Andy Cundick
Everything posted by Andy Cundick
The little grey Fergies seem to have got everywhere as well as their successor the red Massey 35 the only place they didn't seem to predominate was around Letterkenny were you used to see a lot of the Fordson Dextas .Grey Fordsons were much older beasts,originally built i Dearborn then Cork until production was moved to Dagenham in 1932 appearing in Blue with orange wheels(traditional Essex cart colours apparently) though my one is in RAF blue grey being an ex RAF tractor,Andy
Simple one that ,yes.Andy
Yes and then again no the DNG tanks were actually DX 060's with saddletanks,the main difference being the wheel diameter 4'3" for the Specials whereas the DX's were 5'2". I built mine using the London Road kit for the Special tank but with the larger wheels and using the splashers from their DX kit which they do as a spare.Worsley does four of the coachesi most say they do jolly up Valencia when they make an appearance.Andy.
Its simple i used that setup for Lochty The trick with the SEEPs is to convert the fixing holes into slots(file or burr)and don't tighten the screws just leave them slightly floating that way you have enough movement for the switch,Andy
Yes please need something to haul my BCDR six wheelers Andy
Quite agree i usually pick up a box of them at Beaulieu Autojumble each year use them on all the models as well as on all my vehicles from Austin to Land Rover via JowettAndy
For starters theres a track plan in Pattersons Book as well as one in the Narrow Gauge Magazine Donegal special No50 i think the Michael Bunch Book vol 1 has the best selection of Derry section photosthere was an article recently in the IRRS Journal on the derailmenti'll sort out some more details when i dig out my Londonderry section album.Andy
Valencia has her first trip out in over three years to Yate next Saturday its been exhumed from the workshop(hadn't seen it in while) currently going through the stock,one or two odd combinations seen at the moment Harland & Wolff diesel on a rake of DNGR six wheelers anyone ? Andy.
Bought a MGW coach it hangs over my workbench as an example a how bad 3d prints can be,Andy
Certainly interested in both loco and tender Andy
The writeup is a bit odd,as Chris refers to "adding bits of plastic to the locos" whereas 4 and 5 are both scratchbuilt in brass,the railcar is a Worsley kit on a Halling chassis,the Beyer is a Gem kit on a Branchlines chassis and the Kerr Stuart is a Meridian kit on an Arnold TT Kof shunter chassis the only thing i did to the Kof is remove the body,no plastic was used on any of the stock as all the rolling stock is brass as well.still as you say Chris does do a good photo,Andy
Ironically the only locos to work on both Valencia and Courtmacsherry were the C's.which out of my time scale but i run one anyway,Andy
John I'll have one as i have kit waiting to be done after all with Valencia you can't have too many J15's can you Andy
It sounds like a problem with the primer my go to primer is an ordinary grey primer done by Upol it hangs on everything i spray with it from etched brass to diecast as well as full size vehicles from Austin to Land Rover via Jowett.Most good motor shops seem to sell it,Andy.
Thanks its the first of my Irish narrow gauge layouts to get into print,both the standard gauge ones have been in Model Rail,funnily enough my North British layout will be in there shortly and my Welshpool layout has just been photographed for BRM,so theres an Irish a Scottish and a Welsh layout,there has to be a joke in there somewhere.Andy
Just to warn you that Castlederg will be in the next Model Rail(out on the 19th),the photos a good as Chris Nevard did them as for the text nothing to do with me guv,Andy.
My latest Donegal layout Bruckless (the fifth in the trilogy) is out this saturday at Swoons Narrow Gauge bash at Ilton Somerset,and at the the Southampton Show,on the 28/29th.Worryingly i keep finding stock i'd forgotten i had that or they're breeding.Andy
Use it neat and use a sealed container otherwise it'll stink the place out,good luck Andy.
Its one of my claims to fame that in my time at Swindon i managed to set fire to the same DMU two days running,i should point out that it was only a matter of time as when a DMU turned up for overhaul it would go into 19 shop up on the jacks the bogies would be removed and then the cleaners would descend on it to clean the underside so far so good.However this consisted of 2 gallon buckets of white spirit largish brushes and loads of blue paper,now the theory was that this would all be cleaned up however as the lift roads were also pit roads which meant that the pits were sometimes missed in the clearup process plus bear in mind the pit boards were wood it was a fire waiting to happen.Anyway once the fitters started on the strip we were often called out to bring a gas axe to cope with some of the more obstinate nuts and bolts,we always took a labourer with us to fire watch,however this day no problem until we just got back to our gang when the cheering and buffer hammering started,i looked back sure enough the pit boards were going well it ended up with flames up to the units gutter before we sorted out.There was then a meeting of various superintendents,foreman and chargehands with us chipping in with i told you so,the upshot of which that no more cleaning with white spirit would used and a less exciting degreaser would be used.No problem,until next day asked back to knock of a few more bits from the bottom of the same vehicle didnt get more than a couple of bolts cut when the cheering started.Management had forgotten to tell the night shift who had finished the cleaning underneath so there i was with a nice set of shiny new pit boards somewhat singed ,happy days,,Andy.
Or can simply use the Wills kit it regauges quite nicely to 21mm gauge and you can have it whatever colour you want,Andy
It used to be the practice at Swindon works,if one of your mates was getting married,that on his stag one of us with connivance would get him a priv ticket and after getting well and truly drunk got him onto the first train availablea word with the guard who was usually up for it and off he wold disappearthe record was York though God knows how he managed it,happy days,Andy.
Sounds like not enough clearance between the worm and spur gear,the point to remember is that if the gear is secured using a grub screw the gear the gear will run slightly out of true . just increase clearance between motor and spur gearAndy.
If its any help i've already built Tailte and have all the bits to do Macha if i make a start on her now i can pretty well guarantee ,an 800 announcement within the week. Andy.
