Everything posted by Darius43
Hi John, I plan to use Phoenix enamel BR rail grey cut with a little blue - as I did with the two that I made previously. Cheers Darius
Simply the beets. With apologies to the late, great, Tina Turner. Cheers Darius
How I did the beet loads. Load support “tables” made from 2mm thick card and glued together using pva. Tabletops painted black (to stop any light card colour showing through) and tables dropped into the wagon. Neat pva applied to the tabletops and beets spooned on - pressing them in gently with fingertips. Beets secured in place using diluted pva - sort of ballasting with beets. Loaded wagons join the rake. Cheers Darius
Two more completed. Beet loads to follow… Cheers Darius
Hi John, For the base colour I airbrushed Phoenix “Rusty Nails” Track Colour enamel mixed with a little Matt Black and thinned for airbrushing. Once dry I misted on a weak coat of light grey. Sugar beet loads added. Cheers Darius
Dunpaintin. Next step is to add the beets. Cheers Darius
And then there were three… Cheers Darius
Primer on. The detail on the resin moulded parts is superb. I’ve even got some model sugar beets with which to load the wagons. Strictly speaking they’re HO rather than OO but hopefully no one will mind… Cheers Darius
First of five… Wonderful kit - goes together in about 30 minutes including parts clean up. With thanks to Provincial Wagons/Leslie. Cheers Darius
Some haulage has been rostered… Cheers Darius
Two more wagons assembled. …and completed. Cheers Darius
Fairburn, Class 40 and a GWR Castle running in the shed today. Cheers Darius
Decals applied followed by some weathering and coal loads. Cheers Darius
Some Bachmann Thompson coaches with light weathering applied. Will be running in the shed later… Cheers Darius
Two more hopper wagon kits assembled - plus a BR 21 Ton hopper wagon (also Parkside). These are fun kits to build and go together well. Cheers Darius
Started some Peco (Parkside) BR 20t Hopper wagon kits. Coal loads to be added followed by weathering (or vice versa). Then seven more to go… Cheers Darius
Last weekend in the shed… Cheers Darius This weekend in the shed… Cheers Darius
Coastal Defence Train completed. I added Lanarkshire Models tail lamps to the gun trucks. Cheers Darius
Thanks - the scarf was made by rolling out a thin line of Humbrol putty, flattening it and trimming it in place. Cheers Darius I’ll tell mum! Cheers Darius
Some more passengers painted… Cheers Darius
Loco chassis arrived and duly fitted. Cheers Darius
First troops on board… Still quite a few more to assemble and paint. Cheers Darius
