Paddy Mac Namara
Everything posted by Paddy Mac Namara
  1. sorry.....i meant track plan....that we could see...
  2. like it, is that modelling clay?
  3. like it pat, you sure made a lot of buildings, with card i presume? great work and looks like you have a nice bit of space, have you a track that we could see? cheers paddy mac
  4. thanks for likes guys. must do better quality photos next time
  5. Some progress on scenic work at station throat, still a lot more detail to add.
  6. As promised some detail on the circuit used in the most recent video on “Celbridge” As before my test track is not actually an X crossing but the two parallel tracks simulate what I want to do. Track 1 is the main-line thru the junction and the reed switches are here. Track 2 is the “suburban” line and is required to wait for the main-line to pass thru the X crossing, this track is isolated either side of the X crossing. R1 is the reed switch that detects the loco as it approaches the “X crossing” R2 is the reed switch as it leaves the “X crossing” junction. The isolated section on track 2 (the one I want to shut down) is connected to the relay thru the common (cm) and normally closed (nc) pins. So the isolated section is live at the beginning of the sequence. When R1 is activated by magnet on loco it closes and delivers power to coil 1 on the relay, this causes relay to open the cm/nc circuit and so power is cut off to the isolated section on track 2. Because this is a latching relay we only need one pulse to coil 1 and the cm/nc remains open. (it doesn’t matter that R1 opens again once the loco moves away, once “latched” it stays latched). Coil 2 un-latches the relay. So once the loco passes over R2 it activates coil 2 which unlatches the relay so the cm/nc circuit reverts to it original state and power is returned to isolated section on track 2. As noted before this is a WIP and a learning curve, I am working on solutions to problems such as what if the loco on the suburban line is in the middle of X crossing as loco on mainline approaches….watch this space.
  7. thanks, was on the site couldn't get info on what size the OO gauge magnet is?
  8. What happens.....crash bang multiple casualties... Its still very much a work in progress, and learning what sensors work best and easiest. So when i actually use it on the layout i'll probably have another reed switch on the junction, and if junction is occupied i'll cut power to mainline, will probably need to get into some Arduino work then, unless i can get away with just using some kind of logic circuit.....so more research to do
  9. thanks, been a bit of trial and error with magnets, got 8mm dia ones and they were too small, the one in the photo is 25mm and 3 mm thick and it fouls on the track with my 141's....d'oh 16 mm gauge. I want to get one small enough, but strong enough as i may locate reed switches beside track not under it. cheers paddy mac
  10. The next chapter in my efforts to control trains thru the diamond crossing. This is a photo of actual X crossing on the layout. The green loco is on the mainline which has priority, the red loco is on the commuter line, I want to cut power to this line when the mainline is coming thru. I’ve made up a test twin track board to…. well test it. This time I’m using reed switches to detect position of the train, switches are activated by magnet attached to the loco, see photo. And the control is via a “Latching” relay. Main improvements over last attempt is the simplicity of the system with reed switches as opposed to the light sensors, as discussed before. Also my “discovery” of the latching relay means once the train is detected it stays detected, until the next reed switch is activated. Photos and video below. I’ll give more detail and a circuit diagram over on the Electronics forum. And the video
  11. Great memories, thanks for sharing. I must have got my first hornby "train set" when i was around 12, 1977. basic oval 040 loco wagons and a point. As some of you know “good toys” anything electrical was very expensive back then, so it was a great treat to get one I lived in Tipperary, so no handy trip into marks models, I used to buy track, directly from Hornby by post paid for with postal orders. And then the seemingly long wait to get the part…very exciting. Anyway had enough room, just about to set up an 8 x 4 in the bedroom, but it was a put up and take down job. By the time I was 16 I had a double oval with two locos (I am not a huge collector of locos, I have about 14 collected over almost 20 years, my 12 year old self would be thrilled). Station sidings and other buildings. The baseboard was painted green, that was it, not really modelling…but still. We moved home so I had to sell it on…..i think I got an OK price for it all things considered. Then the wife bought me a Flying Scotsman set in 1999….the rest is history
  12. David, many thanks for such a detailed response. Plenty of food for thought......i get it tho', you can't retrospectively add depth you have to plan in advance, i hope to try it out on my "corners" later in the layout. cheers and many thanks.
  13. doesn't look too temporary to me, looks like you have a nice little den for yourself
  14. Hi Dave Sometimes you’re browsing thru the forum you come across something you haven’t seen before…properly. I’m working on my own backscene at the moment, I like the way you have the painted street going behind “cullens tea rooms” gives great impression of depth, also the street continues (tapers) into the backscene at the end, I’m really not sure where it finishes….great work. I can see it and kind-off know how you did it, but have never tried something like that before. So any tips on technique. Also if you see my recent posts on Celbridge I have footbridge going into backscene, have you any suggestions to give that some more depth. My artistic skills would not be great but my daughter has a good eye. Cheers Paddy mac.
  15. Progress on the backscene in the station area. some heavy card about 2mm thick painted neutral grey. and then added some very low relief buildings made up from card kit downloads.
  16. love the layout, whats the overall size, you certainly seem to be fitting plenty in there, like to the use of Y junctions so you can change trains
  17. thanks for the likes guys, been away from the forum for a while, so this feature is new to me, must find out how to use it
  18. Some progress. Platforms
  19. Thanks for comments guys. I think my favourite is 2nd layout, goods yard terminus with loop under the "mountain". Kinda sorry now i dismantled it.
  20. welcome Thomas,looking good so far. cheers paddy mac p.s. you might not realise it but we love a new layout on the forum.
  21. and last one kids layout
  22. I hope this might of interest to new and old modellers alike to show how the “addiction”…oops sorry… hobby progresses. Below are photos of my old layouts.(I remembered I had them on photobucket) some of them featured on the old forum. I suppose as for most of us my first layout started with a Hornby starter set when I was around twelve (cue barrys tea ad). By the time I was 16, it had progressed to a double track layout (I think) on an 8 x 4 chipboard in my bedroom, I had some station buildings and a couple of locos. I remember I used to buy track directly from Hornby with postal orders…..aah remember the days before ebay. Anyway it wasn’t girls or cars that distracted me from the hobby but we moved house, and there wasn’t enough room for it, I managed to sell the layout to a rather unpleasant man. So fast forward to 1999 and my wife (oh how naive of her) bought me a flying scotsmans set. Set it up and played with it a bit…but had no permanent space for it (the ankle biters had arrived). Until 2004 when I got my shed/office in the garden. So 1st layout was around 2006, 2nd 2007 around this time the kids were getting curious so I built them (me) a layout to keep them away from mine. 3rd layout around started around 2008 and completed 2010. Now in 2010 I started playing golf, which in itself does not interfere with modelling time as I usually prefer to model during the winter evenings, but it does distract one and can be and is very time consuming (wasting?)….so in 2014 I was able to start the process of devoting the entire office space to a layout… just took a bit of time dismantling the old layout and sorting things out before I could start on the new one and that’s where I am now…. 1st layout 2nd layout 3rd layout
  23. hi rich, love the layout, where did you get the class C C229 loco. BTW i think the double curve in the corner looks fine. cheers paddy mac..
  24. Its like losing an old friend....but also exciting if you are starting a new layout...i'm on my 5th layout
