Darius43
Everything posted by Darius43
  1. Interior made from cut and shut spare corridor coach seating. Cheers Darius
  2. Dunglazin. Cheers Darius
  3. Primary painting completed. Cheers Darius
  4. Primer on. Cheers Darius
  5. Roof details and ironmongery fitted. Cheers Darius
  6. Not yet. MTK LMS coach repurposed as a UTA (ex NCC) coach. White metal coach ends cleaned up and glued in place. Plasticard strips used to reinforce the joints.. “Standard” chassis made from plasticard sheet and Plastruct angle sections. I used the MTK trusses but replaced the MTK bogies with Bachman LMS bogies. Roof detailing next. Cheers Darius
  7. Thanks Patrick. I get the most satisfaction out of rescuing and restoring a model that would otherwise have been discarded. Light weathering to finish. Cheers Darius
  8. Decals and other details applied. Cheers Darius
  9. Main cab windows cut from acetate sheet and trimmed to fit. Cheers Darius
  10. Bodyside glazing fitted. Cheers Darius
  11. Handrails fitted. Cheers Darius
  12. A bit more painting done. Cheers Darius
  13. Primary painting completed. Cheers Darius
  14. Yellow for SYP applied and Lima chassis/bogies modified to fit. Cheers Darius
  15. Roof vents drilled out and opened up. A1 Models etched grilles fixed in place. Cheers Darius
  16. Recently acquired from eBay a complete and assembled MTK class 42 bodyshell. The builder has made a reasonable job of the assembly but has applied plasticard grilles to the bodysides - presumably as the flush grilles were sanded away in the assembly process. I removed the plasticard grilles and re-scribed the flush grilles in their place. Primer coat applied. Cheers Darius
  17. KR Models rtr model finally arrived courtesy of Rails of Sheffield. Perhaps someone will now produce an rtr model of Mr Bulleid’s Turf Burner… Cheers Darius
  18. Leslie, I would like to second Robert’s words and wish you a very well earned retirement. It was great meeting you at the NEC a few years ago and I have really enjoyed building the Brown Vans, Double Beets and Spoil Wagons. All the best Darius PS - I’ll be in touch regarding the remaining Double Beets…
  19. MTK Class 47 finally finished - Fox Transfers plates fitted and light weathering to chassis. Cheers Darius
  20. Arrived yesterday from Amazon and assembled this morning. Thing is, the dinosaur is missing… Should I get in touch with Amazon about this? Cheers Darius
  21. Thanks Robert. There seems to be a bit of a hoo-ha over on RMWeb about whether the number of this GUV is correct. The first number I applied definitely wasn’t and so I was advised of the correct number series, advice which subsequently turns out to be not so correct… …or is it. We may never care… The next project beckons. Cheers Darius
  22. The original MTK buffer beam was a tad high… So I rebuilt it at a more appropriate height… Cheers Darius
  23. Decals and light weathering to finish. Cheers Darius
  24. Primary painting completed. Cheers Darius
  25. Acquired partly started from eBay. The kit contained an assembled body and chassis parts including generic MTK trusses. The previous builder had applied plastic tape roof ribbing, which was starting to delaminate. The tape ribs were unpeeled and the left behind adhesive residue removed. New ribs were scribed in as were the doors. Door hinges and ironmongery were fitted using MJT etched parts. I made a new chassis using 1mm thick plasticard and Plastruct angle sections. I used the MTK white metal bogie sides as cosmetic sides mounted on plasticard bogies with brass bearings fitted. I modified the MTK trusses and glued them to the underside of the plasticard chassis along with the MTK white metal undergibbon parts. Cheers Darius
