Dempsey
Everything posted by Dempsey
  1. For some perspective here are three keg wagons on one of the storage sidings I've been searching following your suggestion. Any idea where it might still be available as I've come up empty? Slow and steady rob, slow and steady
  2. With most of the track having arrived save for the last three remaining pieces the track plan has begun to reach it's final stage. Some slight changes have been with some lengthening of curtain sections to expand the width as it seems too comprised. I think even though the changes are slight it makes a huge difference.
  3. I offer a service in that regard if you wish.
  4. Brilliant work
  5. Very high praise thank you very much. It is real cement dust. I had some trouble with it initially as ot was my first time using it but I'm happy and more importantly the owner is happy with the results
  6. Recently completed bubbles. Your thoughts as always are appreciated. Chris
  7. Need to up my game. Thats good work.
  8. Nicely done
  9. I'm looking forward to seeing this scene develop
  10. Layout update. Track has started to arrived with must of the points and the slight curved sections having been purchased. Having had the opportunity a few weeks ago thanks too @jhb171achill to meet various others from the hobby who were extremely helpful and more knowledgeable, the layout will be powered DCC wise by the NCE Powercab control system with points being operated by tortoise point motors. Also did a rough fit of the points leading into the yard. The unpowered scenic section leading off the board I decided to recycle some old hornby track and point I had has nothing will run on it and it doesn't need to be prefect.
  11. Or enterprise coach stock as the enterprise livery 201s much like the intercity have nothing to hual passenger wise. That being said, having returned to the hobby too late to pick up any of the originally produced mk3s I'm looking forward to their release.
  12. Suspended sentences only survive to undermine the legal system and enables those to continually break the law.
  13. Thank you I'll definitely look at getting a hold of that. Spent the morning designing using peco set track. I had hoped to use my stock of code 75 trackage and points I had for my actual layout as a cost saving option but the available points would not have allowed me to use the space. The set track by peco that was suggested in earlier posts has given me more room and some longer sidings and run around tracks and I must admit it think it'll add more value running wise to the layout. Thank you all for your suggestions. I'm glad I went back and took the time to revise these plans.
  14. I will look into it further, maybe down load some of those templates off peco. I do have peco track and some points I was collecting for when I build my actual layout but the way that is unfortunately a long way off.
  15. Unfortunately it was a compromise I had to make with the space. Thank you though for your suggestion.
  16. I had originally set out with a view to using peco but my limited selection of their points on Any Rail didn't allow for the track plan within the available board space.
  17. Track plan printed out to use as a template
  18. With some time off work the baseboard for barracks street layout has been completed.
  19. Assembled, painted, transfers applied and weathered one CH-47D. Have to say I enjoyed doing this kit, the first in a very very long time. Not a big fan of Revell to be honest. A lot of panel gaps and rough edges but all in all a good kit to get back into it.
  20. Brilliant images
  21. Had a few days between doing some weathering jobs and my own backlog of projects it was a nice break
  22. If only, would love a spin in one.
  23. Painting completed and two good layers of gloss varnish applied. Leaving to set for a few days before beginning to apply the transfers followed by some weathering. Also dry fitted the rotor heads which will be glued in place along with the side guns once all other work is completed. Very happy with how the paint turned out.
  24. Rotor heads fitted in place along with the internal bay and cockpit. Both body sides glued together with engine exhausts and cockpit canopy fitted following painting.
  25. With installation of the larger extended range fuel tank complete next stage was a light grey primer coat followed by some pre shading along the moulded panel gaps. Next stage will be to fit the window "glass" before dry fitting followed by gluing the interior pictured aboveand both sides together.
