I join in your commemoration!
Exclusive! IRM tell me that the grasshoppers on sale from Tuesday next. DCC extra, with working chirp recordings. Livery options: green (as shown), browny-grey Northern European version, or Norwegian blue. Preorders now - €27 without DCC, €87.50 with DCC, and VAT and Brexitcustoms fees combined with postal charges €248.64.
The "Eyre Lee Bird" railtour Cork-Galway-Return 5th April 2025
jhb171achill replied to Niles's topic in What's On?
Correct - some RPSI and later IRRS tours (eg Youghal) did cover the area and did indeed have trips to Cobh, but no RPSI May Tour ever actually started from Cork. -
Weren't there two of those coaches? Where are they now?
On Thursdays there’s a connection off the morning Tralee to Castletown West train, operating locally as a mixed. Here, it approaches Dugort Harbour in summer 1967……
Excellent. That's a copy I don't have.
CIE locomotive livery variations 1960-1990
jhb171achill replied to jhb171achill's question in Questions & Answers
It’s not black, as such; that much looks clear. If not black, it has to be green, as it’s obviously not silver either. I have seen a picture of (either) an A or C so utterly filthy that you couldn’t make out the white bit at the top at all, but if this engine was (a) black, and (b) as exceptionally dirty as that, you wouldn’t be able to see such a clean number on the front. So we can rule that out. A very small number of A & C classes were painted in the older dark green around 1960-2. While obsolete on diesel locos and passenger stock since 1955, it was still used on buses and lorries. i think there were two or three “A”s and at least one “C” (231). Some had lining, some not, same as the normal lighter green. There appears to be no rhyme nor reason behind this variation, same as dayglo patches on the fronts of 071s & 141s etc in the 1990s. As for numerals on the side, and the metal snails that “A”’s generally had, these simply haven’t been added. The loco could be the normal lighter green - variations in lighting on the day and the type of film can make blues and greens appear lighter or darker. I’m inclined to suspect this might be the case, however it’s equally possible it’s the darker “bus” green. Cork and Limerick painted a number of secondary-use coaches in the plain darker green in late days. Finally, re the snail. This lasted about a year after the black & tan livery came in. Same on the road - first repaints of buses into either red and cream or navy and cream have snails. But no railway vehicle ever carried it in even the earliest BnT times. The BnT livery on the railway first appeared in 1962, but was very rare until well into 1863. The “roundel” first appeared in 1963. -
Making an ‘E’ – the Maybach Diesel Model Assembly thread
jhb171achill replied to Mol_PMB's topic in Irish Models
That's the normal green. Some green locos had lining and some didn't; the missing number on the side could be just - missing - or it could have worn off. As BSGSV says, the makers plate is visible. They all still had them then as far as I remember. And a string of all-grey bubbles behind it; the epitome of the "grey'n'green" era! -
The shapes certainly look spot on. Colour-wise, I think the middle is probably best. -
Exactly; which mitigates heavily against anything but a handful being green, or for anything but a very short period.
Same manufacturer, and according to same colour codes. They often look darker - probably due to different materials used? -
On a point raised earlier, were all 100 in that batch outshopped in green. The answer is no; eye witnesses at the time suggest as few as half a dozen were. I’ve looked into this in detail myself over the years to such extent as I can, but no definitive answer to the question of the actual number is forthcoming. Had even, say, 20 or 30 appeared in green, they’d have been commonly seen about the place for years, but they weren’t. Any built new after mid to late 1962 are almost certain to have been grey from the start, and it seems clear that those which DID wear green, did not do so for long. As as child, personally I never saw one, despite numerous visits to Inchicore, Amiens St, and Westland Row, and occasional forays around Kingsbridge.
I probably have - I’ll check. However, while I’ve a full set of GSR / CIE 1926 to the 1970s, and a few outside that, my GNR stuff has many gaps. I’ll check and report back.
That certainly looks right, based on an original "snail" I'm looking at right now.... -
Top left there is closest. RAL is 130 70 40. -
It was the standard “eau-de-nil” - the numbers were transfers. Note to the general community; anyone with a silverfox model of a silver prototype will probably have black lettering on it, and possibly black roofs too. This, like many livery details on silverfox’s Irish models, is entirely incorrect. -
Worth noting that nothing that was silver - be it a locomotive, TPO, coach or tin van, ever carried a "flying snail" - they were plain. No lining either. With one exception: the "A" class diesels had a painted METAL "snail" attached to the sides. -
Unfortunately I've nothing that recent!!
E's are not generally associated with Cork - either type of them. I saw E425 in Limerick once, I think about 1975. As for the E401s, there WERE more sightings of them than one might think down in Cork, both at Glanmire Road and Albert Quay. Something in the back of what little grey matter I have left suggests E's making various forays down the DSER at one stage, probably to Shelton Abbey - where even a G was to be seen for a short time. -
Railway goods yard cranes - what colour would these have been?
jhb171achill replied to Wexford70's topic in General Chat
Mostly red oxide (red lead), black or grey. It is possible that some had them in their “house” colours - few details of which have survived from that period. The GNR at one time had varying shades of brown, while IF the MGWR painted such things, it would have been bright red.- 1 reply
- 3
Worsley Works Cork Blackrock & Passage tanks
jhb171achill replied to Pete00018's topic in Irish Models
Senior said he timed just under 30 mph once with a class five with three or four carriages behind it, going downhill over Barnesmore. But the coach was jolting and crashing over the joints and swaying like a cork in a rough sea…. -
Virtually every single announcement made in recent years has either not been delivered, delivered way later than suggested, or delivered in a different way; or still in planning, but with variations from the original. The debate over what will replace the 26 class in Cork, and when, and as a result of what precise movements in the Dublin or Limerick areas, has had more variations than I've had hot dinners. An announcement that Youghal will receive J15s and 6-wheel coaches again, and Limerick - Galway a couple of D17s would barely surprise me now; though to such extent as it might be a surprise, it would be a most pleasant one!
I’ve a log of one heading through Omagh at 87.26 mph….
