josefstadt
Everything posted by josefstadt
  1. Advertised as 'Mint!' but one buffer missing, appears to be rust on the couplings and, as DC notes above, a fairly ropey paint job.
  2. If one of the MkIIIs has significant modifications to make it an ‘Observation Coach’, such as fitting windows in the end as per the Belmond brochure, then the coach would have to go through the approval process with the Railway Safety Commission and this can take some time.
  3. No, it will be hauled by a single 201, normally 216. The other loco will be spare, for use if 216 fails or to release it for maintenance.
  4. josefstadt
    Videos
    Amazing stuff! Double headed NIR 111s and 201s in the first video; the transition from MkIIs to De Dietrich stock on the Enterprise along with loads of freight in the second. Many thanks to Colm O'Callaghan for taking the time to go out and record these scenes for posterity and thanks to Eiretrains for placing them on Youtube. Thanks also to 201bhoy for finding the videos and posting the link here.
  5. Sign seen in Tokyo Station. I wonder if the Japanese have hit upon a new revenue stream? Could IÉ follow suit? Supplementary fare for travelling in the more sheltered pocket wagons!
  6. Best of luck on all fronts Noel. As rebelred said, I'm sure TJ2 will be even better.
  7. Note the caption which wrongly refers to 'New Dutch engine, Inchicore, Co. Dublin' instead of 'New Deutz engine ...'
  8. Cheers Anthony. Certainly looks the biz!
  9. Brilliant set of recent images Anthony! The shed area looks great. What did you use for the paving?
  10. Sounds interesting. Looking forward to hearing more about this subject.
  11. If you log into the Faller website: http://www.faller.de/App/WebObjects/XSeMIPS.woa/cms/page/pid.14.17/lg.en/Produkte.html then select 'Track Gauges', then 'HO Selection', then 'Railway Stations Railway Buildings', then 'Railway Stations' you will find what you are looking for. There are also other types of railway buildings at the last step. However most, if not all, of these buildings are based on German prototypes. These can be quite different to those found in Austria. German stations often are built of brick or stone, while Austrian stations, particularly rural ones were finished in yellow stucco plaster. There are a number of manufacturers of station buildings in Austria who specialise in producing models of Austrian prototypes or generic Austrian building types: http://www.mbc-weiss.at/ http://www.h0-gebaeude-modellbau.at/produkte/Angebot___2608 Unfortunately their products tend to be somewhat more expensive. Hope this helps.
  12. Faller also do realistic looking backscenes. I got mine through Walter Oberle (Kinvara Train) for a similarly themed layout.
  13. Yes, but you never get a day off!
  14. Have to agree with the above comments regarding the NCE Powercab. Got one at the Glasgow show and found it quite easy to set up, even for a complete novice in the world of dcc. Had been thinking of the Lenz 100 starter set, but the Powercab's cost was less than half that of the Lenz and it got a better recomendation from the staff on the Digitrains stand.
  15. Thank you very much David. As usual, a mine of useful information! And, by the way, I like the appellation ‘Young’!
  16. Interesting maps Noel. Never knew that there was a tramway depot on Victoria Quay.
  17. Fantastic, as usual, Anthony.
  18. At least you got the grass cut!!
  19. No they haven't! Marvellous performance against Scotland then an incredible French rear guard action in Twickenham. Merci beaucoup Les Bleus!!
  20. Video of a recent derailment in the Czech Republic:
  21. Ask and thou shalt receive: Lovely models Glenderg.
  22. Indeed, it would more correctly be a 'near collision'!
  23. The track is to be welded here. There are no holes for the fishplate bolts so the fishplates are temporarily clamped in place. When the time comes the fishplates and clamps will be removed and the joins in the two rails will be welded together.
  24. I sense that we will have another treat in store as Nelson brings another of his fantastic projects to fruition!
