Mayner
Everything posted by Mayner
  1. Explored Penmachno Quarry once and sometimes used the road over the Denbigh Moors and through the Penmachno Valley as a 'short cut" driving from Scotland to Portmadoc. Model seems to follow the route of the NWNG Bedgellert-Betwys-Corwen scheme hopefully someone will bring out a rtr model of NWNGR single Fairlies Snowdon Ranger or Moel Tryfn Funnily enough I was thinking of a similar WHR minimum space layout with Bachmann Baldwin, Kato England loco and Quarry Hunslet based on an junction at Nant Gwynant between the General Undertaking and a line from the South Snowdon Quarry but I already have more than enough on my hands
  2. I love your nicely organised workbench, tools and fixtures, mine looks more like a scrapyard! Nice work with the piercing saw.
  3. Harcourt Street would be extremely ambitious for a first layout particularly if your planning to scratchbuild a model of the station building which would be a major project in itself. Its probably best to consider what aspects of model railway do you enjoy the most before deciding on the type of layout and space available. Harcourt St, Milltown Viaduct and Dundrum Station would take a lot of space, time and effort to build in OO, but would fit in half-three quarters the space in N. The station while relatively compact in length (excluding the fitting between Albert Place and Hatch Street, the was almost as wide with the carriage sidings/goods yard fanning out half the distance between Harcourt Street and Earlsfort Terrace. The late Desmond Coakham published an excellent article in the Harcourt St line in CIE days which includes photos and trackplan of Harcourt St. Railway Byelines Annual No5 published Irwell Press 2002 who may be able to help.
  4. I remember a priest working himself into a lather during a sermon (the late 60s) about how the World was coming to an end, after seeing a young couple and not being able to recognise the difference between the sexes because they were both wearing long hair and denim jeans. I was only a kid at the time, but it of those lightbulb moments about not believing everything your told by people in authority
  5. Many years ago a model railway club member remarked that the only thing missing was a Kango Hammer as the O Gauge group carried out track laying on a new layout. The group went about their tracklaying with as much finesse as a full scale track gang using a full size hacksaw and 20oz hammer to lay and pin down Peco Flexi-track. The larger the scale the closer you get to the real thing I use a graphic paste for lubricating the rail joints on the Garden Railway though its supplied in a small tube by LGB rather than a 5 or 10 Gal drum by RS Clare https://www.rsclare.com/wp-content/uploads/2020/09/RS-Clare-Rail-Brochure.pdf
  6. I am not sure if TPOs ran on the WLWR line, at the time the daily Limerick-Sligo train was usually operated as an AEC railcar set, the Limerick-Galway train was a loco hauled (A Class) Mail based in Limerick possibly with a TPO. The late 50s built Bogie and 4W TPOs may have struggled to provide cover for all mail trains before the line closures of the 1960s Possibly a cripple shunted out of a train (especially with the net) en-route from Limerick Works to Sligo or Athenry, ex MGWR TPOs appear to have been in use on the Midland until the (very) early 60s.
  7. Stewart Hine wrote about "route feeding of track power" as "Linked Section Control" in Model Railways Magazine during the 1970s, I had tried variants of the system using relays and manual switches on a number of layouts down the years. I am not convinced that the accessory switch on the Seep PM 1 would be reliable enough to operate the relay. I use a similar "route-feeding" arrangement using "Blue Point" manual point controllers https://ppw-aline.com/collections/blue-point-manual-turnout-controller using push rod control, on a small end to end layout eliminating the need for section switches or a control panel. The "Blue Point" has a built in DPDT switch, I use one pole for section control using common return wiring, the second to change frog polarity with live frog points, the power is routed "backwards" through some of the points which are controlled using manual push rods (bicycle spokes) I use hand held controllers (1 Gaugemaster, 1 custom made) which plug in to DIN sockets on the layout fascia 1 socket for main and 1 socket for yard working. I will probably use a similar system using the accessary switch on Tortoise point motors http://www.circuitron.com/index_files/tortoise.htm for power routing if I get round to building a new layout.
  8. There is a photo of a Macroom 4w 5 Compt. coach coupled to a Macroom 6W 5 Compt coach in "Irish Standard Gauge Railways Tom Middlemass 1981. Curiously the 4 wheeler appears to have been fitted with gas lighting at some stage (by the GSR or GSWR?) while the 6 wheeler retains oil lighting. The panelling detail above the windows on both the W&CIR and Macroom coaches appears similar possibly with Metropolitan supplying coaches to both the W&CIR and CMDR
  9. My impression of a W & C I Rly five compartment Third Class Carriage based on the Metropolitan drawing of the 1879 Second. Apart from the harder seats ,Third Class passengers would have had less legroom than those that could afford a First or Second Class ticket with an internal compartment width of 4'10" and poorer lighting with 4 compartments sharing two Oil Lamps. In GSR days the Macroom had a 5 compt. 3rd with a similar lighting arrangement though with gas rather that oil! I will place higher-resolution copies of these drawings in the resource section.
  10. Although mainly interested in the Midland I bought a copy of a GA drawing of a WCIR 4w "Second Class Carriage" to get a better understanding of the type of 4 wheel carriages bought by Irish companies during the 70-80s. There is also a more modern WDLR 4w brake in the catalogue which is probably next on the list. I decided to "colour-in" the drawing to give an impression of the WCIR 'lake livery' and provide some contrast between the paneled areas and mouldings, I tried to re-produce the graphics in a similar style to the 1879 original The coach had an overall body length of 25' on a wheelbase of 14' a similar length to the WDLR Brake and 4 compartment 4w coaches built by the GWR in the early 1900s. The most interesting thing about the coach is the absence of brakes! the coach was introduced long before power braking and block working became compulsory. . The coach is listed on the drawing as 799 (a worker or order number) no other order numbers are listed on the drawing, its difficult to establish at this stage whether the coach was a one off or part of a larger order. I suppose the next job is to re-draw the coach a 5 Compartment third.! The panelling style on the ends is not dissimilar to the 4W van coupled behind No 12
  11. Most likely an Up Meath Road Goods hauled by a Cattle Engine. There were three return goods trains between North Wall and Kingscourt weekly during the 1950s most likely departing Dublin on M,W, F returning T,Th and Sat with the loco shedded over night in Kingscourt. Traffic to Dublin appears to have been mainly bricks from Kingscourt and general goods traffic from Navan with light traffic from intermediate stations. There is a photo of a Cattle Engine on an up-goods passing Gibbstown during the same era in a "Decade of Steam" the train consist (not very long) was mainly open wagons and a couple of vans.
  12. Quite a treasure throve, especially the loco drawings and makers photos.
  13. The politics behind extending the Dublin and Meath to Armagh and further north are fairly complicated. There were completing proposals for inland (via Navan and Armagh) and coastal routes between Dublin and to link up with the Ulster Railway at Portadown during the "Railway Mania" era of the 1840s. Later post "Railway Mania" era schemes included plans to extend the Navan-Kingscourt line beyond Armagh to connect with the Belfast and Northern Counites at Cookstown. A line to Cookstown would have allowed the MGWR to tap into brick and coal traffic from the Tyrone coal field and tourist traffic to an from Portrush over the Derry Central between Macfin-and Magherafelt. The D&M/N&K plans for a Kingscourt-Castleblaney-Armagh line appear to have been serious enough to locate Kingscourt Station at the bottom of a hill at distance from the town laid out as a through station. The N&K basically appears to have run-out of money when they reached Kingscourt and the MGWR was highly unlikely to subscribe capital to building branch lines preferring the locally owned companies or the Government take the risk. The GNR would not have wanted a MGWR line entering its territory and blocked a Kingscourt-Castleblaney line by building the Carrickmacross Branch. if you have access to the IRRS library GR Mahon wrote an excellent series of Journal Papers on Irish Railways during the 1860s-1870s during the 1970s including the Dublin & Meath and Navan & Kingscourt and proposals for extending to Armagh and further north.
  14. I haven't tried static grass, I still use Woodland Scenics medium and coarse turf scatter on pva glue on plaster bandage, with rubberised horsehair and Woodland Scenics foliage for hedge and bushes. Not looking bad after 10 years dust fall out! Used 'Fine Turf" scatter for the roadway on the Roadside section medium and coarse turf for grass/ground cover. This scene was inspired by a section of line where the road & tramway ran parallel with a canalised river. Again not looking bad after 10 years
  15. Without going into too much detail its unlikely that shifting production and distribution to Ireland or the UK would lead to a reduction in the price paid by customers for our 3D printed wagons. Basically its cheaper to print our wagons in New Zealand and Asia than in Europe. Higher printing costs are likely to cancel out any savings on shipping if I moved manufacture and distribution to Ireland or the UK. The bottom line is that 3D printing is only really suitable for prototyping (one offs) or low volume production which comes with a higher price tag than a similar mass produced item.
  16. The semi-circular pipework at the front of the smokebox was a distinctive feature on Atock locos until re-built re-boilered from the early 1900s onwards. The pipework disappeared from the E Class and conventional smokebox doors were fitted when the locos were re-boilered from 1912 onwards. 556 is basically in MGWR condition with the exception of the GSR number plate and loss of its MGWR name and number. I think the pipe and flexible hose may have been for powering water pumps and other accessories rather than steam heating purposes
  17. I went down the direct sales Shopify route because sales and distribution through IRM and retailers like Marks, Rails and Hattons would have resulted in a significant increase in the price point of our models even before UK or Irish vat was added, which would not have excatly helped sales. The underlying problem is the relatively low level of demand for Irish pre-Liner Train era wagons and the fact that a kit or 3D printed model cannot compete on price point with a mass-produced plastic injection molded Far-Eastern models. Initial feed back when we sent samples to model railway clubs in Dublin was that people 'could not see the point" of paying a higher price point for an accurate model of an Irish wagon than they could buy a rtr model of a similar British Rail wagon at a lower price.
  18. I designed the MGWR 2-4-0 kit with a single piece fold up chassis for OO that could be assembled in 21mm gauge as a conventional chassis with separate frame spacer. I designed the GSWR 52 Class with a conventional chassis with OO & 21mm frame spacers. The majority of my customers are experienced kit or scratchbuilders or people who want a model of a particular loco regardless of the chassis design. Interestingly I sold more MGWR 2-4-0s than GSWR 4-4-0s most likely because I produced 3 variations of the 2-4-0 kit and only 1 variation of the 4-4-0 rather than the fold up OO chassis.
  19. Interestingly Tarmac UK cement/building product traffic of 9M tons annually is roughly 3 times heavier than CIEs total annual railfreight traffic during the 1970/80! https://www.globalcement.com/news/item/11387-tarmac-renews-rail-freight-contracts-in-uk Ironically railborne cement traffic was in decline in the UK and increasing in the UK during the late 1980s-mid 1990s with the situation reversing following privatisation in the UK. The UK freight flows tend to be heavier and over longer distances than in Ireland which gives rail a competitive edge over road leading to investment in modern high capacity wagons by rolling stock leasing companies, subsidised freight access charges after privatisation has lead to four 'open access' operators competing to haul bulk cement and building traffic. Difficult to see a similar situation developing in Ireland because of the relatively short distance between the major Cities and the Cement Plants and IRH loss of market share to Quinn, Lagan north of a line drawn from Wicklow to the Ox Mountains.
  20. CIE tended to "re-purpose" existing steam sheds for diesel traction rather than building purpose built 60s era Motive Power Depots. Galway & Westport are examples of steam shed retained for diesel traction into the 1980/90 Westport Shed. The photos were taken approx. 10 years apart and shed out of use in upper photo, the turntable was out of use at the time. Galway and Westport re-fueling points mid-90s Galway recently updated with a bunded tank and concrete re-fueling pad, possibly replacing fuel tanks installed for oil burning locos winter of 1947 Tank wagon is on the stub of the Clifden branch, loco depot trackage and turntable still in use at the time. Later that evening IE staffed re-fueled 201 Class locos rostered to work the Galway-Athlone Liner and morning Galway-Heuston passenger. The fueling point at Westport was originally the running line to Westport Quay. Stabling-refueling points. There were also a number of stabling-refueling points without a loco shed, simply one or two tracks, a refueling point, single storey office/signing on point and mess room. Claremorris. Downside Westport end of the station two sidings retained for refueling locos on Knock specials, Liners and Ballina Shuttle. Waterford: Originally Platforms 1-2 (New Ross Bays) and later sidings in former loco depot area of freight yard. Loughrea Branch Tank wagon re-purposed from 1947 loco oil bunker/West Clare fuel tank/Loughrea tank wagon. In short a 1960s CIE diesel loco depot can vary from a tank wagon or refueling point on a simple siding to a former steam shed.
  21. Mill basic assembly painted and windows/doors fitted. Paint colour match-pots from a paint shop finding a near match for aged concrete from a "whites & neutrals" selection, pots worked out at roughly €1.80 each. Main quibble is the visible grain in the ply but not really noticeable from normal viewing distance. Quayside I need to square up and fix the roof to the elevator section Rail Side the two large openings at 1st floor level were covered loading chutes for loading mill-products directly into Soft Topped convertible wagons, I will need to build a loading platform for loading hard topped (H) Vans which had a higher flatter roof profile. Closer view of the windows, I will need to sand down/touch up blemishes in the paintwork, but is a reasonable match for aged concrete
  22. Drogheda-Navan was always single with the exception of crossing loops and sidings at Drogheda Platin, Duleek, Beaupark and Navan. As far as I remember the cutting between Drogheda and Platin was only wide enough for a single track https://www.geograph.ie/photo/3348749
  23. Carrignagat was the end of the double line section from Sligo until moved to Ballysodare in 1930. Apparently the original cabin was destroyed during the Civil War and replaced by a temporary ground frame until 1930 when the Junction was moved to Ballysodare. Ballysodare Cabin was a GSR replacement which controlled the junction with the SLNCR and the remotely controlled junction with the Burma Road at Collonney Junction.
  24. I think Portadown-Armagh was double tracked Armagh-Monaghan always single Monaghan-Clones double possibly singled as an economy measure 1930s. Belfast-Cavan appears to have been considered an important route up to closure, with a relatively frequent (by Irish standards) of direct passenger trains using modern steam hauled coaching stock.
  25. The Waterford and Limerick Waterford West-Fiddown was formerly double track. A section of the Down? main line at Grange was retained as a siding to serve a high loading bank after the main line was singled during the 1930s. Limerick Junction-Limerick double track in WLWR days. Dublin-Waterford Sections of double track retained as sidings. Clonsilla Junction-Galway. Sections of redundant double track were retained as lay-bye's or refuge sidings at the majority of crossing stations on singled sections of the main line. The lay-byes/refuge sidings were used for shunting complete trains clear of the main line when the running line and loop were both occupied. The lay-bye sidings at the east and west end of Maynooth were used for shunting Liner and ESSO Oil trains clear of the main line when up and down passenger trains were crossing up to the early 2000s. A section of the Up main line at the Dublin end of Drumree on the Meath Line was retained as a siding to serve a (new) goods shed after the line was singled by the GSR. Cherryville Junction-Kilkenny. Kilberry: A section of the former Down main line was retained as a siding to serve the Kilberry Moss Peat factory until disconnected in 1975. Carlow: A 3/4 mile section of the former Up main line was retained to serve the Carlow Beet Factory opened in 1926, rail borne beet traffic appears to have ceased during the late 60s/early 70s though the factory dispatched train loads of export sugar in ISO containers during the early 1970s. Bridges and Structures Bridges and Structures on main lines built during the 19th Century were were normally designed or built and enough land taken to accommodate double track at a later date, one of the main exceptions was Killarney Junction to Killarney, though the Killarney-Tralee section were built to accommodate double track.
