Interesting Early Irish Railway photos
5 minutes ago, Mol_PMB said:
Locos might be a 101 piloting a 321 class? Just a guess - happy to be corrected.
Almost looks like an ex WLWR 2-4-0 as pilot
On 12/12/2025 at 3:32 PM, Killian Keane said:
Railmotor no.92, location unknown
Kingsbridge? 92 spent a large part of its life as the Inchicore "taxi", I believe.
On 5/11/2025 at 3:34 PM, Westcorkrailway said:
Not going to unload the entire Colm creedon stuff here. But just a taster of what you can find within his archive regarding old interesting stuff. Again, I strongly encourage to go and browse yourself!IMG_3965.thumb.jpeg.28fe54ef15594e4463405e5e7dd2049b.jpeg
1890s CBSC mainline train
1933 cashel service
the following 2 locos are of pike and Carlisle. 2 original cork and youghal railway tank engines IMG_3970.jpeg.b9f25ad5c956fbacbd963f587790788c.jpeg
 Clayton railcar trials in the Newmarket and kanturkIMG_3949.thumb.jpeg.f11563c4e5c666cb425708800991ee0c.jpeg
and finally. A CMDR 4 wheel coach IMG_3953.thumb.jpeg.26b07d53bd94509aef7bdf29d25e1012.jpeg
Not just an exceptionally rare picture, or an exceptionally rare vehicle - but an exceptionally rare TYPE of vehicle in Ireland. A four-wheeled anything of that style is almost unheard of here, though once relatively more common in the Neighbouring Island, but a two-compartment four-wheeled brake third would be little more than unique. Excellent find - and it has lasted into GSR days!
Like this? (Flickr image by Trainiac)
Kingsbridge station
  • Agree 1
Midland Great Western no. 50
Another gem from Trainiac on Flickr on that theme.
From the same source, this one is almost as stubby as the Triang-Hornby 4-wheeler:
Belfast Central Railway
  • Like 8
Kingsbridge station
They’ve captioned that wrongly - this was a GSWR 2.4.0….
That lower one is Bishop’s Castle Railway in England rather than Belfast Central. Fior that line, and quite a few others in Britain, vehicles like this were not uncommon. The 3rd class compartments must have been cosy….
Thanks for setting me right, JHB. There's some great photos on that Flickr site but we obviously need to interpret the captions with more caution than I had done.
1 hour ago, 2996 Victor said:
This is a fascinating conveyance! Would it have been restricted in use to a specific service or branchline?
Cheers,
Mark
Looks tbh like a drovers van. Attached to cattle trains to accommodate the guard and also the ‘escorts’ for the cattle. SLNC was using them right up until closure.
Edited by Galteemore
Thanks! Presumably, then, it would have been finished in goods stock livery rather than passenger livery?
Thanks,
Mark
  • Agree 1
That's exactly what it is. They were used on cattle specials and tended to be found lurking in Athlone, Mullingar and Broadstone when not in use. You would think that they also might have seen use on branchlines, especially where cattle was a big thing (e.g. Loughrea) but seemingly not so much. Certainly not in GSR times.
Senior took a photo of a similar van but without passenger accommodation at Broadstone in the early 1930s. It was shabby looking and as he said, probably (but not certainly) out of use. It was still in MGWR livery like the above. The full brake versions of these were green, so the above may be too. Failing that, certainly standard dark wagon grey.
There is a Cyril Fry model of a yoke of this nature in the Malahide Model Railway Museum. It is a very dark green, not unlike UTA coach green or BCDR loco green. The van that Senior saw in the 1930s was a dulled mid-green, but since anything in Midland livery in 1931 or 1932 hadn't seen a paintbrush for at least seven years, the original colour could have been very much darker indeed. Fry's livery interpretations are generally exceptionally accurate and exceptionally detailed, though there are a few aberrations to the theme; he painted a model of a 500 class 4.6.0, and two other locos, which spent their entire working lives in dark grey, in "Maedb"-style blue-green!
Edited by jhb171achill
Actually classed as a Goods Brake Van apparrenlly for general use.
The H C Casserly photo was described in the IRRS paper as "11 ton brake van No50 built 1892, shown in rebuilt state with 'glasshouse: at Broadstone 1932
A raised guards lookout(s) and drovers compartment/(s) were almost a standard feature of MGW Brake Vans until a 'conventional' van with balconies at each end and no duckets were introduced during the early 1920s
Interestingly a pair of 6w 20T Brake Vans with guards compartments (with raised lookout) at each end and two passengers compartments were introduced in 1912. There is a photo of these vans in a decrepit condition in one of the collections in the IRRS Flickr Site.
P. O'Cuimin Feb 1970 IRRS paper Wagon Stock of the MGWR includes details of MGW Brake Vans.  Brake Vans listed "Generally brown" 1874 type mid-green as running circa 1923-4
Scratch built model of 1874 Brake (1stStandard Type) Brake Vans, plasticard/stripwood approx 30 years ago. My model of the 1874 van is based on a 1931 LGRP photo of No29 in MGW livery still with wooden brake blocks.
The HC Casserley photo of No 50 appears to be a re-built verison of a new type of van introduced 1892 for use on the "new Western Lines. O/Cuimin indicated that the van as built was quite different to the 1932 photograph, origonally the 2 passenger/drovers compartments were located at each end with the guards/luggage compartment in the middle, no balcony but retaining a birdcage look out, 56-61 introduced 1904 were listed with differning compartments and 'this design" used for 'renewal" (replacement) of 1874 vans with same leading dimensions as in the 1892 Class.
I suspect that these older 'caboose' style vans were withdrawn/taken out of use as more 'conventional" steel underframe Midland, GSWR/GS vans became available during the late 20s-early 30s. In his 'Enginemans Son" IRRS paper PJ Currivan wrote about playing 'cowboys & indians" in the long line of caboose brake vans stored in a siding in Athlone during early GSR days, his father was a former GSWR driver transferred to the Athlone Midland shed following the amalgamation and wrote about his adventures growing up on the railway. PJs two Engine Mans Son papers are a great read.
Basically looking at short 14' mainly GSW Cattle Wagons or 14' Convertibles for modelling the GSR/pre-Amalgamation period the longer KN Cattle Wagons only seem to have appeared in CIE days. The Midland mainly relied on Convertibles to handle the bulkof its cattle traffic with covered cattle wagons relatively rare and camera shy 430 Covered, 1613 Convertible still in service 1924
Edited by Mayner
  • Informative 3
  • 4 weeks later...
7 minutes ago, Westcorkrailway said:
Only seeing this now…never seen this before!
Sorry, I didn't win it! Thought you might be interested.
  • 1 month later...
Quite a rare photo, or at least one I had never seen before of old no.36, taken (presumably at Inchicore) about 1890, from The Engineer, January 17th 1896, whats almost as interesting as the loco is the narrow gauge line to the right, I had been unaware Inchicore had such a system, presumably purely hand and horse worked
Edited by Killian Keane
  • Like 9
That is incredible. Had no idea these ran in Ireland. What railway and colour scheme?
Yes, that tramway was hand worked.
It certainly IS incredible! Built for the Great Southern & Western Railway, could get from Dublin to Cork in five hours...... Livery was a dark green, possibly not unlike what it carries on display in Cork station nowadays - at first. In later years a very dark olive green, same as 90 at Downpatrick. Black and white lining originally, but it possibly got the elaborate lining seen on 90 before it was withdrawn. It would not have carried the much paler green it was displayed in for very many years, as far as I am aware. For anyone wanting to model that era, the passenger stock carried a variety of colours to denote 1st, 2nd & 3rd class. I think I have the details somewhere. By the late 1860s anyway, the GSWR seem to have standardised on an exceptionally dark maroon / brown colour (like the lower panels on preserved coach 836 at Downpatrick), which in traffic, and weathered, looked almost black. Goods stock at that time was also an extremely dark shade of grey, more or less black; much darker than "normal wagon grey".
Larne, Co Antrim
Found this image of Larne, description says it was taken c. 1888. There’s a nice view of the town and sidings and a loco that looks ancient — even for 1888!
Edited by Branchline121
Typo
  • Like 8
That four-wheeled van it’s towing was one of several mobile tool vans. Operating between Kingsbridge and Inchicore would be typical of their use.
  • 3 weeks later...
On 4/11/2025 at 1:54 PM, Flying Snail said:
The 'Abbeyleix' photo appears in the Poole Collection on the NLI. The caption is that it was 'commissioned by Mr. John Gorry, Derrykearn, Abbeyleix'. So to be fair, it doesn't actually claim to have been taken in Abbeyleix. It almost certainly wasn't, thats a MGWR loco.
Original link here: https://catalogue.nli.ie/Record/vtls000595074
100%; couldn’t possibly be Abbeyleix.
  • 1 month later...
Looking behind the people (sorry, my sociopathic tendencies):
Page 18 shows a GSWR 6-wheel passenger brake van in the 2-colour livery in 1906.
Page 25 shows the directors posed on a step wagon on the Listowel & Ballybunnion.
Page 45 has some detail of two covered carriage trucks.
Page 46 has a variety of goods wagons.
Pages 47 and 48 show details of inspection saloon 352 and the interior of Killarney train shed.
Page 49 is the Rosslare image in my previous post. Nice view of 6-wheel coaches behind.
Pages 55 and 56 seem to show narrow-gauge rope-worked railways at Lisduff Quarry.
Page 66 shows the Cahirciveen fishing fleet - a huge number of small vessels!
Page 67 is the Valentia image in my previous post.
1 hour ago, Tullygrainey said:
Wonderful stuff. And what a great bunch of characters. I can almost hear the chatter and smell the pipe tobacco.
“Splendid, old chap!”
On 28/8/2026 at 8:49 AM, Flying Snail said:
Wonder where that model is!
  • 3 weeks later...
Looking on the Westport Facebook page, there was a coloured version of an Achill picture that has been seen on here, plus a Clifden shot taken from a different angle:
IMG_1470.thumb.jpeg.140dae2785eb75f7e8cad862b3148676.jpegIMG_1469.thumb.jpeg.d084a42f476b3a5c445f04817c299fe5.jpeg
At least they’ve the carriage colour right! Station paintwork red where the brown is, and loco green….
I was thinking the same. I do find these AI-assisted colourisations frustrating as they are often inaccurate.
The train in the second image includes one of the 4-wheel third saloons with longitudinal seating.
