Everything posted by murrayec
Hi Just a note on a previous post about the Lidl grinding wheel for the hand held unit;- Though the Lidl ones may be soft, but one wants the wheel to disintegrate (hopefully at a slow rate), this is how the wheel works- as chips break off it leaves a continual sharp surface on the wheel to do its job Eoin
Dave Sorry to hear that, it would have been wonderful item to have in the workshop Eoin
Hi I gave the bench grinder its first wherrrrrr this morning, processing a batch of screws for a DART set chassis;- At 1/4 regulator open it works an absolute treat, nice and quiet and far better than the Dremil screaming in my ear and blowing cold air in the face! The grinding table support needs a little up-stand for to rotate the pliers on and the job will be perfect. I then turned to the brass wire brush to clean up a bit of the flyingscot soldered brass back chassis, again at low speed, it cleaned up beautifully with little effort. Though a softer wire brush would be better. Very happy with this addition to the workshop and my ears really appreciate it..... Eoin Safety Tip Using Brush Wheels;- There is no guard on this wheel so be extra careful, and a good idea is to put something soft about 300mm behind the machine- just in case the wheel takes the work piece out of the hand the soft object will retain it and hopefully minimise damage. Never put your fingers inside an object being worked on always hold it on flat surfaces and not on protruding edges. Bring the work piece up to the wheel under the centre line of the wheel. Read the safety instructions that came with the machine.
Broithe That's a nice size, plenty of room in n around that Sometime in the future I would like to acquire one in this size range..... Eoin
Hi Kirley Lovely, I like the section at the shed Eoin
JM You mentioned a C3, I have a Clarke version, I upgraded it over the years to the same spec as an ArcEuro C3- its a deadly machine and love using it BUT;- if you can afford it go for something bigger, everything is very tight (close together) on these little machines, all the stuff gets in the way of your hands and using small drill bits is a nightmare as the saddle gets in the way of the tailstock! Go bigger, if I was doing it again I would.... Eoin
G oooohh! like sherbert, do you remember the stuff that came in the tube with a liquorish straw.... Eoin
Hi JM The mini bench grinder is for light work only- grinding screw lengths, cleaning up light sheet materials from metal kits and bar stock that one could not put near a proper bench grinder, plus my proper bench grinder takes up the whole bench.... Eoin
Hi David The Proxxon drills come in different flavours, it depends on which one you have and they are only light-work machines same with the Dremel. If you require something with umph one needs a high speed spindle drill but they come at a premium in the range of €400.00 up to €2,000.00.... I've just purchased a StepperCraft A3 CNC Machine Kit with HSS drill and other attachments- not telling how much it cost, but cant wait for the courier to come calling... Eoin
In Lidl today Nice set of small power tools for the workshop;- €24.99 for the belt sander €24.99 for the bench grinder and polisher €19.99 for the jigsaw The thing about big tools is when you bolt them down to the bench there is no bench left, these tools are ideal and could be left in position for handy use! Eoin
Hi DC Cellulose is a fantastic paint for all materials its why most car body shops used to use it- its probably the best and its cheep On the other hand its deadly to humans if it gets into the lungs- it sticks the little woolie bits together and suffocation comes on. This is why you don't see back lane car body shops any more- insurance companies and employers wont take the risk and to up-grade to the water system is to expensive for the back lane guys- what's the cost of a car oven!! Eoin
Lads! I feel another cartoon coming on.... Better refrain! Eoin
Weshty for you... Tony As far as I know cellulose paint is not used in the motor industry any more due to safety, they use a water based system now that requires an oven to set the paint hard- that's why they say the paint does not dry well if used without an oven! Go for the Humbrol option Eoin
David Excellent stuff there, has been a great help Eoin
Tony That paint you have there looks fine Many moons ago myself and a chap who drove JCB's used to service the bushings on the back-actor- I still have the drill bits and the reamers for doing the job! oh and I still have the pillar drill we used to use, at that time JCB sold the kits and one could buy paint from them for touch up?? Eoin
Hi There is a hand written date on the instructions- 7-4-1982 In my search I read that Hornby employed an outside company to build the models and Hornby added their name. I'd say they regretted in the end because a lot of people experienced trouble running them- steaming problems, gas container and seals perishing, and it was constructed 4mm to small of 3.5inch gauge! Not sure but I reckon the static model idea was to recoup... Eoin
Hi Tickets! sure Mum and Dad are holding the train up while junior makes a swing to catch the pantograph and he's off Clever devils, must be southside pandas Eoin
On the Stephenson's Rocket Model;- Nelson;- it would be great to see any photos you have, but its the inside bits I require if you ever took it apart and photographed it.... This is the idea I have on drilling out the steam chest and cylinders;- The first image shows the cylinder assembly from the instructions, note there are 4 holes shown along the centre line of the chest port face which are not drilled out on the kit, also a longitudinal steam way will be required to be drilled out also (I indicate this on my sketch of the side view with dotted lines) The second image is my sketch as to how I reckon the system needs to be modified, but not to sure! pity the instructions don't show the cylinder port face If these sketches mean anything to anyone I would be interested to hear what you think Thanks Eoin
Hi All Don't forget the Bray Show 'Toys of Yesterday' is on this Sunday, second last show before Christmas and the New Year- time to pick out your presents!! See you there Eoin
Borithe you beat me to the photo of a early hi-tech phone/camera! The tame geek site is deadly;- ''How To Solve This Problem You can prevent any rotation issues in the future by taking your iPhone photos and videos with the volume buttons pointing down. However, it’s not as convenient as holding your iPhone with the volume buttons pointing up, especially if you use those buttons to take photos. That’s why I almost always prefer to keep the volume buttons up and deal with possible problems later.'' I can say this easier- 'JHB you are holding the camera upside down' Eoin
Hi Noel A video here; http://irishrailwaymodeller.com/showthread.php/4121-Class-C-ECMCHAS-For-Silver-Fox-Kit?p=79227&viewfull=1#post79227 also slow running vid at start of the above thread Eoin
Hi Noel, this one is for you I had taken this video and others some time back with fast, slow, stop/start running- but somehow this is the only one I can find. If I locate the others I will post up, otherwise I will shoot it again the next time the test track is up. Long curve points, short points, and double scissors at speed!! - all the points have the ECM check-rail mod. The little beast will be at Bray Show on Sunday??.... Eoin
Hi All I picked up a Hornby Rocket Static Model kit last week at the Stillorgan Show, I plan to Live Steam it and have trawled the internet for photos and info- found loads but some things I cannot find;- If anyone can help it would be much appreciated 1. A copy of the Live Steam instructions. 2. Has anyone taken photos of the cylinder steam ports- the static model does not have these drilled out, I have worked out the approx set-up but it would be nice to know I'm on the right track. This may also be indicated in the instructions? 3. Has anyone got photos of the piston parts- these parts are not included in the static kit! The kit; The offending cylinders with no ports; Thanks if you can help Eoin
