Everything posted by Mayner
My father great man for conspirancy theoies used to say that the Drumm Trains were "sabotaged" off the rails. I am not sure if he was thinking about the Sandycove de-railment or the DUTC shutting down Drumm train operation when it took over the GSR The whole saga of the Drumm Trains seems to have been initially tied up with the Shannon Scheme the ESB providing special discounted electricity rates and the Dail voting substantial money for battery development for trains A&B. Things had changed by the mid 30s with the ESB charging the standard rate and the GSR taking on the entire risk in building the final Drumm Battery Trains C&D. C&D introduced 1939 only lasted less than 10 years in service. C&D had a much more modern appearance compared to the earlier units with rounded cabs and steel framed bodies similar in styling to the Bredin main line and suburban coaches. The main draw back seems to have been short battery life (difficulty in obtaining nickel) though services were also affected by restricted ESB hydro generating capacity during the Emergency
Irish Broad Gauge Carriages is basically a concise history of the evolution the Irish railway carriage from the 1840s up to the 70 Class Railcar trailers the last Irish designed and built carriages. The ITG stock book is probably better source for the more modern stock than Broad Gauge Carriages. http://www.irishtractiongroup.com/shop.html
Keep an eye out for Locomotives and Rolling Stock of CIE&NIR Doyle & Hirsch. (3 editions) cover the 70s & 80s probably the nearest thing to an Irish version of an Ian Allen ABC spotters notebook with photos and details of each loco and most coach and wagon types. ITG published similar books covering locos and wagons only.
One of the attractions of building and operating a garden railway was that it felt more like the real thing. My garden railway The Jackson County found itself in a similar situation to Irish Rail in the early 90s needing major work on the track. The first sign of trouble was when the gauge started spreading in one area. The ties bleached out noticeably after about 6 years, the rail fixings then became brittle and spalled off. The engineers tried replacing every 5th tie to hold the gauge, a run-down short line money always tight, speed low, the mines and logging camps almost played out. County Surveyor and State Government start hearing complaints of standing de-railments an inspector is sent. Emergency re-laying Tie strip completely failed on some lengths. Recovery train propelling back over re-laid section. Replacement track panels for the re-lay. The little diesel is an LGB DRGW Switcher converted to on board battery RC, with receiver in cab control gear and batteries inside engine housing. The original track was Accucraft (AMS) American 3' narrow gauge track the replacement Sunset Valley narrow gauge. The bleaching and UV damage only became noticeable after about 6 years. Luckily enough I was able to find a suitable replacement tie/sleeper strip for the existing rails, hopefully the replacement ties will have a similar service life to the rails. The area where the track failed is exposed to afternoon sunlight although UV radiation is supposed to be stronger down here the Waikato is probably as sunny as the West of Ireland
I started setting out sleepers and point timbering on the curved approach track to the station. Track and ballasting for the station board is nearly read for transplanting to the layout. I have followed Iain Rice's technique in "An approach to building Finescale Trackwork in 4mm" in prefabricating complete sections of ready ballasted point and crossing work on a sheet of paper rather than assembling the track in situ on the layout. On this layout I am experimenting with Templot templates glued with spray mount to a sheet of kraft paper, the complete formation will in turn be spray mounted onto 6mm dense foam (ground sheet) on 18mm ply baseboard and hopefully result in quiet running. Approach crossover timbering I gave the template a wash of dark grey water colour to prevent the white paper 'grinning" through the ballast resulting in twisting and curling of the template and backing paper. Plain sleepers in ballast Sleepers and ballast are laid on white glue (pva) applied with a small artists brush. I found that it is easiest to work in a small area laying no more than 3-4 sleepers and completing the ballast as your go, otherwise its easy for the glue to loose its tack leaving bald spots in the ballast. White glue can easily obliterate the template markings so I first glue the area within the width of the sleepers, place the sleepers in position, then glue the area outside the edge of the sleepers (shoulder or 6') then sprinkle the ballast in place. I then usually place a weighted block of timber or strip wood on top of a finished section of sleepers which helps keep a level top and iron out any crinkling. The layout will be on an L shaped book shelf with the approach tracks to the station on a curve. The turnout from the main line to the loop is part of a crossover from the platform road either to an engine shed or possibly a private siding. I had originally intended to use up my stock of SMP (Marcway) flexible track on the plain track on the layout but discovered that SMP & C&L Bullhead rails have slightly different profiles with the SMP an narrower head. The plain track between the crossovers and approach to the platform and goods yard will be laid with C&L components to reduce potential running problems in this area. The layout is supposed to be the goods only remains of a light railway branch line, some where along the Welsh Borders between Hereford and Chester with quite a bit of influence from the Tanat Valley line near Oswestry but with a hint of the LNWR thrown in. The layout is mainly an excuse to run my British outline main line and industrial stock and a prod to finish some nearly complete loco and wagon kits.
Nice job on the Diner the North Atlantic coaches are so distinctive, a set in LMS NCC Crimson Lake behind a matching Mogul or U2 4-4-0 would be an absolute stunner. I like the idea of combining the Worsley Works sides with the Comet parts, hopefully the business will survive following the owner Geoff Brewins recent death
Just came across this on the Eiretrains web site. Mainly Bell and Liner traffic out of the North Wall 001s & single 141s working most of the traffic, a few surprises including the 62'9" flats on the Galway Liner
My first train ride was from Killiney to Tara Street in a black and tan non-corridor behind a black A or C class some time in the late 60s early 70s. Up to around 1972 CIE used to make up a rake of late GSWR/early GSR stock for summer holiday traffic on the Bray line. The Dapol/Airfix suburbans with their flush sides are fairly close in general appearance to late 1920s built GSR non-corridor stock.
The coaches in the pictures are in preserved condition at Tralee and Tuam the late 80s early 90s. The GSRPS restored several of these coaches in Tralee & Mallow for use on excursions and the Fenit Line some of which found their way to Westrail in Tuam and the last of these coaches is preserved at Dunsandle. JHB is probably the best to advise on livery, photos indicate that some early CIE built stock was painted plain unlined dark green without flying snail logo, repainted into the light green scheme with a single narrow eau-de-nil line at waist height before being painted into black and tan. Lettering in the green era seems to have been in light green (eau-e-nil)
I don't know if its the light colour the Dapol vents tend to stick out like a sore time. The one advantage is that they are separate from the roof moulding, so should be fairly simple to detail the roof of the Side Corridors with the distinctive toilet filler pipework in brass wire and replace the vents with something from Comet or MJT. Coachman (Larry Goddard) had a thread on RM Web on detailing the Airfix/Dapol LMS coaches, including a re-skinning job with etched brass sides, advice on flattening the Dapol roof and detailing the interior http://www.rmweb.co.uk/community/index.php?/topic/67996-making-use-of-dapol-lms-coach-kits/ A slightly more modern version of the Corridor Seconds on Bulleid Triangulated underframe and commonwealth bogies.
The recent thread on modelling Limerick Junction raised interest in building pointwork with C&L and similar systems. I am using the system on a small British Railways layout partially as a decider whether to go with flatbottom or bullhead pointwork on an Irish layout. The C&L system is based on using ABS plastic chairs and sleepers and chairs in combination with nickel silver or steel rail to represent traditional Bullhead track used on railways in the in the UK and by most of the bigger Irish Companies especially the BCDR, DSER,GNR, GSWR & NCC. On CIE this type of track was widely used on the Kerry Road, Dublin Waterford Line and Wexford Lines until re-laid with CWR in the mid late 1990s. C&L supply point kits and individual components many modellers use ply or wooden rather than plastic sleepers cheaper and more realistic. Chairs The C&L system is based on a standard 3 bolt chair for running lines and a slide chair to support the moving switch rails at the toe end of a point. A number of different types of chai are used to support the rails around the crossing and check rails in points, with C&L its basically a matter of cutting and splicing a standard chair. Some systems (Exactoscale) manufacture special chairs. Chairs threaded on to a stock rail Not as tedius as it looks quite therapeutic if you take your time Building a crossing Ready made crossing vees are expensive, I use a jig for filing and soldering the vee probably takes about 5 minutes. partially assembled V waiting to be fixed in place The metal strips are for soldering the "wing rails" in place and maintaining electrical continuity. Model points are usually assembled by first fixing the straight stock rail in place (long straight rail. Then fixing the vee and wing rails in position .... Step 1. Straight stock rail and chairs positioned Step 2. Positioning the vee using gauges. This point is built on a Templot template, the position of the crossing nose, switch and other critical details are marked on the kraft paper backing before the sleepers and ballast was laid. Steps 3-6 jumping a head too fast point almost complete You basically work across from one side to another building a point once the first stock rail and Vee is positioned the second stock rail is gauged from first stock at the toe end and from the vee at the crossing, then the blades and gut rails fixed in position. The track gauges are roller gauges, the brass gauge has sections milled out for gauging across converging rails at switches and crossings. On average it takes me an evening to build one of these points. With the formation more or next complete the next job is to install the droppers for the wiring and tie bars, then weaher the sleepers and ballast, before fixing the assembly on the layout.
Side Corridor (compartment side) Buffet Buffet kitchen side The donor coaches are Dapol 60' Stanier Coaches. Plastic is removed from the area between the windows leaving a strip below the waist and a narrow strip above the windows. The sides are fixed in place with contact adhesive. Comet Kits RTR Conversions and Building Coaches the Comet Way http://www.cometmodels.co.uk/ are probably the best instruction for this type of modification. Comet recommend gluing the roof to the body before cutting out the sides when carrying out this sort of conversion. The flush glazing units on original Airfix/GMR/Dapol coaches were also used to lock the body in place on the floor and locate the roof. I have built the models with removable roofs clipped in place to strips cut from the old glazing units glued to the remains of the Dapol sides. I may be possible to kitbash the Dapol interior to fit the Side Corridor coach or scratchbuild an interior using plasticard and Ratio or Comet coach seats.
The first batch of Buffet Car and Corridor Standard sides will be ready for shipping in about two weeks at $32NZ(£16stg)+shipping. The TPO/Tool Van will be available in November. The first batch basically covers existing enquiries/orders, please send me a p.m. if you want to be added to the list for the next batch of sides/TPO kits. 1953 Side Corridor Standard Close up window/door details Iarnrod I am not planning scale width/length CIE coaches in the immediate future or at least I have released the 20t flats and MGWR vans and loco. Tin & Luggage vans are out of stock.
Richie: Great concept with the different era's from modern state of the art the 1860s to the increasingly run-down and obsolete as the port shifted Eastwards. Modelling an urban Irish layout warts and all is a challenge and a welcome change from a country station in a scenic setting. As a South sider I never got to explore the North Wall quays and yards until the late 70s, I will always remember going with my parents as a nipper to see what seemed to be the whole US Navy tied up along the South Quays from Butt Bridge to the Grand Canal Docks some time in the early 60s. To me the most striking thing was the dockside cranes of which there is little trace. Like most ports the Docks was melting pot of races and culture that never really recovered from the loss of traditional dock work and the community being dispersed to Corporation housing estates in the suburbs in Brendan Brehan's words to Hell or Kimmage. The decline seems to have set in from the closing of the LNWR passenger station and hotel when the City of Dublin Steam Packet Company lost the Mail Boat contact to Dunlaoire in the 1920s. Your plan has a bit of the Iain Rice's London Dock schemes about it, not sure about modelling the Quayside sheds (Campshires). Visually they cut off the view of the more interesting 19th Century buildings and streetscape from the river. The North-Wall Liverpool passenger boat also carried cattle up to its replacement by Car Ferry in the 70s, cattle arrived by rail and were driven "on the hoof" down the North Circular Road from the Cattle Market for loading on what's now City Bank and the Dockland University. There was an interesting photo in Heitons head office of a coal boat being off-loaded into railway wagons on the quay outside the Point Depot in GSR days.
For some reason I kept thinking of Dianna Rigg in the Avengers
- 19 replies
- nir railcar
- ni railways
(and 3 more)
Tagged with:
Finescale OO with flexible bullhead track seems to be a good compromise for a large operating layout, you time scale to get the layout to a reasonably stage seems ambitious. Fitting in a layout with a working grade crossing between two main lines is a challenge sneaking the Waterford line around the back seems good idea. The main draw back of the plan for an operations based layout seems to be the rather limited staging, it might be worth while to double the Waterford line from behind the pump house and use it as what the Americans call surround staging to queue trains to go through the Junction. Besides Limerick-Waterford Mail, Liner, Cement and Fertiliser traffic, Bell Liner, Fertiliser & Quigley Magnesite trains regularly reversed at the Junction enroute between Cork and Waterford a very busy place
CIE Compartment Cars - What type of coaches?
Mayner replied to Noel's question in Questions & Answers
The etched sides are designed to fit to the 60' Dapol Stanier body shell. I found that I was simplest to remove all the plastic between the window and then use contact adhesive to glue the sides in place. The first lot of Buffet Car and Corridor Standard sides and the TPO ae winging their way South should be available in October. -
iPhone/iPad Wireless CABS - Setting up JMRI + WiThrottle
Mayner replied to Noel's topic in Tips & Tricks
JMRI with an IPhone or IPad seems a very good approach. JMRI is or can be made compatible with most DCC systems. Interestingly Digtrax has just announced that it is discontinuing the UR91 receiver for its Simplex radio system, potentially forcing users to upgrade to its "Duplex" system at $150US per receiver & $65 throttle upgrade. -
All in less than$ 45 minutes!
Mayner replied to heirflick's topic in Photos & Videos of the Prototype
Well done takes me back to my Irish gricing days Interesting but subtle changes in the close to 40 years since CTC was introduced, signal cabin and relay room survives, the shelter belt by the farm house has grown back in the 20 odd years since it was cut down, crossover between the up and down main lines moved to the North of the Crossover. -
Generator cars for irish coaching stock - specifically HLV
Mayner replied to Junctionmad's question in Questions & Answers
Besides the Dutch and BR vans CIE converted a sizable number of older coaches to Brake Standard and Brake Standard Generator Steam van (BSGV) format in the mid to late 70s mainly to replace the 4 wheelers on Suburban and the remaining branch and cross country trains. http://www.cs.vintagecarriagestrust.org/se/CarriageInfo.asp?Ref=3340. The Cravens as the most modern conventional stock appear to have been converted to TL lighting at an early stage, the all the Park Royals and even some Laminates were converted by the Mid 1980s. -
The 30T vans seem to have been less popular with guards and the Operating Department than earlier CIE/GSR/GSWR brake vans. The all steel body would have been like a freezer or an oven to work in compared to the earlier wooden or ply bodied vans. The original oil boxes gave trouble with overheating and the hand brake was not supposed to be as good as a 20 Tonner. Apart from the running gear and foot boards the main spotting difference was greater variation among 20T vans, planked or ply body sheeting, wooden or steel duckets. Hybrids with a mixture of ply and planking. Perhaps another variation for Des?
Popeye Lovely job on the pallet cement especially the large wheels.
The timber swap bodies were fitted on 27301-27767 series 22'6" 14' wb skeletal flats the last 4w wagons built. These had a sightly lower frame to carry 8'6" containers and a longer wheelbase to improve stability at speed. The channel framing of the swap bodies sat down over the wagon like a saddlebag and hid most of the wagon solebars and underframe.
Great to see the local IE management getting the railway involved in the European City of Culture street theatre events. The event had major spin off effects for Glasgow and other cities that had suffered from poor press. Hopefully its good for Limerick as a city and some of the extra visitors arrive by train. The Giant Grandmother thing reminds me of a cross between Mrs Browne and in Gulliver's Travels'
Running a course to 'facilitate" Irish people to mix and mingle, a bit like selling snow to Eskimos
