BSGSV
Everything posted by BSGSV
On the MGWR, Collooney MGW station to Sligo was double-tracked, except for a short stretch from Collooney Junction to Carrignagat Junction. On the GNRI, Portadown - Trew & Moy was double, the section from there to Dungannon had a tunnel, so stayed single, so far as I know. Dungannon to Donaghmore also got doubled I think. Newry North to King Street was also double.
Do you know if this a bad sign for the coach or is this just the normal state?
BSGSV replied to Glenderg's topic in Photos & Videos of the Prototype
The point rodding run doesn't seem to correspond with Athlone East. It does look like the west end of the layout at Mullingar West, see this photo only you're facing the other way: https://www.facebook.com/photo/?fbid=1405587800190989&set=gm.2486712704815406&idorvanity=171953576291342 -
which coaches in intercity service Corg-Dublin in June 1990
BSGSV replied to MAL's question in Questions & Answers
The Mk.2d was vacuum braked, and the Galway trains had a vacuum braked TPO included for mails. The other Mk.2 stock was air braked, as well as having windows with ventilators, and wasn't in service in 1990, only appearing later. The Up train from Galway might have had problems, and not arrived in time to form the down Cork service, so a scratch set may have been sent instead, formed of whatever was to hand that wouldn't mess up the following day's diagrams. -
From the sounds of the above, unless you were on the 05:20 Cork-Heuston (which does not seem likely for someone on honeymoon), then Cork to Dublin should have been Mk3's. The Dublin-Cork train at 20:40 or so, should have had the Mk.2's which came up from Cork at 05:20 (and went to Galway and back during the middle of the day). It does sound like something was wrong if you had Cravens, which would be the bet for a backup, and the only carriages with the windows you describe allowed down the Dublin to Cork mainline in 1990. -
Removed -
Sorry to be a pain, but the Alphagraphix's kit is for the type of cabin put up by the GNRI in the 1890's, 1900's. The cabin design changed in the early 1910's to a new, (similar) design. Dublin Amien's St. was built in c1923 to replace Dublin Central , which was destroyed in the Civil War, to the later design. The interior photo was taken in 1959, and shows a lot of empty space at the far end of the operating room. Originally the locking frame was much longer, as the cabin also controlled the GSR lines, from the GSR Loop line platforms, towards North Strand Junction. However, when the GSR took over control themselves (on West Road opening), the GNRI frame was shortened.
At the time Cyril Fry got those, 1442 would have been without the heaters, as they only came in the 1970's. 2651 is an AEC Railcar, one of the last of the "main line" ones.
1968 is about when the Free School Transport scheme came in. CIE did not get much (if any) warning, and were left scrambling to get vehicles together to meet the demand. This included both postponing withdrawals and buying some secondhand/withdrawn half-cab single decks from the UTA, to tide them over until the Bedford SS class could be produced. Perhaps the buses in the background are some of those? -
I think they are electric wires going to the signal lamps, instead of having oil. That looks like B234 in the background. If so, it's late-60's rather than early? -
A lot of country lads at Dublin sheds too! Others have commented on the traversing jacks, but the fishplates look like items designed for the spiked track in the photo. There's no soleplates, just the track flange spiked to the sleeper. The fishplates appear to have a dual function in bolting the two rails together, and having a hole, either end, to either bolt or spike down the track on to the sleeper, just at the joint where a bit more support would be useful.
The City Basin site seems to have an army of builders at it currently. I do hope they don't destroy the lovely warehouses. -
CAWS was not fitted coincidentally with the original Mainline CTC section. It only started appearing with the DART resignalling on the Dublin Suburban. The diesel locos used the track codes for CAWS, the DART units for ATP. CAWS was retrofitted to the Mainline CTC in the early 1980's. So no locos with "S" in 1975!
I don't see any "Limit of Shunt" boards on the diagram (to stop moves in the wrong direction proceeding too far), but then, there's no Facing Point Locks shown either. So I would say that, judging by the closeness of the two crossovers on the branch (to main line and run-round), there looks like there may have been one FPL locking both facing points, but there might have been one for each, if they were too far from each other. The discs on the main line crossovers and down refuge crossover would probably have only shown green with the crossover reversed. The discs either end of the crossover from Up Main to Branch probably/possibly showed green for either lie of the crossover - from Up Main platform either along the Up Main to the northern main line crossover, or onto the branch. From the branch either into the Branch platform or out to the Up Main. The disc on the branch run-round would be green for moves onto the branch proper, but yellow normal, as trains could shunt along the run-round without fouling other lines. If starting from scratch more "properly", a single semaphore would cater for moves from the Up Main platform to the branch and a bracket would only be needed if you also intended to start passenger trains from the Up Main platform to the Down Main, in which case the northern mains crossover would need an FPL at the station end, the far end being trailing. Sorry if it's a bit complicated sounding, I only hope I've got my ducks in a row in the first place! I haven't seen a signal cabin diagram which would explain much.
May be a shunt, but still a train carrying passengers. If there's no facing point lock, then the turnout should be clipped. Starting a passenger train should also be by a running signal.
I take it you mean when heading towards Banbridge, they went to the Down platform first? Could be, although as the station building was on the Up side, it could be they used the south crossover first, then stopped at the Up platform, then used the crossover to access the branch. The GNRI seem to have held a mid-19th century view that the driver should be able to stop short of any obstruction for a long time longer than they should have. There were failures to put alterations up for inspection as they should have, and running passenger trains across turnouts with facing point locks doesn't seem to have bothered them either (think Mountpleasant), just to mention two items. So I should have said that the absence of appropriate signals does not mean things did not happen!
Aside from the flash, there is also a small headboard fitted I think, which would indicate the loco had been used on the "Radio Train".
I'm not sure about the wagon, but there is a section of trackbed still looking like that, with the sloped stone facing, not long after leaving Moyasta heading for Kilrush. -
Lower black band on rebuilt Dutch vans
BSGSV replied to murphaph's topic in Photos & Videos of the Prototype
I would suspect the yellow background stuff is an inspection date - C exam, Week 29, 1998 in your sheet (or whenever). The small white lettering is about where the filler is on the fuel tank, so possibly says "Fuel". -
I don't know, but the silver pole on the left is distinctive. -
Cabin view blocked by water tank sounds like Boyle!
Lovely job this. Re signalling, the layout is similar to Loughrea or Ballinrobe minus one siding. The 1890 practice for those had a working distant (a practice later abandoned), home and starter (the latter on the platform before the fouling point with the loop crossover) and one lever operating the crossover near the tunnel to the loop, the facing point lock and a point detector on the turnout from the loop. A five-lever frame (four working one spare) would easily fit into the type of Railway Signal Co. (the usual MGWR contractors) cabin used at Ballinrobe. Such a cabin might be only 10' wide and 7' long, the dimensions of the 1918 cabin at Loughrea, would be spot on apart from the concrete blocks. Such a building might fit between the water tank and tunnel?
The remaining insulator is damaged, which is perhaps why it remains. The spindles are galvanised, so still fairly rust-free, as is the clamp for the stay wire, although the stay wire itself does not look so good.
That looks like an old-fashioned junction signal. Instead of a bracket, the arms are stacked on the one post. Normally the convention is arms top-to-bottom reads to lines/tracks left-to-right. But, as you say, only one lamp.
