the prints would be do-able in 7mm?
The paint finish is great, how you’ve managed to get a totally run down appearance is marvellous.
I’m with Ernie on this. Here’s a video clip of Pempoul, a model done by the Gravetts, who are total masters of scenery. Just watch how the train exits at the right hand end, small insignificant trees in front and behind.
