Everything posted by Noel
Hi Paul. Horses for courses, different materials work for different folk. I used 9mm marine ply on Kingdbridge when I built the boards 27 years ago. Heavy and not suitable for a portable layout. Built upon 2"x1" formers with 1"x3" on the edges for rigidity. More recently I've used the WMRC box construction sections method with 6mm ply for the top. See below: Laser cut to size by a company in Dublin, very quick to build using a heat gun, smaller pieces easy to assemble, and reinforced joint by fibreglass webbing underneath using PVA instead of resin. Each board is 2ft x 5ft so fits in a car and lightweight so can be turned on their side for wiring, etc. I'm unable to crawl around under baseboards anymore. Very stable and will not warp or sag in time. Sealed with paint for stability from moisture. Takes track pins well. I used 3mm closed cell foam to cover the entire board with a second layer under the track for ballast. This offers good sound insulation as ballast PVA will never come into contact with the ply baseboard creating a sound bridge. Have fun. https://www.efoam.co.uk/closed-cell-polyethylene-foam.php#sheet1 I tried MDF 30 years ago but found it unstable long term and it was a complete PITA as it would not take track pins. Not as good with damp cold air as plywood from a stability point of view.
Thanks Kieran. Much appreciated. Is that second photo one of the other side? (ie they are a mirror of each other)
Does anybody please have photos or drawings of both sides of mk3 EGV? I've discovered plenty of photos of the starboard right side (ie generator aft), but none of the port side. Wondering about kit bashing one for fun. Preferably photos of prototype, but even a photo of a model (eg Silverfox) would be a help. Thanks in advance.
Fab, love the timber off cuts on the lane.
That’s impressive and really useful information
Yes climate action means an almost immediate end to all peat harvesting, already peat power stations are being decommissioned.
I’d buy a half dozen of those. Looks great so far.
Nice idea. As to a 21mm flexitrack product, a market size of 5-10 people may not attract a manufacturer. Any 21mm layout will be hand built track which seems half the attraction.
Leslie we are all flawed sinners in some shape or form, even I have supped with bogie stock and touched forbidden fruit of ultra modern mk3 stock, but if in a moment of weakness the evil one I lures me to touch a DMU, you or Jonathan may cast the first stone, the keepers of the sacred three link coupling, protectors of two axles and defenders against bogies of eternal stench, be they free running or not. Seriously Leslie your kits have been a great joy to work on, and I look forward to more. Totally my era, and a vaccine against imprisonment in the bogie of eternal stench. Thankfully I have not fallen victim to ‘yellow fever’ so no yellow ‘stuff’ allowed on my layout.
Do I have to glue the cork underlay to plywood baseboard
Noel replied to Bill Paddy Andy's question in Questions & Answers
Charlie of Chadwick model railway youtube fame dilutes copydex 4:1 with water and uses it to ballast track instead of pva. He swears there’s no transmission to baseboard guitar, unlike PVA. On a recent layout I’ve used double layers of 3mm closed cell dense foam with self adhesive backing. -
Decent food pub can do 5m/pa handy on food & BEV in the right location. 5m is not a large turnover if your employing close to 100 staff on rosters, chefs, managers, etc.
Go for a cycle on the Westport or Dungarvan, its incredible the footfall some of these new hospitality spots are getting. A captive audience and very very profitable to provision for. There is one in particular on the Westport and its like a mega pub in the middle of nowhere, a vast complex in old stone farm buildings. A huge employer too, and these businesses benefit from a long season including both shoulders and even mid winter business.
Cheers Skinner. I think in future I may still lean towards reverse masking. I cannot abide wavy lines nor wavy stripes. Enjoyed this kit, just grab rails, glazing and some decoration to do.
The Ballasts and Bubbles NEM pocket problem was easily solved as per IRMs own recommended fix, just superglue the kadee tongs to the underside of the NEM pocket for correct height as per Kadee height gauge.There was a valid argument for just plugging into the NEM pockets and correct only the two end wagons on a rake, but I like to be abe to mix'n'manch stock and prefer all stock to be able to couple up together. The Tara's, Fertilsers and 42ft flats had perfect NEM pocket positioning. No 18's seem to work well with IRMs entire wagon portfolio. As an aside, in advance of some scenic work, just recently started clearing the layout of rolling stock and put all my IRM models back in their boxes, almost drooling at the fabulous underside detail one normally doesn't see while running or on the tracks. I decided that whenever the beautiful ballasts come back out of their boxes they will get some gentle weathering treatment. Also discovered I still had 3 boxes of pristine bubbles which I kind of like that they avoided the weathering station. Just gorgeous wagons. Thank you again IRM.
Redemption for the rebuilt Dutch GSV kit from IFM, after the great peeling primer disaster of two weeks ago. Had a second go at this, first time using waterslide transfers instead of reverse masking and airbrush for white stripes. The first attempt two weeks ago didn't end well (below). Lesson learned clean resin bodies properly using unspent nuclear fuel if necessary to ensure no resin release agent residue, and never give up. There's always a recovery route. When this is finished have two IFM Park Royal kits to start. Not so long ago I was RTR man, now finding doodling with kits addictive and therapeutic.
Another mk3 donor bites the dust. Could not get the window glazing out this time so had to resort to tedious masking. Avoided the hideous maskol route, dreadful stuff. Primed with Hycote plastic grey primer ready for reverse masking It kind of gets addictive after a while
One of the successes of the Westport greenway was getting farmers to buy in and convince them the passing walkers and cyclists would not cause problems for their livestock, so it proved, and some of those farms are now running multimillion euro cottage cafes and restaurants along the route. It was dealing with fears and objections from land owners that made westport such a success. I'd highly recommend a visit and cycle along it. Clewbay bike hire are a superb outfit with courtesy buses, will drop you off at achill, so wind at your back, and will pick you up at any of the intermediate stops, so you can do only 10k, 20k, 30k or the full 42k. Stunning wild atlantic coast scenery and cycling through harry potter like scenery and forests over magical bridges and viaducts. A must do for every Irish citizen, and the beauty is its only a few hours from Dublin, no airport hell needed to get there, or better still take the train and pass through Athlone and Claremorris on route.
Minister Ryan should perhaps get rid of his NoX spewing filty diesel car and get an EV instead or getting rid of more rail potential or closing more lines.
Don't like the idea of the Rosslare or Athenry ones. Both could be put back as rail lines, but once lost to greenways there gone for good. Greenways earn local communities vast amounts of indigenous tourism revenue and transform the local economies. Post brexit it looks like our dear neighbours are hell bent on the kamikaze route with a hard over the cliff no trade deal on WTO terms, so Rosslare could gain massive significance as a port that could bypass the UK land bridge handling container traffic direct from Europe to Ireland. The line from Waterford to Rosslare could suddenly become economically viable again for freight traffic and therefore be able to provide commuter traffic to waterford and wexford. Once the line is pulled up for bicycles its gone forever, don't believe the myths about contracts facilitating a return to rail. Local parish pump Politics would stop that. Same goes for Youghal to middleton, huge potential to reopen for busy commuter traffic to Cork as well as seasonal tourism to Youghal. I'm a cyclist and really enjoyed the greenways in Westport and Dungarvan, but enough is enough, how many greenways do we need. Those coastal greenways have amazing scenery, but many on that list are through flat boring bogland with no elevated views nor mountainous scenery, and that won't attract cyclists. Did the Abbeyfeal one a few years ago and it was third world compared to Westport-Achill or Dungarvan-Waterford with their stunning coastal scenery. Kilrush-Kilakee has some merit, but the midlands one to Athlone is bog boring.
Dear Glover. All I can do is wish you care. So sorry to hear. Loved seeing your creative and superb atmospheric modelling. The photos above of the cattle wagon are testament to a wonderful artistic creativity. Sublime scenes filmed in 1950s nostalgia gold. Will pray for you and your loved ones. Take care. Noel These are absolutely stunning scenes. Alive with realism and atmosphere. The cattle wagons turned out absolutely superb and the layout is a perfect home.
Worth waiting for, it’s summer and little indoor hobbies going on. I don’t recall any new Irish model from any supplier that wasn’t at least one year late. Even OO works were late with their J15s. I’ve learned to take all announcements with a crate of salt, even announcements about announcements. A model in the hand has arrived, everything else is a future possibility. No prob happy to wait and impressed to hear MM have picked up on any issues BEFORE Models despatch to customers. Really looking forward to the grey locos, and good point @connollystn about running nose first for interest. Can understand unions exploiting it as a safety issue, but steam locos ran ok cab aft with boiler bonnets for 100 years, so why there was a big song and dance about it in 1962 seems a mystery except as a bargaining chip.
On the contrary the grey 121s may prove in time to be the most desirable and most valuable for collectors. Its' how they were delivered and how many remember them. Also many of the old YouTube depict the grey livery 121s in operation. Commuters probably have an affinity for the tippex 121s.
No MM never did their own 141/181 sound project, just the 071, 201 and now the 121. WheelTappersDCCsound and MrSoundguy have excellent sound decoders for most Irish locos. As to loco renumbering there's loads of YouTube tutorials on this.
No you cannot a) legally copy another companies intellectual property, and b) technically its not possible to extract a sound project from a decoder chip using LokProgrammer. Just like with software you need access to the 'source code' not just the binary output (ie the ESU sound project files that made up a project). Some of the US locos are perfect for 141, 181, 121 prime movers, but there's a lot more to it than just prime mover channels. Need, brakes, air lines, horns, acceleration & declaration profiles, flange squeal, and especially light function mapping. The 141/181 had very simple if not somewhat crude lighting setup but 071, 201 and the 121 have comprehensive lighting options.
