irishthump
Although there's a minimum of cosmetic updates on this run, they are still a damn fine model! Just out of interest... what are the updates to the lighting functions? Does anyone have a photo of the loco with the body off? I'd be very interested to see the new speaker/PCB setup.
Since it's show and tell time.... I built this shed during the pandemic, 11ftx13ft if I remember correctly. The inside is like a bomb hit it right now.....
Late to the party on this... but personally I'll be giving these a miss. I own 5 of the older 141/181's already which is quite enough for my small layout. Also, no disrespect to PM and his efforts, but I don't think the minor upgrades to the model will be enough to justify me adding more of these locos to my fleet. But as always fair play to PM for doing the rerun and I've no doubt they'll sell like hot cakes.
Exactly. CIE stock was the very definition of mix'n'match!
Well said! As a kid, avidly watching the Supertrain liveried trains run by I don't remember anything but the heavily faded light-orange hue! Scale is also an overlooked factor. The correct shade will tend to look darker when it appears on a model.
I thought that myself until I read Rails through the West. There are several pictures of freshly painted/cleaned locos and that shade looks spot on.
Very tidy work!
Great stuff... Looking forward to seeing Ballyercall live and breathe again!
- 468 replies
- 3
- ballyercall
- layout
(and 1 more)
Tagged with:
How do I add a Shop (Coches De Metal)?
irishthump replied to DJ Dangerous's topic in Site News & Help
Yes, I heard of several people who were left out of pocket. One is a member here (they haven't posted in 5 years) who told me in PMs that he paid $650 to MSB for sound decoders. Got no reply for 6 months and after hounding them was finally told they were "dispatched". Needless to say they never arrived and MSB resumed radio silence. This all happened mid 2013 - 2014. A full two years before MSB folded. -
And they closed down under dodgy circumstances as well. Lot of customers were left out of pocket. -
I believe I recommended the Lokprogrammer, but just to be clear, that is for detailed CV reprogramming work such as remapping functions or loading sound files. Any good DCC system will allow you to reset a decoder without risk of mucking anything else up.
Yes you can remap the functions on any ESU Loksound decoder. However, it's best done with the Lokprogrammer. It can be done by reprogramming individual CV's but this is complex and risky. The Loksound V5 has over 2000 CVs many of which have to be accessed with indices.
I actually commented on this video at the time and asked where they got the engine sound from. Apparently they used a generic file that was closest the could get to the Crossley sound.
Best DCC Controller for a small project?
irishthump replied to Leyny's question in DCC, Electrics and Electronics
If I were you I'd be looking at either Roco or Lenz. GeorgeConna mentioned above that he has the Z21 and I've heard nothing but good things about it and you can get it for around the €200 mark. I'm looking at the Lenz 101 for my own layout in the future but that's in the €300-400 range. At the moment I use a Gaugemaster Prodigy 2 which I absolutely love, but it's getting on ow and it's very hard to source a new one from anywhere but the UK. The Lenz or Roco can be ordered from Germany and you bypass any Brexit shenanigans. -
Transitioning from DC to DCC in Simple Terms for Beginners
irishthump replied to DJ Dangerous's topic in General Chat
To be honest you won't use that many functions when running trains, ten is plenty if the main ones are assigned to F0-F10 -
Standardised DCC Decoder Function List for Irish Diesels
irishthump replied to DJ Dangerous's topic in Tips & Tricks
Yeah I standard all of my loco functions whether they be Irish, UK, US or whatever... All my sound decoders are Loksound and I have a Lokprogrammer which makes swapping functions simple. I put the most used functions on F0-F9 F0 - Marker lights (if separate to headlights) F1 - Prime Mover F2 - Horn F3 - Brake function (I only use the loco brake function) F4 - Drive Hold F5 - Load setting (simulates a heavy train) F6 - Couple/uncouple and uncoupling cycle (Kadee Shuffle) F7 - Headlight if separate F8 - Flange Squeal F9 - Rail clank Like I said I really only use these functions so the more obscure sounds are on F10 and above -
Just to complicate things.... My old man was a tailor so knows a thing or two about sewing machine oil. (I once used his machine oil on the gears of my BMX, that didn't go down well!) There are actually different kinds of oil for sewing machines. The "light oil" version which is thinner than regular oil which is used on the needle bar and the bobbin spindles and a "stickier" oil used on the larger gears inside the casing which is like a very thin grease. Anyway, just some trivia for you... Oh, and don't get me started on WD40. The most misunderstood product in the world! It shouldn't be anywhere near a model railway
Nice job. Very tidy!
I run a DCC layout but my points are still powered 24v AC supply through a CDU. I prefer to keep the train control and point control seperate.
You can get that effect by either using the brake or Drive Hold feature.
My ears are burning...... It sounds like something in the PCB has gone kaput. The fact that you can't get the decoder to make contact with your controller would support that. If it was the motor you would still be able to communicate with the decoder be able to turn the lights on and off. You can doublecheck the motor is ok by removing the shell and applying current directly to the motor contacts, if you can get at them. Long time since I took the shell off a 121 so I can't really remember the layout. Yeah I'd strongly advise to not use the "DC option" that some DCC controllers have. It works by "stretching" the AC waveform of the DCC signal so it is not true DCC. It can fry motors very, very quickly. Older motors like the Lima and Hornby pancake and ringfield motors can go bang in the blink of an eye. Some modern motors can also be susceptible to damgage.
Yeah I use XPS all the time now. It's insulation foam, either the blue or pink kind, NOT the yellow kind from builder's merchants. It's easy to carve and not as messy as clay or plaster. Here's one of the last things I built on the layout.... https://irishrailwaymodeller.com/topic/71-grahams-workbench/?do=findComment&comment=163727
Did you buy the culvert or make it yourself? Just scrolled up and Just saw you made them from clay. Have you tried using XPS foam instead?
