murrayec
Everything posted by murrayec
  1. Well with DART models on TV, n all!..... Here are a few photos of the completed S-bahn- a project on the go for over 3 years! It's done.... Just a few little touch ups, into the box and will have it on show in Wexford over the weekend Eoin
  2. Oh! the fame, the fame!! Thanks guys, I have not seen it yet but me Mum recorded it Eoin Edit;- Just saw it on the RTE player, great DART coverage- I wonder is there something wrong with the second set's internal lights? The show was a bit one-sided, very much on the negative.... Eoin
  3. until
  4. If one wanted to display a collection and is concerned about protecting their rights to ownership, one could set up a site with, say Wordpress, that displays photos in a thumbnail format only- low enough resolution to preview, but no use for printing or zooming in unless permission is granted by the host- this could be done by request, then granting access permission to the user, or emailing the photo to the user. This requires work and monitoring by the host but does allow the collection to be displayed with a reasonable amount of control and compiles a database of users that permissions have been granted to, if issues arise..... Eoin
  5. Hi Broithe Sid Meade used to do futuristic city & vehicle calenders for a Japanese tyre company, one of his designs was self cleaning streets- the street was in sections and had different faces like a drum, when they needed cleaning they rotated to bring up a new clean face..... Eoin
  6. Hi Noel Disconnect the battery unit from the light strip, and install it under the chassis with wires back up to the strip- then you can pop the battery out easier! A tail lamp can be added to the strips at the end, the dots on the strip are soldering tabs to add additional lights- don't forget the resistor.... Eoin
  7. Hi Borithe It's an exceptionally neat and tidy station! Eoin
  8. I recently had an enquiry on converting an Oxford truck to the Faller Car System, so I thought I'd add a link in here to make it easy to find how I did one in the past, I posted it in my projects thread in 'Workbench' some time back - here is a link;- Eoin
  9. Hi btb A very small unit if you plan to do a lot of painting, you'd be far better off getting something a bit bigger in the compressor area. Here is a link to the kind of unit I use;- https://www.expotools.com/acatalog/AB603-Airbrush-Deal-AB603.html#SID=2 Lidl do a full size tanked compressor from time to time for around €100.00, one would need a filtration system €20.00 in Lidl (not the best unit- SIP do one for around €100.00) Lidl's one does work, it's a water filter n oiler- the oiler you don't need for painting! then the spray gun and a few connectors. These compressors are OK quality and you have the added advantage for use in other applications- pumping up her tyres! Eoin
  10. Hi all So with the Bray Fair cancelled on Sunday I had a bit of spare time- Flying Scot upper tender body time! With my plan on being able to remove the upper body I cut some waste brass sprue to make two brackets to hold it together on assembly, straps cut, scored for folding, and M2 bolt holes drilled.. All folded up and setup to mark holes in footplate Captive M2 nuts about to be soldered on, using the excellent modellers tool to hold the nuts in place- cocktail sticks! All soldered up with 180deg solder, soldered the folds also for a bit of rigidity M2 holes in footplate were countersunk for the screws After a few minor adjustments the upper body was installed and the unit was epoxied, making sure the footplate was not glued While that was setting I started on the tender main frames, these needed the rivets embossed out first, the kit has half etched marks for this This is a very handy rivet embossing tool which I made a new MDF table for, and I get to try it out for the first time here- its hard to hold a part in place with nothing to rest it or your hand on when using the punch, it works really well Nice little embossed rivits I then soldered on the frame steps, steps rivet detail, and the axle box keeper plates with 180deg solder All cleaned up and frames now ready to be fitted to the footplate Eoin
  11. Hi irishthump There are different grades of alcohol spirit, I suspect them Americans use a specific grade for mixing paint? I have a bottle of isoprop from a pharmacy that melts any soft plastic or rubber it comes in contact with, skin also!..... Eoin
  12. I have to agree there with thumper- surgical spirits is not the best for cleaning paint, paint doesn't dilute in it like it does in thinners, spirit can also melt O rings and plastics that some guns have..... Eoin
  13. Cant believe it! not a split pin suitable in the workshop. So set about making up a few out of .8mm brass wire Clamped down in the vice on a piece of hardwood and filed the wire flat on one side Then measured off 5 lengths, bent them over the PB wire steam pipe, cut them, and then pinched each with a pliers to form the eyelets Split pins With that done I started to fit the lubricators, atomizers, and pipes- this photo shows the steam pipe installed with the split pins Hand rails completed with wrap around over smoke box door rim, lubricators, atomizer and pipes installed on this side All complete and very close to start painting- small bit of straightening up and a bit of filling here n there Its great to get this job completed, I wasn't to sure how the pipes were going to work with my plan of being able to remove the boiler from the footplate for painting. It does work but some of the pipes will have to be installed after painting- otherwise it worked out Deadly! Eoin
  14. Nail on the head, John, with Noel and his 30mins Eoin
  15. Hi All With the recent discussion on the Luas and in that thread the mention of an underground railway for Dublin City- I thought of doing this thread so that some of the people interested in, or against, can view the technical and design aspects of a project like this. Some may find this very boring and not applicable to their argument, but it is real information and has to be considered in the discussion for reasons of;- cost, technical & design ability, build ability, feasibility, and the affect it would have on the City while under construction. Some of these points if not all are the reasons why an underground has been promoted in the past and then abandoned! So here we go;- This is a truncated report by the Institute of Engineers of Ireland on what's under Dublin City- some argue that its all rock but the report indicates what's actually there;- https://www.engineersireland.ie/EngineersIreland/media/SiteMedia/groups/societies/geotechnical/Soils-of-Dublin.pdf?ext=.pdf This is a lecture by Michael Löffler from CDM Smith discusses the use of underground space as a key factor for sustainable development of densely populated areas. He outlines innovative solutions to these challenges from a number of ongoing and recently completed underground rail projects;- It's interesting that the Institute hosted this lecture only last year? Please contribute to this thread with any information you think is relevant and please link to the source of the information that you add, so that we have qualified additions that can be referenced and not just notional personal thoughts- qualified information leads to good understanding of a development like this...... Eoin
  16. Hi Noel I reckon the ultrasonic cleaner has caused this problem- it is known that ultrasonic cleaners can cause metal fatigue by vibrating the crystals to the point of destruction- the glue in the metal lets the hard particles go and under pressure or working the item breaks. I would recommend keeping precision tools and metal models (especially ones that have been super-glued or epoxied) away from ultrasonics..... Eoin
  17. and For those masking problem areas use liquid masking applied with a brush into the raised area under the masking tape, let it set then tidy it up before painting- Humbrol do it or you can use the liquid masking one gets in the Art n Hobby Shop Eoin
  18. Hi Noel Use cellulose thinners to clean your spray gun, cellulose will remove all paint if you spray with it after quitting painting, use it after spraying the paint thinners to wash the gun out first, or when cleaning the gun use it and/or leave it soak in it for a few hours- spanking clean every time.... If you have paint getting into the air in area there is a problem with the gun? Eoin
  19. Thanks guys for great coments I started on the upper tender stuff on the Flying Scot, a lot of cusp removal from the brass parts and sized up everything to plan it out. The upper tender section will be removable, I reckon this is better for painting and it allows disassembly if problems occur.. it also allows the tender inside to be accessed if one wants to install anything at a later date Working out the system to assemble the tender structure without using the footplate, the plate will be fixed to the chassis detailed above, so then the plastic structure and all the bits assembled on it will be removable.... Lots of little bits required two evenings cleaning up All the set up work is now complete on the footplate parts of the loco and now getting ready to stick things on Lubricators, atomizers, and .4mm PB wire pipework setup to go on the valve chests on the footplate- a lot of little holes drilled... Valve chests ready Firebox washout plugs installed and boiler handrails test fitted and ready to be stuck on A hold up again as the parts to support the break steam pipe that runs from the smokebox back to the cab are missing- should have some split pins that should work- off to look see.... Eoin
  20. It's a transition DART- used to train the drivers while they waited for motors and other stuff to be installed Wrennie Those 'Ribbons' draped on the side- to me they look like protection coverings falling off in the wind! Eoin
  21. Great photos Wrennie People did bash the DART at first, even Mr Fitzgerald who brought it in was afraid of it's first run and stayed away, ever the opportunist Mr H (cant bring myself to say his full name...) went on the first run and stole the credit.... after it came in the bashing was in regard to, that there was not enough of them and those stupid folding seats were silly! it transformed commuting in and out of the city... the Luas is doing the same Eoin
  22. Hi Guys The Luas has been an incredible addition for the commuter, we are just fudies because we like real trains! and it's lack of good authority road management and cars that cause all the trouble...... Back in the 70's the Dublin Development Plan had the underground planned, it was indicated on the development maps including locations of stations n all- the powers that came along after decided to abandon the plan on the basis of the disruption to the city while building it!- decent tunnelling machines had not been invented then... Eoin
  23. Hi Paul Check out here;- http://www.electrarailwaygraphics.co.uk/ and keep an eye on here;- This system will allow a number of loco types to be made in RTR and in kits- still early days but plodding along I also do Gauge N 2 car DART and a Kato 103 conversion DART Eoin
  24. Hi Guys Just a reminder that the Train & Model Fair is coming up this Sunday.......
  25. Hi dave182 It's not necessary to go back to metal a light sanding with fine wet n dry fine paper or a soft fibre brush to create a key for the new paint will suffice, then a good wash and your away painting, some models have to much paint applied in the factory and with a second paint detail starts to disappear- these models need a good sand down to retain the detail- Oxford apply a lot of paint to their models.... Eoin
