BosKonay
Moderators
Everything posted by BosKonay
  1. :drool: Insufficient drool alert!!
  2. Moved you over here Sean. Looks good, you've the start of some lovely stock - do you plan to set up a baseboard?
  3. Good luck Richie! Not a bother to ye!
  4. Wow! Can't wait to have a Paddy murphy 121 in that livery!
  5. http://silverfoxmodels.co.uk/ir-ie-electricity-generating-van/ Thats the link to the silverfox option
  6. The MK3 kit / sides from Studio Scale Models is probably your best bet http://www.studio-scale-models.com/Coaches.shtml
  7. Albeit Maternal
  8. And tubbers called it 'old fashioned'
  9. BosKonay
    A Class
    Yep - John Hazleton - johnsilverfoxmodels@msn.com
  10. I'm using cobalt digital point motors. They include a switch terminal so you can add a push button and LEDs for an 'old fashioned' physical control panel.
  11. Great!!
  12. Take the clear plastic rail joiner on the bottom left rail and move it up to the frog. Then join the point up to your layout using regular metal joiners on all the other rails.
  13. Also, the frog should be fully isolated - so make sure you have insulated joiners on both frog connections like this image
  14. In your photo, you have what look like Hornby "DCC" clips inserted into the point. See the small thin metal 'wires'? You should be able to pop them out with the blade of a screwdriver, you should be ok then.
  15. Sounds like a short. I assume it's a point?
  16. An absolutely beautiful execution!! Lovely work!
  17. http://www.themodelshop.ie/de-detrich-open-coach-ienir-enterprise-new-livery/gtm009pd.html €69.99 each, but am sure Seamus would do you a deal if buying a few They are a stunning paint job
  18. Now yer talkin HeirFlick!!!
  19. If using a mac, I'd recommend http://www.railmodeller.com/
  20. I. Know! I'm using it for routing and point / signal control so the base version covers it!
  21. I'm using this http://moorestreettmd.co.uk/mstmd/bigbeardcc_trial.aspx 30 day trial, works beautifully with the Elite, and only 20 pounds for the basic version
  22. Lovely Gear Jack!!
  23. What stunners! How did you do the load?
