Paudie Riordan Posted January 14, 2014 Posted January 14, 2014 Hi Guys. What's best to use for road markings and box Junctions etc , outside of buying transfers? Any help is appreciated Thanks Paudie
0 Broithe Posted January 14, 2014 Posted January 14, 2014 For the white markings, these 'correction pens' are quite good. ..and 'flexicurves' can still be had from some stationers, they're a great help in making the lines 'flow' properly.. The white markings that result can be a little too clean, but it's easy enough to dull them down a bit.
0 Weshty Posted January 14, 2014 Posted January 14, 2014 (edited) The white markings that result can be a little too clean, but it's easy enough to dull them down a bit. That's the thing. A road is not matt black and white markings. Best advice, go outside, take a photo and then look at the result. Multiple shades of mid and light grey. Very fine black wet and dry sandpaper is useful as the road surface that you can then airbrush to get that graduated look. The off white marking (white and tiny bit of brown) can then be finely daubed on. Edited January 14, 2014 by Weshty
0 Broithe Posted January 14, 2014 Posted January 14, 2014 That's the thing. A road is not matt black and white markings. No two pieces of tarmac are ever the same colour - the range of shades is quite extreme, if you do actually look at them - and there's usually a shading where the tyres have 'polished' it a bit, too - as in your picture.
0 Weshty Posted January 14, 2014 Posted January 14, 2014 In fact it might be better to look at variations of blue-grey, rather than grey. Particularly if the road is made of limestone chippings as a lot of smaller non-asphalted roads would be in the Republic.
0 heirflick Posted January 14, 2014 Posted January 14, 2014 For the white markings, these 'correction pens' are quite good. [ATTACH=CONFIG]11333[/ATTACH] ..and 'flexicurves' can still be had from some stationers, they're a great help in making the lines 'flow' properly.. [ATTACH=CONFIG]11334[/ATTACH] The white markings that result can be a little too clean, but it's easy enough to dull them down a bit. great tip there Broithe:tumbsup:
0 Broithe Posted January 14, 2014 Posted January 14, 2014 great tip there Broithe:tumbsup: You can hardly see it - the cap is still on....
0 heirflick Posted January 14, 2014 Posted January 14, 2014 You can hardly see it - the cap is still on....
0 dave182 Posted January 14, 2014 Posted January 14, 2014 and the 2014 IRM award for worst one liner goes to...
0 David Holman Posted January 15, 2014 Posted January 15, 2014 For road colour, sadly Humbrol Tarmac is no longer made, but Precision paints do an equivalent. As the others say, road colour is highly variable and is much darker when wet too. For that, Humbrol Clear Cote is good, as it darkens whatever you use very nicely. Either fine wet and dry paper is good for a Tarmac surface or paint the surface in gloss grey and sift on talc. Leave overnight and brush/vacuum off. Extra layers of paint and talc can be used to add the inevitable repairs, trench fills etc. The white lines could be done by cutting a stencil and painting throught it, but the are commercial road markings too, including ready printed roads ready to lay. You pays your money and makes your choice. Perhaps the one thing to ensure is any markings are really sharp, which is where the ready printed ones can be advantageous.
0 Glenderg Posted January 15, 2014 Posted January 15, 2014 One option is to use cheap tile adhesive, which comes in a dark grey colour. Add a couple of drops of blue cartridge ink and stir vigorously. The finished texture looks superb, and scraping or working an area with wire wool will highlight it like a worn surface. Years since I did it, but when I ripped up the layout in September, it still looked decent enough. Even where I'd spilled RailZip looked good as diesel splashes etc. Richie
0 Broithe Posted January 15, 2014 Posted January 15, 2014 Don't forget a few(?) pot-holes, puddles, man-holes, shores, etc - with all the different coloured repair patches.
0 Broithe Posted January 16, 2014 Posted January 16, 2014 Or a squashed badger? ..... Or a shot one, if you're doing a UK West Country layout - at £4,000 a hit - you could have a person shot for that much..
0 minister_for_hardship Posted January 16, 2014 Posted January 16, 2014 Or a squashed badger? ..... A mate from the uk was shocked at the amount of roadkill on Irish roads...'why doesn't someone from t'council go round picking them up?'
0 jhb171achill Posted January 16, 2014 Posted January 16, 2014 At the risk of misguiding this thread away from the original point, I once saw the Gardai having to shovel up the remains of a very large dog which had come to grief at the Mad Cow roundabout..... stomach churning.
0 Paudie Riordan Posted January 16, 2014 Author Posted January 16, 2014 Thanks for the replies lads. Lot to think about there. How do you model roadkill! lol
0 RedRich Posted January 16, 2014 Posted January 16, 2014 Plastikote Suede is another option worth considering and should be available in DIY stores. I've seen it used on a few layouts and it looks really impressive when painted. Rich,
Paudie Riordan
Hi Guys.
Thanks
Paudie
18 answers to this question
