Mayner Posted August 28, 2022 Posted August 28, 2022 2 hours ago, Broithe said: Over time, as the 70s moved into the chaos of the 80s, they became used for more and more things, as it became impossible to get agreement to spend any money on the actual job. As things failed, they were slowly replaced by, essentially, home-made things. When my father retired in the late 70s he started doing shutdown maintenance work for an engineering contract shop. One of his last jobs (in the Clondalkin Paper Mill) was inspecting/dismantling plant then servicing and re-assembling the plant without replacing worn parts as there was no money in the budget to replace worn/broken parts. Dad didn't mind he had basically seen it all before and the pay rates with the contract shop were good 2 Quote
Broithe Posted July 22, 2023 Author Posted July 22, 2023 Talk elsewhere of a time when I did a bit for a plant hire firm has had me thinking about the mad stuff that went on. The owner did not look the part at all - when I first met him, I would have guessed he was a geography teacher, but he was hugely competent at his work, if a little unconventional. He had plant involved in a project which was running a new bridge across a dual carriageway. The bridge spans arrived and were hanging on the crane when it was noticed that an existing streetlight was in the way of one of the spans being placed. As with all such projects, huge numbers of organisations were involved and a dispute arose about what to do. The lighting had to remain operational, but the post couldn't stay there. It was not really any of his business, but whilst dozens of blokes were arguing in a Portakabin, he spoke to the crane crew, to ascertain what height was acceptable and got an electrician to disable the wiring up the pole, but leaving the connection in the base, as a 'junction box', so the rest of the lights would still work. Then he got a saw and was lifted up in a bucket to cut the top of the lamppost off, leaving a few inches clearance from the bottom of the bridge, so there was no chance of rain ingress. The stump was there for many years after, under the bridge and unnoticed by thousands who drove past it every day, although it is gone now. I always used to acknowledge "Martin's lamppost" whenever I went past it. 3 2 Quote
Broithe Posted February 27, 2024 Author Posted February 27, 2024 . 15 minutes ago, Mike 84C said: I posted that Baldwin drawing quite a few years ago. I rather suspect that all of the American imports were not successful/ liked in the UK is the totally different engineering philosiphy of the American builders and the "not invented here" attitude of GB engineers. That ones still about! Interesting article about the Port Talbot 0-8-2t's in Railway Archive No 4 July 2003 it also has a very good drawing. They were built by Cooke of Paterson NJ. This reminded me of one of many similar events when I had a 'proper job'. We made high-voltage circuit breakers and had many "events" which were caused by plated bolts having the plating scraped off as they were tightened. With vibration and the effects of the fairly intense electric field, the bits would often eventually line up and cause the insulation to fail, in quite a spectacular manner. The company had the policy of always buying the cheapest rubbish available and hoping for the best, but this was getting desperate, stuff was blowing up everywhere and a solution was wanted (in reality, they just wanted to be seen to be actively seeking a solution, whilst hoping that the problem would soon be overshadowed by something bigger). A meeting was called and I suggested that we might get a lot less debris if we used stainless steel fasteners. This would have involved spending a few pence more, but I might as well have suggested using platinum. A few years later, we were taken over by a French operation who made similar stuff, but to a much higher standard - and I remember a bloke actually laughing at the state of the bolts we used. We then went to S/S everywhere... Not only were the fasteners a bit flaky, in the true sense, but they were also very rough - to the point that they usually required a spanner to spin them in loose. This led to a near double fatality, when some bolts were removed from a pressure vessel which was still (unknowingly) pressurised. The tightness as they came out, still loaded up, seemed 'normal' to the chaps undoing them, until the last few let go and fired the whole 4 tonne thing up through the roof, derailing the travelling crane that was holding it, ready to be lifted off, and filling the sunken area they were working in with a dense, asphyxiant gas.... 1 2 Quote
Mike 84C Posted February 27, 2024 Posted February 27, 2024 British engineering ; run by ??? oh yes accountants. 1 1 Quote
Mayner Posted March 9, 2024 Posted March 9, 2024 On 28/2/2024 at 3:15 AM, Mike 84C said: British engineering ; run by ??? oh yes accountants. Not just Britain but prevalent 'as value engineering" (skimping) at an international level in construction. Senior management began to panic that I was using substantially more stone fill than they had estimated on the Masonite Ireland project in County Leitrim during the mid 1990s. In commercial construction the Contractor buys stone fill by from the supplier by the Tonne and is paid by the Main Contractor or Client by the Cubic Meter. When the panic set in our engineers were instructed to (physically) check and re-check the volume used and kept coming up with the same answer in Cu/M which did not tally with the tonnage used, until I pointed out that the density of the stone supplied from the Roadstone Boyle Quarry average 2.5T/m³ well above the theoretical 1.6T/m³ used in the estimation text books. We had a similar panic while working for the same firm on a Dublin project and decided it was time to move to a firm with a more practical pragmatic management culture. Moving to my first job in New Zealand I spent my first day laughing at the level of skimping on an Auckland Apartment project which made engineering design on Irish and UK projects of the 2000s era look extremely high cost and conservative (cautious) in comparison. I quickly made two decisions (1) not to buy a post 1970s home because of the high risk of defects (2) to get our of construction or work on my own account due to the hassle working for the larger companies in the industry, a decision that me basically took me through to retirement without too much hassle 2 1 Quote
Horsetan Posted March 10, 2024 Posted March 10, 2024 2 hours ago, Mayner said: Not just Britain but prevalent 'as value engineering" (skimping) at an international level in construction.... The Chinese have taken this to another level, which might explain why a fair few of their boom-era buildings have collapsed over the years. Quote
Ironroad Posted March 10, 2024 Posted March 10, 2024 On 27/2/2024 at 9:15 AM, Mike 84C said: British engineering ; run by ??? oh yes accountants. That's a little unfair. Accountants are not engineers and if involved in the costing process can only take the information provided to them by engineers at face value. Sometimes in the course of competitive tendering it is engineers on the sales side that take an overly optimistic view on quantities etc. The situation described by John would indicate to me that, yes, as should be the case the accountants were raising the alarm when actual costs were exceeding the estimates. I've seen this happen. Hopefully there were no other issues and the contingency factor, (that should be a part of every building/engineering proposal) provided sufficient cover, albeit of poor consolation. 1 1 Quote
Mayner Posted March 11, 2024 Posted March 11, 2024 On 11/3/2024 at 4:36 AM, Ironroad said: That's a little unfair. Accountants are not engineers and if involved in the costing process can only take the information provided to them by engineers at face value. Sometimes in the course of competitive tendering it is engineers on the sales side that take an overly optimistic view on quantities etc. The situation described by John would indicate to me that, yes, as should be the case the accountants were raising the alarm when actual costs were exceeding the estimates. I've seen this happen. Hopefully there were no other issues and the contingency factor, (that should be a part of every building/engineering proposal) provided sufficient cover, albeit of poor consolation. In commercial construction an Estimator or a Senior Quantity Surveyor will prepare costings (and appoint contractors) for a project in consultation with members of the senior management team who are usually of an Engineering or Construction Management background rather that working is separate silos. Part of the problem may have been a reluctance by managers from an Engineering or Construction background to question the assumption of an Estimator or Quantity Surveyor (member of a separate professional body) As a Site Manager or Foreman I only got involved after a successful bid, my role was identifying issues and risks at an early stage including questioning design, estimating and final assumptions. At organisational level there tended to be two responses either to work through the issues or pretend they did not exist. I tended to jump ship quickly with the latter kind of organisation, staying around was not worth the hassle. 2 Quote
Mayner Posted April 7, 2024 Posted April 7, 2024 I guess the moral of todays story is that the Irish can beat almost anyone when it comes to sharp practice and its sometimes difficult to judge whether a Gombeen Man is just incompetent or a rogue. Abought 30 years ago I was working as a Site Manager for a major Irish Construction company one of whose specialities was building Hotels for "Investors" who were taking advantage of tax breaks for investments in 'tourist infrastructure. The company successfully completed 'budget hotels" in Cork and Galway using pre-cast technology and were approached by the promoters (firm of architects) in mid-96 to complete a similar hotel in Dublin by the end of the (96-97) tax year. The company advised that it was unable to complete the project within the expected time frame using traditional construction or pre-cast technology. Promoters came back a couple of months later advising that they had found the Irish Licensee to a British "fast build" building system that would that would complete the building superstructure within the foreshortened time frame. The Irish licensee would be appointed as Lead Contractor while our role was to manage the overall project and collect our fees. I had just completed a manufacturing project in Athlone and was asked to be present at a meeting in Dublin the following morning with my bosses, the promoters, services contractors and the Irish Licensee for the 'fast build system' our Gombeen Man. This was before the days when everyone on a construction site wore high vis or branded clothing, most of use arrived at the meeting wearing a combination of business suits and smart casual wear though our Lead Contractor turned up smoking a cigar and dressed like Arthur Daley complete with soft hat and Crombie coat. Our lead gave use a presentation on how he would complete the project on time, though the information on his concrete supplier and sources of labour were not convincing, the left the meeting While promoters and my side did not say a word, the services contractors immediately turned to the promoters and asked for a 'extension of time" to complete the project when the Lead Contractor failed citing major problems on a number of projects where the same individual was involved In the end we finished the hotel in time for the 'investors" to receive their tax breaks, though we had to take direct control of the works from the licensee to complete the project (similar to adminsitration) The Gombeen Man had sufficient leverage in terms of the Irish license to the proprietary UK system to be retained as contractor to carry out the "off site" assembly in Dublin, though he remained a nusiance and was banned from site for much of the contract, though he did appear to take credit and guide prospective clients around after we handed the completed hotel over to the client. Think it may have been mainly a case of our Gombeen Man not realising his limitations getting in too deep both in the case of the organisations he was dealing with the construction team were aware of his track record and used him as long as necessary. Surprisingly while our Gombeen Man struggled with the off-site assembly, he employed a highly competent site manager and team of carpenters and roofers to complete the roofing works. One interesting snippet was receiving a call to remove the company sign board as the ISO Quality Auditor was expected to drive past the site on his way to carry out an audit at head office. The company possibly keeping the project "off the books" in terms of its Quality Assurance system to avoid reputational damage if the project failed. I left that particular firm shortly after completing the hotel and never experienced a similar problems on a construction project again 3 Quote
Mayner Posted April 7, 2024 Posted April 7, 2024 Looking back apart from the drama that was going on in the background with the license holder of the 'building system" the project ran smoothly at site level with the exception of one potentially serious incident. The metal framing system was accurate, components arrived on time and everything fitted accurately co-ordinating with brickwork modules and aluminium glazing system often a serious problem on large projects. The building was four storey with concrete floors supported by the steel structure on a metal decking system that was supposed to be self supporting, I had come across similar systems in the UK that used a lightweight concrete topping but not with a dense concrete topping. Unconvinced that the decking would be self supporting I ordered in props while waiting the paperwork from our Lead Contractor that the floor was self supporting. Armed with the paperwork we started to pour the first floor of the building without propping, the concrete gang noticed the decking had began to deflect in one area, we paused the pour to install the propping and resumed the pour after 1 hour and used propping on the remaining three floors while the powers that be argued over who would pay for the propping. Ironically I investigated two floor collapses involving similar flooring systems while working in Health and Safety (Ireland and New Zealand) one as a result of inadequate propping one as a result of inadequate design, luckily no one was killed or seriously injured in either incident though it was a close thing. The Irish case (which involved my former employer on the hotel project) resulted in a successful prosecution of the contractor who installed the propping the New Zealand case a change in the Design Code for Composite Floors. One near miss and investigating two collapses leads me to take nothing for granted and to look upwards when it comes to building and construction. Quote
Broithe Posted April 8, 2024 Author Posted April 8, 2024 (edited) We do have a general tendency to just believe in (completed) floors, but I lost that belief in the late 1990s, not in a factory event, but in doing some voluntary work for a wildlife trust. Their headquarters was in a 300-year-old three storey ex-farmhouse. There was no electricity on the top floor, but they want to turn an old storeroom up there into an office. I was roped into providing sockets and lighting up there. The whole building was very delicate, but the components was generally big and it all seemed OK, if you were careful. Someone had been under the floor before me and had created a loose board, which was very handy - this had been to get at the wiring for the light in the office below, where a solicitor's wife was performing her secretarial duties. I was particularly keen to avoid damage to the ceiling - a delicate lath and plaster structure, on separate beams from the floor (a good idea, as flexing of the floor does not flex the ceiling). I made a point of doing all the work under the floor first and getting the lifted board back in place, so that I wouldn't put my foot through the ceiling. "Phew, I'm safe now!" At this point, it became clear that the ceiling in the 'new office' was not up to holding anything more than itself, so it was agreed to put the lights on the walls, which were a bit better. This involved going up and down two steps on a step ladder repeatedly. Stepping down from one task, I didn't stop as usual and the eruption of debris, plus the odd position of my leg, told me I had gone through the floor, but, even from where I was lying, I could see the 'loose board' really was in place. By the time that people from below arrived, I had managed to extricate myself and could see down through the hole to observe the state the solicitor's wife was in below. I had stepped onto the centre of the span of one board and, not being tongue-and-grooved, that single board had given way. The wood looked beautiful, polished by three hundred years of use, but it was like a photograph of some wood, stuck onto an inch thick digestive biscuit. Having ascertained that I was uncut underneath all the debris, I went downstairs to see the result, a yard-wide hole in the ceiling and the solicitor's wife totally submerged in the debris of three centuries storage above - one of my great regrets is not having the presence of mind at the time to record the imprint of my boot in the pile on top of her head. We took two binfuls of debris out of her office and the hole was plated over. The rest of the floor above was found to be in a similar state - I even managed a Jackie Chan test on another part of the floor and punched through it with my bare hand - so, be warned! The beams were found to be OK and the floor was boarded over. I now have a permanently-running 'soft floor detection programme', whenever I am above ground level - or a cellar. Edited April 8, 2024 by Broithe 1 1 1 Quote
Gabhal Luimnigh Posted April 8, 2024 Posted April 8, 2024 Not as eventful as you lads but one time in the last century I was doing some fascia and soffit on a new house belonging to my boss at the time, the scaffolding was already in place from the blocklayers and plasterers but my boss had been moving boards to suit us, I was on the top level casually walking the line with a length of fascia and suddenly dropped through the scaffold! The boss had put a plank that was too short and barely sitting on the scaffold and I almost did severe damage to myself only for the boss was actually underneath me at the time and broke my fall with his hard hat , I was sore but alive, he was in pain 2 Quote
Mayner Posted April 8, 2024 Posted April 8, 2024 (edited) Back in the day on a sunny summer morning walking the top level of a scaffold of a round a house I noticed a beautiful girl walking by on the street below and suddenly found myself walking in thin air! luckily I grabbed on to a scaffold standard and lived to tell the tale getting away with a few bruises and learned to keep my wits about me regardless of the temptation! This was back in the days when 'I was learning the trade" guardrails and toe boards on scaffolds and any formal though of safety were unknown you could easily "walk off" a scaffold if you wern't 100% alert, yet working for the same firm building several hundred houses serious accidents were practically unknown. Edited April 8, 2024 by Mayner 3 Quote
Ironroad Posted April 8, 2024 Posted April 8, 2024 And she probably would not have even noticed. 2 Quote
Galteemore Posted April 8, 2024 Posted April 8, 2024 Probably used to people falling for her all the time. 3 Quote
Mayner Posted April 9, 2024 Posted April 9, 2024 Bit like a story of one of my aunts as a young woman being 'chatted up' and followed by a driver of a CIE bus who was so besotted he took the wrong turn at Harolds Cross Park and had to back-up with a busload of passengers. I guess we were all young once! 2 Quote
Broithe Posted April 9, 2024 Author Posted April 9, 2024 10 hours ago, Mayner said: Back in the day on a sunny summer morning walking the top level of a scaffold of a round a house I noticed a beautiful girl walking by on the street below and suddenly found myself walking in thin air! luckily I grabbed on to a scaffold standard and lived to tell the tale getting away with a few bruises and learned to keep my wits about me regardless of the temptation! This was back in the days when 'I was learning the trade" guardrails and toe boards on scaffolds and any formal though of safety were unknown you could easily "walk off" a scaffold if you wern't 100% alert, yet working for the same firm building several hundred houses serious accidents were practically unknown. We used aluminium 'quick' scaffolding in the factory, as it was up and down all the time. The Safety Officer started insisting on toe boards, etc, and we went along with it, even though the platforms sagged so much that tools could get kicked off just as easily as without them, except at the ends, etc. One day, I found that there was another new problem. We had a truly giant bloke, who normally worked on site, but was in the factory during a quiet period. I was showing him an odd thing that he would be needing to deal with in the future. We were about fifteen feet up and when that was done, he left the scene, whilst I carried on with the last bit. I found that I was unable to leave the scene - my safety shoe was trapped by the rebound of the platform, when the toe board pinched it just behind the toecap. No matter what I did, I couldn't get loose. Rather than go for help with one shoe on, I shouted at a couple of chaps to come up and act as ballast to 'sag' the platform enough for me to get out. The cause of all this was, a few days later, banned from the aluminium scaffolding as, when torqueing up a bolt, standing in the middle, he bent the platform to an alarming degree! I also still have a CEGB helmet that I was wearing when I heard something small hit it. I looked around to see what it was and found a Swann Morton scalpel that had been dropped from twenty feet above... 1 2 Quote
Horsetan Posted April 12, 2024 Posted April 12, 2024 On 9/4/2024 at 10:18 AM, Broithe said: ....I also still have a CEGB helmet that I was wearing when I heard something small hit it. I looked around to see what it was and found a Swann Morton scalpel that had been dropped from twenty feet above... Block of flats, was it? 1 Quote
Broithe Posted April 12, 2024 Author Posted April 12, 2024 31 minutes ago, Horsetan said: Block of flats, was it? No, a circuit breaker in this sort of style. I was sitting on the ground at the bottom and it was dropped by a chap standing on the scaffolding above the top. 1 Quote
Horsetan Posted April 12, 2024 Posted April 12, 2024 2 hours ago, Broithe said: No, a circuit breaker in this sort of style. I was sitting on the ground at the bottom and it was dropped by a chap standing on the scaffolding above the top. Jaysus.... Quote
Broithe Posted April 14, 2024 Author Posted April 14, 2024 . 2 hours ago, Horsetan said: Just imagine it's the caravan that Father Ted, Father Jack and Father Dougal stayed in when they went on holiday! This reminded me of an event with one of the circuit breakers described above. Actually the one where the scalpel was dropped on my head. The bloke who dropped it was called Jack and worked for the CEGB, the ESB equivalent on the Big Island. He had no idea what he was doing, but also no understanding of how little he knew. He was also the dropper of the scalpel. They blew up one of the breakers in a dramatic and potentially fatal way. I know what they did, but they denied it and tried to blame us, saying it had 'just blown up', so we had to go through a pointless pretence of trying to find the "reason". The operation of these devices is fairly violent. In normal operation, though, the system stopped the mechanism from reversing until the operation had been completed, but, when hand operated, a person could defeat this delay, if they really tried, and cause the operating tube to buckle and break the pressured porcelain column that held the interrupter head up in the air. One of their chaps had blown the centre phase up, by doing this and only narrowly avoided killing himself in the process. He admitted hand-operating it and hearing a 'funny noise', then finding that it wouldn't operate again (because the loss of gas pressure had locked it out), so he got up and stepped back, falling over the ton of interrupter lying in the gravel just behind him, having caused the 'funny noise' as it fell down. So, we had to go through the process of seeing that the stresses were well within a reasonable range, when it really was operated properly. This involved sticking strain gauges all over the surviving breaker on the site and operating it in the manner in which they claimed to have done to the exploded one. Anyway, the aforesaid Jack, who had no idea of what he was supposed to be doing, spent a lot of time trying to see how we were setting up our strain gauges, so that he could copy us. The CEGB had said that they would supply a caravan to house the rather delicate electronics that we brought up with us. They had no shortage of money at all and I expected a caravan the size of a decent house, but, possibly in a further effort to stop us showing that it was not our fault, they supplied the smallest caravan that I've ever seen. My colleague, Barry, of whom more may be said at a later date, was the strain gauge king, so I left him to it in the caravan, as there was very little space. Jack, determined to see what was going on, went in there with him, but had to crouch and lean back against the door. The 'safety officer' felt the need to say something to Barry, for some reason, and grabbed the catch of the door - caravan doors open outwards - this was all that was holding Jack in place, like a coiled spring - and Jack, prestressed against the door, shot out horizontally, like a missile, taking the safety man off his feet and carrying him a yard back into a concrete pillar, winding him so violently that we considered calling an ambulance. I was nearly hyperventilating to the same degree... 3 Quote
Broithe Posted April 25, 2024 Author Posted April 25, 2024 (edited) The mention elsewhere as to veracity, or otherwise, of some writing in blue crayon, reminded me of what seemed like a great wheeze at the time, but escalated way beyond our expectations. The engineering director was based at another factory site, sixty miles away. He would come down every few weeks and annoy people in our factory. He would drive down in his Granada and, not having a designated parking spot on this site, he would just dump it in anybody else's that was vacant and 'pull rank' on them. He was a very pompous and argumentative bloke, so he usually got his way. One day, driving in, he spotted a space that was almost always occupied, by the car of a chap as awkward and obnoxious as he was himself. This absence of a vehicle was taken to mean that Harry was not in work that day, so Pete abandoned the Granada in the spot and went off to annoy people. However, Harry was only at the dentist and came back after half an hour, to find Pete's cat there, he parked an inch from the bumper, leaving no possibility of getting the Granada out without negotiating its release. He had had run-ins with Pete about parking before, so he went inside, wrote a note and put it under Pete's wiper. The note said, in blue crayon and block letters "DO NOT PARK HERE AGAIN". Harry was not under Pete's auspices in any way, working for a completely different organisation, so he was well up for arguing with him, on the few previous occasions that it happened. Someone came in the office and said "Harry's put a note on Pete's car, this could get interesting", so we went down to look at it - Harry had only used to top half of the A4 sheet. After some effort, I managed to locate another blue pencil and we added "YOU BASTARD" in the bottom half - then went off to wait. The effect was rather greater than we expected - down the corridor, we heard "Did you put this on my car?" - Harry shouted back "Yes!", which, whilst true, was taken to mean the whole text, including the added part that Harry knew nothing about - they were both well into their sixties and we had to separate them from the scuffle that erupted... They are both dead now and neither of them ever spoke to each other again - or knew the full context of the Rumble in the Corridor. Edited April 25, 2024 by Broithe 1 4 Quote
Mayner Posted April 25, 2024 Posted April 25, 2024 (edited) The saga of the hotel project and the Gombeen Man did some good as I was headhunted and offered a role as a manager with a company that had impressed me for some time. First project was Project/Site Manager on a large North West Dublin Logistics/Warehousing project where my role was largely co-ordinating things with the designers nd specialist contractors while John our senior engineer and something of a Claude Greengrass character was in day to day charge of the sub-structure works with a team of engineers, direct labour, and specialist contractors. I looked after superstructure works (steel work, cladding, mechanical and electrical services) with a Finishing Foreman in charge of the Office Fit out. John was extremely enterprising individual along with his day job, he provided a taxi service for our team of directly employed workers from Westmeath, installed part of the project's rainwater system on a piece-work rate during weekends and indulged his Greengrass instincts by trapping game and vermin. Setting and checking out the traps did no go down to well with his passengers going to and coming home from work. John would take a diversion to set or check out his traps and some of the lads were a bit squeamish about the dead animals in the back of the van. John got into a spot one day installing a downpipe inside a warehouse at a height of about 12m using a knuckle boom and managed to trap himself between the structure and the cage of the boom, was unable to reach the controls but somehow managed to find a way out despite being the only one on a very large site before the days of reliable cell-phone coverage. I did not acquit myself to well with possibly the same boom after successfully replacing a defective double glazing unit in the project Office Block some time after handover and the Office Block was occupied, I managed to strike and damage the remotely controlled entrance gate to the Office car park with the knuckle boom. One of the clients Directors rang my boss in panic and was told not to worry that I would sort out the problem. Apart from telling me that he received the call my boss never said another word about the incident. We carried out a temporary repair job and operated the gates manually for a couple of weeks before carrying out the permanent repair. During the Final Phase of the project a serious problem arose for the firm of Architect in charge of the project issued a Certificate of Practical Completion to our firm and the Client refused to accept the Final Phase of the project. At literally the last minute the Clients representative identified that one of the staircases in the Office Block breached fire/building regs.. Spent an interesting afternoon walking the Office Block with one of the Architectural Firms senior partners and a copy of the Building/Fire Regs trouble shooting the offending stair case, changing the direction of opening of some fire doors and closing off general access from the staircase to a plant room (chain and a small sign) so it was not classed as part of an escape route. We completed the alterations in a day or so and the client occupied the Final Phase of the project. I guess the Clients Rep could justifiably claim that he had done something to justify his fee. Never found out if we invoiced the firm of architects for the alterations or simply treated as a goodwill gesture to avoid embarrassing the firm and remain on their list of preferred contractors a days wages for a couple of carpenters was small change on a £12m project during the late 90s Unfortunately I did not really appreciate that I was working for a really good company until I jumped ship in pursuit of higher pay 2-3 years later and found myself in a far worse situation, though I guess I would not be where I am today if I did not make that move so there are no regrets. Edited April 26, 2024 by Mayner 2 Quote
Gabhal Luimnigh Posted April 26, 2024 Posted April 26, 2024 15 hours ago, Broithe said: The mention elsewhere as to veracity, or otherwise, of some writing in blue crayon, reminded me of what seemed like a great wheeze at the time, but escalated way beyond our expectations. The engineering director was based at another factory site, sixty miles away. He would come down every few weeks and annoy people in our factory. He would drive down in his Granada and, not having a designated parking spot on this site, he would just dump it in anybody else's that was vacant and 'pull rank' on them. He was a very pompous and argumentative bloke, so he usually got his way. One day, driving in, he spotted a space that was almost always occupied, by the car of a chap as awkward and obnoxious as he was himself. This absence of a vehicle was taken to mean that Harry was not in work that day, so Pete abandoned the Granada in the spot and went off to annoy people. However, Harry was only at the dentist and came back after half an hour, to find Pete's cat there, he parked an inch from the bumper, leaving no possibility of getting the Granada out without negotiating its release. He had had run-ins with Pete about parking before, so he went inside, wrote a note and put it under Pete's wiper. The note said, in blue crayon and block letters "DO NOT PARK HERE AGAIN". Harry was not under Pete's auspices in any way, working for a completely different organisation, so he was well up for arguing with him, on the few previous occasions that it happened. Someone came in the office and said "Harry's put a note on Pete's car, this could get interesting", so we went down to look at it - Harry had only used to top half of the A4 sheet. After some effort, I managed to locate another blue pencil and we added "YOU BASTARD" in the bottom half - then went off to wait. The effect was rather greater than we expected - down the corridor, we heard "Did you put this on my car?" - Harry shouted back "Yes!", which, whilst true, was taken to mean the whole text, including the added part that Harry knew nothing about - they were both well into their sixties and we had to separate them from the scuffle that erupted... They are both dead now and neither of them ever spoke to each other again - or knew the full context of the Rumble in the Corridor. Excellent Quote
Broithe Posted April 26, 2024 Author Posted April 26, 2024 (edited) 11 hours ago, Mayner said: John was extremely enterprising individual along with his day job, he provided a taxi service for our team of directly employed workers from Westmeath, installed part of the project's rainwater system on a piece-work rate during weekends and indulged his Greengrass instincts by trapping game and vermin. We had a few country gentlemen in the factory and a steady supply of free-range non-domestic victuals. One chap was a legitimate gamekeeper and was able to supply wildfowl, etc. One day, as I entered the foremen's office, I heard a conversation that i understood, but would have sounded a bit odd to anybody who wasn't aware of all the underworld stuff that went on. We used a lot of epoxy resin and had a dedicated cold storage arrangement for it. Without looking at each other, one of the foremen, filling in the day's attendance sheet, asked the other "Is Jim Cook in today?" the answer would have seemed enigmatic to anyone who didn't know - "I haven't seen him, but there's a duck in the fridge". - the sheet was duly ticked and they carried on with other stuff. We had another chap who was very much less official in his activities. Fred would supply anything to order, wild or otherwise. He was the slinger in the fabrication shop and had a 'cabin', a small steel shed in the centre of the shop, to hang his slings, chains, etc. This also served as a bonded store for stuff that he had brought in for people. The foreman of the shop was a rather gruff character, that it was generally best to avoid, I found. One day, at a time when Fred was going to 'find' some brass sheet for me, I heard some soft noises from the shed, so I stuck my head in to ask how he was getting on on that score. He had about thirty rabbits hanging up and was gutting them into a bucket. Having ascertained that my needs would be fulfilled later that day, I left the scene. I was then apprehended by the foreman - "Have you just been in Fred's shed?" - expecting some admonishment, I had no choice but to answer "Yes". He just looked at me and said "I've never been in there" and walked away, shaking his head. We had a chap who was a trendy, cravat-wearing, finger-in-the-ear folk-singing aficionado. He had a fondness for all things 'traditional'. He asked Fred, "Could you get me any real turnips these days?' - the next day, he arrived at his desk to find, on his seat, a huge sack of turnips, and soil, freshly dug from a field a few hours before, before it got light. It took him three days to get them all home. Fred never had a car (or any form of licence!), or even a bike, and lived ten miles away. He would get to work by standing in the road and stopping any passing car. If things got difficult, he would sometimes 'borrow' a Ferguson and drive in on that. I was late more times in any week than he ever was in his whole time there. Most people in there had a 'side hustle', as the youth of today term it. Mine was selling woodscrews. I had a little display board with the various types, finishes and sizes on and would collect orders, until I had enough to get a good discount from a chap in Exchange & Mart. He would trade from the start of the tax year until he was just under the VAT threshold, then stop, so this kept prices keen and I could supply myself 'for free', with screws purchased using the discount for large orders. He would tip me off as the annual sales hiatus approached, so I could keep my customers happy. Edited April 26, 2024 by Broithe 1 Quote
Broithe Posted June 20, 2024 Author Posted June 20, 2024 A discussion elsewhere has reminded me of this. We still made and maintained air-blast switchgear in my time and that had its own issues, as the pressures could be quite high and failures could be fairly spectacular. One thing which became an issue was that the compressors that maintained the air supply did, occasionally, blow up dramatically, sending big lumps at speed around substations. There were obvious safety issues about this, although it usually happened with nobody there, but statistics would catch up in the end. It was decided to produce a 'cage' for the compressors, to catch the bits and contain the damage area safely. It was not easy, or economical, to blow up actual compressors, so estimates were made of the size and velocity of the bits. Me and my lad were tasked with testing and modifying the mesh enclosures, as necessary. We ended up, through a few stages, building a large air-powered gun. It fired brass slugs, about 2" diameter and 4" long, by means of a 'snap' valve that dumped 3,000psi from a reservoir onto the back of the shell, driving it out of a three foot barrel. To avoid the firing device being damaged by the ricocheting shells, as the ones that got through rattled round the sleeper-lined walls, we fired it into the blast cell, through a cracked open door - waiting for things to go quiet before we opened the door to see what had happened. We altered the cages until we got an arrangement that contained the shell most times and that was deemed 'OK'. It wasn't until later that we started to consider the legalities. The UK would let you have an air rifle up to 12 foot-pounds without a licence being required. Our gun was many, many times beyond that - basically a small cannon. It seemed best not to raise the issue... 1 2 Quote
Gabhal Luimnigh Posted June 20, 2024 Posted June 20, 2024 7 minutes ago, Broithe said: A discussion elsewhere has reminded me of this. We still made and maintained air-blast switchgear in my time and that had its own issues, as the pressures could be quite high and failures could be fairly spectacular. One thing which became an issue was that the compressors that maintained the air supply did, occasionally, blow up dramatically, sending big lumps at speed around substations. There were obvious safety issues about this, although it usually happened with nobody there, but statistics would catch up in the end. It was decided to produce a 'cage' for the compressors, to catch the bits and contain the damage area safely. It was not easy, or economical, to blow up actual compressors, so estimates were made of the size and velocity of the bits. Me and my lad were tasked with testing and modifying the mesh enclosures, as necessary. We ended up, through a few stages, building a large air-powered gun. It fired brass slugs, about 2" diameter and 4" long, by means of a 'snap' valve that dumped 3,000psi from a reservoir onto the back of the shell, driving it out of a three foot barrel. To avoid the firing device being damaged by the ricocheting shells, as the ones that got through rattled round the sleeper-lined walls, we fired it into the blast cell, through a cracked open door - waiting for things to go quiet before we opened the door to see what had happened. We altered the cages until we got an arrangement that contained the shell most times and that was deemed 'OK'. It wasn't until later that we started to consider the legalities. The UK would let you have an air rifle up to 12 foot-pounds without a licence being required. Our gun was many, many times beyond that - basically a small cannon. It seemed best not to raise the issue... The good old days 1 Quote
Broithe Posted June 22, 2024 Author Posted June 22, 2024 Seeing @Dempsey's terminal boards reminded me of a highlight event of my time in the factory. Our control cabinets had large columns of terminal boards and relays, as there was not enough commonality for the wiring to be done with a loom, but each wire was individually terminated and run to be bundled up. This also, coincidentally, gave a means to find out what was going on, if the control arrangements failed, as they often did. The relays were meant to have protective covers on, but it was common to leave them off until things were working reliably. One day, myself and another chap were walking past Barry, often mentioned in reports of events, whilst he was delving into a suspect cabinet with his beloved Fluke meter. Just as we reached him, he suddenly adopted a position very like a figure skater - on one leg, with the other pointing straight back and both arms outstretched and fluttering. He had clearly found a live bit, and not with the probe, as intended, but with his head. Test items were mounted on a large cast-iron bedplate, with T-slots in, for ease of clamping things down quickly. Thus, being on a very nicely earthed floor, this meant that dragging Barry off the source of the shock was really not a good idea at all and I took a step back to aim a kick at his chest, as he performed his (potentially real) dying swan act. This would separate him from it and give me the minimum time exposure. I was actually quite disappointed when he managed to extricate himself before I could kick him off it, but I was still treated to the memorable sight of the small hole in his forehead, as he turned to face us, dazed. The hole was where he had put his head onto the 415 volt connection of one of the relays. There was quite a significant wisp of smoke coming out of the hole, not a thing you'll see very often. He survived the event without any extra issues, but he wasn't right before it, to be fair. 1 Quote
Gabhal Luimnigh Posted June 22, 2024 Posted June 22, 2024 1 hour ago, Broithe said: Seeing @Dempsey's terminal boards reminded me of a highlight event of my time in the factory. Our control cabinets had large columns of terminal boards and relays, as there was not enough commonality for the wiring to be done with a loom, but each wire was individually terminated and run to be bundled up. This also, coincidentally, gave a means to find out what was going on, if the control arrangements failed, as they often did. The relays were meant to have protective covers on, but it was common to leave them off until things were working reliably. One day, myself and another chap were walking past Barry, often mentioned in reports of events, whilst he was delving into a suspect cabinet with his beloved Fluke meter. Just as we reached him, he suddenly adopted a position very like a figure skater - on one leg, with the other pointing straight back and both arms outstretched and fluttering. He had clearly found a live bit, and not with the probe, as intended, but with his head. Test items were mounted on a large cast-iron bedplate, with T-slots in, for ease of clamping things down quickly. Thus, being on a very nicely earthed floor, this meant that dragging Barry off the source of the shock was really not a good idea at all and I took a step back to aim a kick at his chest, as he performed his (potentially real) dying swan act. This would separate him from it and give me the minimum time exposure. I was actually quite disappointed when he managed to extricate himself before I could kick him off it, but I was still treated to the memorable sight of the small hole in his forehead, as he turned to face us, dazed. The hole was where he had put his head onto the 415 volt connection of one of the relays. There was quite a significant wisp of smoke coming out of the hole, not a thing you'll see very often. He survived the event without any extra issues, but he wasn't right before it, to be fair. FFS jaysus how the hell did he get away from it, how did he even stay conscious to do it!? The smell of burning flesh is not pleasant 1 Quote
Broithe Posted June 23, 2024 Author Posted June 23, 2024 4 hours ago, Gabhal Luimnigh said: FFS jaysus how the hell did he get away from it, how did he even stay conscious to do it!? The smell of burning flesh is not pleasant It was OK, I was upwind. It was probably less difficult than the time he was walking downstairs behind me and another chap who was describing an explosion to me and illustrated it by flinging his arm backwards and accidentally punching Barry in a delicate region, provoking him to fold into a foetal position and only just be caught by us as he hurtled past, no longer in control of his own descent of the stairway. 1 Quote
Gabhal Luimnigh Posted June 23, 2024 Posted June 23, 2024 8 hours ago, Broithe said: It was OK, I was upwind. It was probably less difficult than the time he was walking downstairs behind me and another chap who was describing an explosion to me and illustrated it by flinging his arm backwards and accidentally punching Barry in a delicate region, provoking him to fold into a foetal position and only just be caught by us as he hurtled past, no longer in control of his own descent of the stairway. So Barry was the real reason you turned up for work, endless entertainment 2 Quote
Broithe Posted March 3 Author Posted March 3 Talk elsewhere of the culture of avoiding reality in management responses has reminded me of this flowchart, of great use in predicting the outcome of an activity. 2 1 Quote
Horsetan Posted March 3 Posted March 3 4 minutes ago, Broithe said: Talk elsewhere of the culture of avoiding reality in management responses has reminded me of this flowchart, of great use in predicting the outcome of an activity. That's a bit like the whole "helping Ukraine" thing. 1 Quote
Mayner Posted March 3 Posted March 3 (edited) 21 hours ago, Broithe said: Talk elsewhere of the culture of avoiding reality in management responses has reminded me of this flowchart, of great use in predicting the outcome of an activity. "Self" Praise and honours for the non-participants reminds me of when I was managing the construction of a large steel framed workshop on a UK Heritage Railway in North Wales about 30 years ago. The prep-work(earthworks and foundations) for the 'big day" of erecting the structural steelwork was carried out over several months by a small group of regular volunteers and like Jim Morrison's prophecy in Waynes World 2 or was it Costner Field of Dreams "book them and they will come" I announced in the Society Journal that we had booked a mobile crane to erect the steelwork on Easter Sunday. The 'they will come" part was fulfilled when a group (of steel erectors) from Holycombe Museum met us in the pub on the Saturday evening and volunteered their services, completing the steelwork element in two days. The self praise and honours for the non-participants took place on the Sunday morning when the crane set up with about 100 people wearing hard hats appeared (many I had not seen before or since) and posed for the "group' publicity photo for our Journal and Railway Press, before immediately returning to their cars and driving away never to be seen again. I would hope that at least some had donated to the appeal that paid for the shed. The steel erectors and crane driver simply got on with it, the regular volunteers installed the purlins (timber) and roofing iron during the following week and we never saw the VIPs again, so everyone was happy. Edited March 4 by Mayner 3 Quote
Mayner Posted March 21 Posted March 21 (edited) Being young and ambitious I was recruited a couple of times in the late 80s into DOGE style management teams on London area construction projects that were in or getting into trouble. (Usually over budget, behind schedule and sometimes serious quality problems. Interestingly the recruiter and interviewers kept very quiet about the trouble shooting nature of the role or being recruited into a new team to replace existing staff. The first on a major Wapping residential development (opposite the Prospect of Whitby) by an old established Building Company from the South Coast was one of my most enjoyable and frustrating roles in 30 years working in construction. I was hired by the London director (a GWR enthusiast) and got on well with my Boss a Londoner of Scottish extraction who was brought in to turn the project round and the Commercial Manager (Snr Quantity Surveyor) going out for a meal and drinks on Thursday evenings, the job paid well with salary review and pay increase almost every time the deputy GM visited London, the car was the best perk the company ran its own fleet and I got the Managing Director's David cars (a Ford enthusiast) as he traded up starting with an Escort XR3 and later a Sierra Saphire (XR4) pretty good with unrestricted private use holidays and weekends. The frustrating bit wasn't that the project had fallen behind schedule, over budget and there were serious quality problems/repetitive errors, but there were serious problems at Head Office level that the Trouble Shooter, Peter (a Scott) brought in to re-organise the company was unable to influence. The business was basically a family firm controlled by three brothers divided into a Building Division (income from external clients) run by the MD, with a Plant Hire division (Brother 2) and Joinery Divisions (Brother 3) as preferred suppliers to the Building Division. Dealing with the Plant Hire division was almost Dickensian there was a minimum 2 week lead time on all orders regardless of urgency (fax & paper original) anything from a small power tool to a Site Office faxed & internal mail to the South Coast although often cross-hired from a Docklands Plant yard. The last straw for the Commercial Manager was when the Plant Division supplied some WW1 or possibly Crimean War huts as office accommodation for our Client and then got into trouble for ordering some modern Portacabins. My last straw when finally given 'my own" project a project for a Hackney Housing Association that was at an advanced stage of construction (beautiful Facade tiny apartments/town houses, was to find that I had 20 almost complete two storey town houses with no staircases, the Joinery Division were unable to provide a projected delivery date. Peter (the Troubleshooter) and I resigned around the same time. Peter had to go as the MD David was not prepared to have the hard words with his brothers, the Brothers eventually managed to sell the business which ceased trading after 2000, though its now almost 40 years since I worked at Shadwell Basin. The next job was with a building company that pioneered "Fee Contracting" in the retail sector which morphed into a form of Partnership Contracting for major commercial and retail projects in the 1990s and again found myself recruited into a new management team on a major retail project in Watford. After the nice pleasant interview and induction & given a company car at Head Office, my first inkling that something was amiss was when I was greeted with 'who the fuck are you" when I reported to the "Site Superintendant" on my first day on site. I was quickly taken under the wing of Tony the Superintendant (company tended to use different job descriptions for the same job to most other UK contractors) on Phase 2 of the project which was complex and kept me busy for about 4 years. During the re-organisation the company dropped all reference to "Site" and usual industry roles from its job descriptions A Site Manager became a Construction Manager, a Quantity Surveyor a Commercial Manager. Although originally pioneering the organisation became outdated and complacent and was not up to managing the large complex projects that emerged in the "Big Bang" era, the entire senior management team (above line manager) on the project was replaced during my first year on site, some of the senior management people did not realise what was happening until they received their severence. In certain respects the old school of senior management was more line Grace Brothers than what you'd expect on a then £100m project. David the "Superintendant" that greeted me on site had a site clerk more a military "Batman" Tom to keep the office organised, both were Scot's received lodgings and travelled home once monthly. Tom assumed that my overcoat was 'company issue" and asked me to sign a chit for my own coat. Tony's and my Senior Manager seldom if ever appeared on site (Project Office) had to be specially summoned to the Project Office to return his company car & receive his severance pay. Project was great fun for me identifying and offering solutions to problems, in one case we had to install a 12m temporary bridge to cross a basement excavation, after the local council a project client would not allow concrete trucks to cross a bus lane, in another the Clients Project Manager was not exactly pleased that I identified design issues that added £100k to the project cost. Client had imposed a 'design freeze" on the project before the completion of the architectural and engineering design was complete omitting a series of 'plant room" doors. Like the little boy pointing out that the King was wearing no clothes, I asked the Project Architect why there were no door openings or doors to a large no-of rooms and he was unable to answer. We had a good social life for several years on the project once the new management team settled down, though they increasingly became leaving does as the project would down with little emerging work in the pipeline I had that meeting with HR with generous redundancy terms and I got to keep my company car. Edited March 21 by Mayner 1 Quote
