Everything posted by Darius43
Running session yesterday… Cheers Darius
I was going to frame a reply using a reference to Methody, but thought better of it just in case there are some Methody alumni around… Cheers Darius
Next project… Cheers Darius
In action on the layout this morning Cheers Darius
6th and final coach completed Cheers Darius
Latest progress. No prizes for spotting the part from a old felt-tipped pen… Cheers Darius
Thanks guys - I have one more coach on the go to complete the 6-car unit. A pantograph coach. Cheers Darius
The real thing. Now a thing of the past as the DC “Local” trains are now retired. Cheers Darius
Five cars completed… …one more to go. Cheers Darius
Running session in the shed last Saturday. Cheers Darius
…and home made decals applied. Cheers Darius
Painting completed. Cheers Darius
Roof vent “Spangles” added and primer paint coat applied. Cheers Darius
I have “lost” parts that I was going to glue only to find them stuck to my jumper later on… Cheers Darius
Roof constructed using plasticard and the original Triang coach roof - with the molded on roof details removed. The edge of the roof base is superglued to a sheet of 0.5mm thick plasticard. Once this glued joint has cured, the roof is rolled round to the half way point and superglued in place, then rolled around again to glue the other side. After all the glued joints have cured the excess plasticard is trimmed away and the edges cleaned up. Cheers Darius
Started work on a composite coach this evening. Sides marked out on a sheet of plasticard. Windows cut out. Doors cut out. Representations of the sliding doors and window shutters glued to the inside face of the carriage sides. These are always open. Coach ends made using a plasticard master template. Vestibule walls made from 1mm thick plasticard. These have the curved profile of the carriage sides on one edge and will be glued in place once the carriage sides have been fixed to the chassis. Carriage sides fixed in place. Cheers Darius
Buffers and other details added to the cab end - plus bogies. Almost finished apart from the mesh grilles over the windows. Awaiting suitable mesh from the Bay of e. Cheers Darius
Decals on. Cheers Darius
Home made decals printed on clear and white decal paper. Cheers Darius
Main painting completed. The roof is just placed loosely in the photos. The original Triang coach roof is sandwiched inside and the Triang roof bolts are used to hold it down in service. Cheers Darius
Primer coat applied. Cheers Darius
Roof vents and door grab posts added. Cheers Darius
Roof on. Cheers Darius
Cab end completed. Cheers Darius
