Andy Cundick
Everything posted by Andy Cundick
  1. The other point is i built it so i can repair it,not something you can say about most ready to run today.Andy.
  2. Can i start a list of what i don't want coming out as ready to run as i've already built it,Andy.
  3. It'll be GSW No100 as i've just finished scratchbuilding it,Andy
  4. It might be worth finding a prototype station or track plan which interests you and start with that,it needn't be complex you just need to something running.You can't get much simpler than Valencia but it was up and running quickly and taught me a lot,you don't have to stick rigidly to the prototype after all Valencia sees all sorts from Queens to Harland and Wolff diesels.Andy.
  5. Any rewheeling exercise is daunting it depends on the end result and just getting on with it,one of my current projects is rewheeling the majority of of my Donegal stock from 9 mm wheels to 10.5mm using 8mm spoked lowac wheels and shortening the axles,with about 20 coaches and 70 wagons its taking a bit of time but visually well worth it.Andy.
  6. Bound to happen ,i've been modelling 21mm for years so someones bound to bring out ready to run.Proof i've just finished a couple of old Centre Models industrials(EM gauge),a Hunslet 16"saddle tank and a Kerr Stuart Victory,and surprise surprise both have just been announced in 4mm by a couple of manufacturers,Andy.
  7. Its available as a kit in 4mm from Noneminstre .Andy.
  8. Mike more than up for it,my main issue these days is suitable coaching stock after all you can only have so many GSWR 6 wheelers(apparently)and my rake of Bredins are less than likely vistors west of Cork or the depths of Kerry.Andy.
  9. Now that would be useful as the next 5'3" layout is Ballinacarthy junction,something to give the various Bandon engines something to play on,not sure about the Queens though,Andy
  10. Funnily enough Fenit is on the todo list.Andy
  11. Having built one i can honestly say its a well thought out kit which went together well only problem is coming up with a likely scenario to it appearing on either Valencia or Courtmacsherry.ANdy.
  12. Just compared my No90 with a terrier . wheelbase for the terrier is bigger as is the overall length however the the cab and tanks are roughly the same size and obviously 90 is much wider so perhaps a Hornby chassis would fit(My terrier is a Ks /Branchlines hybrid).Still to be honest 90s chassis is an easy one to scratchbuild.Which reminds me i need to finish 100 where would Courtmachserry be without them.Andy.
  13. We had a funny incident with the Police involving a Foden steam wagon.We were steaming it back from the Model Engineer Exhibition(when it was at Wembley)basically a trundle down the North Circular to Kew Bridge.Anyway we stopped by Hanger Lane to have a quick blow up when a motorcycle policeman came over to have a chat.Now at this point it has to be explained that one thing that steam waggons on pneumatics have is an earthing chain usually down by the back axle.The reason for this if you are using the blower it creates a static charge(a very good one)hence the earthing chain.However its a known thing that to prevent engines being messed about when on display you hook the chain up and leave the blower cracked open,a marvellous deterant.Thats why you often see a fire iron on the deck by the engine an earthing device for the driver.Anyway the Policeman comes up to the waggon and in mid sentence inquiring about the age of her,he grasps the cabside,followed by a large crack and said Policeman propelled back several feet.He was very nice about it Andy.
  14. The waggon is a 1925 Foden C type,they're good for 30 mph tops,the Greenaways who own her have quite a collection,i bought a an Aveling roller of them back in the 80's.but thats another story.Andy
  15. Apparently,Andy
  16. Not quite sure how that leaves me with modelling 1850's GWR Broad gauge through to 1950's County Donegal via 1900's Highland and North British ,1930s Great Southern not to mention the four irish and Welsh narrow gauge layoutsannd i won't mention the Rhodesian locos(Salisbury loco shed anyone?) Andy.
  17. No ,i make them my self with a file and a mini drill(Too lazy to go into the workshop and fire up the old Drummond) Andy.
  18. Just done 4 of the Worsley DNGR coaches with one more to do.i'll have to check but i'm sure i managed to get all the bits from Wizard models.Andy.
  19. A couple of points to bear in mind especially when you're starting the great thing with soldered PCB track is that once assembled it can be tweeked with a soldering iron not an option with other forms of construction,as for rail i use code 75 bullhead NS no one has noticed yet that its been used on Valencia,Courtmacsherry and Arigna and will probably be used on Ballinacarthy.Another source of Sleeper strip is Wizard models who's mail order is first class bear in mind the date of your layout as earlier sleepers were 9 Point foot rather than 8'6".Point vees are easy to do it takes about 2-3 minutes and doesnt need anything more technical than a pencil,paper file and vice.1st draw the the vee you want then extend one line on so you have a sort of a wye.you then bend the rail to that angle so you have the shallow vee,stick it in a vice a file the outer angle of the vee until it is almost breaking through then bend the rail filed side inwards and you will have a nicely filed up vee ready for soldering,simples!(its easier describing this with a diagram but i havn't a clue how to do this on a computer).My main challenge at the moment is a thee way point in bridge rail to 7ft gauge for another project which has been bumbling along,what larks! Andy.
  20. The layout itself is no more,as i wasn't happy with the trackwork on the 3foot side its down to the point radius the stock runs through it all right but for bigger 3ft stock they don't look happy thats the main reason i built my own track for Arigna.Saying that the new Donegal layout Brucklees uses it as i had it in stock and just being a siding it shouldn't be an issue.However all the buildings and signals have been saved and who knows Strabane may rise from the ashes,that said i don't know when as the next irish layout is going to Ballinacarthy junction as i seem to be suffering from a surfeit of Bandon tanks plus it gives the Courtmacsherry stock somewhere else to play.Andy.
  21. Ah Ah memories of the Westinghouse show at Chippenham ,October 1996, 8 irish layouts including Adavoyle and Castle Rackrent.I had Castlefinn there and had a visitor comment that there seemed to be a lot of County Donegal layouts there(3), something i've never heard before or since.Happy days Andy.
  22. Personally all my layouts which use handbuilt track (3 out of the 7 at the moment) are all built directly onto the baseboard that way once its drawn out you can better visualise what you are getting as well as especially with curves using a mark one eyeball you should be able to get much smoother flowing curves.One tip when making point vees/frogs keep the tails as long as possible that way you avoid the inevitable slight kink the curved part of the point.(theres a bit in one of the recent New Irish Lines on a simple foolproof way of doing the frogs).For gauges the Scalefour Society do them but they can be made up with some washers bolted together as can a back to back gauge.Incidently i always use EM standards which at least give you a fighting chance.Andy
  23. The daft thing is its not that difficult,both Valencia and Courtmacsherry were built directly onto the boards,having drawn out the track basically 2 parallel lines first(tip here a 3ft steel rule on its side gives you lovely transition curves),copperclad sleepers then laid on double sided carpet tape and a soldering you will go.I can't remember how long Valencia took but Courtmacsherry took about 10 days in total,Andy.
  24. I'm afraid to say no it isn't. 228 was Castlederg No 28 was a steel underframed 4 plank open bought from Pickerings along with the bogie open No 29 both were numbered in the Donegals goods vehicle series.Whereas the 6 original Castlederg opens 15-20 were the original Red wagons and apparently numbered 3-9,i say apparently as i've at least 2 photos of No2 which is supposed to be a Clogher van but is definitely an ex Castlederg open (been there built the lot) .Andy.
