New Layout Plans
BabyGM
  • Replies 163
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Today I started fitting Kadee's to my fleet
I started with no 201
I used Anthonys guide to fitting the Kadee
After putting it in place i drilled a small hole in the back of the Kadee then put in some brass wire to keep the coupler where it should be
Here are some pictures
B01FED65-E4E6-454C-B1E8-AD4D6A122094-507-00000053204FC2A0.jpg?t=1350144153
66FB10ED-0C88-4003-BDFF-EAE25D24B1C6-507-000000533567C5DD.jpg?t=1350144190
0DE8ACED-CC78-4949-9094-4ED7973595B7-507-0000005354C75C5D.jpg?t=1350144194
I'm also making a stand out of plasticard for the steam engine in my last post to sit on as it dosen't have any use on the layout
As requested by HeirFlick here are some pictures of point motor progress
D1EA431F-91DD-4F07-B3CB-475CC50F3593-109-00000001778AD4A8.jpg?t=1350666883
FB274A1C-108E-4E2B-9E05-E6AD3A4FB4E1-109-000000018074DBEB.jpg?t=1350666887
Also some pictures of Kadee progress, the messiest layout in the world and a stand for the 0-4-0 steam engine
AF2EB82C-DDF1-434C-ACA8-B56F35CBFABA-109-000000018626A237.jpg?t=1350666894
E54F5A5C-E10C-4E7A-9B2E-3F51422889F8-109-000000018FA6F730.jpg?t=1350666899
My EGV
1CFC6D04-3B4F-43E0-A58E-F576C4F7260B-109-0000000195E24FC1.jpg?t=1350666905
DB767ABD-F47C-4263-85C2-5E3256A3A7EC-109-000000019F800E3B.jpg?t=1350666911
4295C2A8-4DA1-4F14-9634-08A060433621-109-00000001A997C194.jpg?t=1350666924
I'll probably put some coach or wagon alongside the steam engine and then the stand will need painting
I started fitting point motors yesterday and I've began to run into problems
I'm using Everard Junctions tutorial as help
Here is the switch board the point in question is in the bottom right corner
EE49E597-A79C-4421-90E7-44B0E07E7E1C-683-000000B219EB300E.jpg?t=1350815527
The back of the switch
7E6A56AF-AD4F-4A08-BC67-2808D6A8D7FF-683-000000B229F4816B.jpg?t=1350815534
The point motor
8E85918C-B0BC-4457-BD59-E9DAF55261A9-683-000000B2361DB7FF.jpg?t=1350815539
The point
14A99222-72F3-4D57-8785-C4A88FD27C8D-683-000000B23E30E555.jpg?t=1350815557
C01B12A3-D093-444B-A353-E82742D16A91-683-000000B2559FDDD3.jpg?t=1350815563
D2C906F1-C040-44C5-9FF8-001F792D9239-683-000000B25FDD7C4E.jpg?t=1350815579
And the instruction sheet I'm using
C1B5FEF5-FA77-48C8-B534-AD26285BD2C5-683-000000B27C94A594.jpg?t=1350815587
I've gone over all the wires and connections a few times and everything seems alright
whenever I go the change the point it just gives off a buzzing sound and when I try running a train over the top part of the point it cuts out
:confused::confused::confused::confused::confused:
any help would be greatly appreciated
  • 1 month later...
Today I decided The layout really needed to be cleaned ,again
So once I got that out of the way I put all of the trains back on
54537414-722C-49B7-8680-39F854836C49-3667-000005E4B49F492B.jpg?t=1355009830
8E57DED0-F195-4082-AA5A-48A5D2022EE2-3667-000005E4C19C8B68.jpg?t=1355009833
D2F93E3F-6D0C-4291-9E42-C1FB4AF80D99-3667-000005E4C79F06A3.jpg?t=1355009837
39D47863-BCDE-42BD-A125-1C3AD8B39D47-3667-000005E4CCE3DAFD.jpg?t=1355009848
AAB72B10-20F2-4021-ABD5-B0759359F535-3667-000005E4D7384BD3.jpg?t=1355009851
4AB8744B-C75A-49A5-9B73-E4DCCE5E470E-3667-000005E4E0256E77.jpg?t=1355009856
6FDB9C27-4F82-410F-B8B9-80947055A8A9-3667-000005E4E7680524.jpg?t=1355009865
I've been meaning to try and sort out my point motor problem for a few months now and sheer laziness has gotten in the way so tomorrow I'll give it a lash and see whats going wrong
Hopefully I'll be able to run trains properly for the first time in about 6 months :trains:
  • 1 month later...
Over the past few weekends I've been re-laying the layout using woodland scenics foam and using Boskonays ballasting method
Here's a few pictures
FE52D6F5-CF62-47F4-BF2B-E6C7CA1527CA-4491-00000AAE09777012.jpg?t=1358545314
I also introduced height to the tracks to I can have a beach on one side and a canal on the other
B0D7FEA1-CF89-401B-983F-E19DCF6D4174-4491-00000AAE14D4625D.jpg?t=1358545317
Tilted corners ,probably not obvious
CBFA1A07-DD24-4746-B2DE-0BA9EF5A8DC1-4491-00000AAE1BA27218.jpg?t=1358545330
7EE54EAF-6329-4B24-9C02-AE0A374FB799-4491-00000AAE2A75D303.jpg?t=1358545347
4B7E8B1B-7CC2-4055-A1AD-D3682F62E941-4491-00000AAE333039B3.jpg?t=1358545359
Edited by BabyGM
Are you using double stacked matches as filler borders / containment? Any idea on what kind of filler you are going to use?
Yes ,concrete will cover most of the freight yard, I need to do another stack of matches as the current line isn't great
I'll use pollyfilla ill probably use whatever I find in the local hardware shop
As a tip, you can buy cork floor tiles from woodies. They pretty much match up exactly to rail height. Am thinking of experimenting with using them as hardstanding, then filler between the tile edge and the track... You can see a similar method here: http://www.rmweb.co.uk/community/index.php/blog/1/entry-44-inset-trackwork-on-keyhaven/
On the upide, its a lot less filler, and should be easier to get an 'expanse' of flat, level surface (you can always spread filler thinly on the tile anyway before painting too)
too)
That looks great I'll certainly look into it, It appears alot easier than the usual method
Thanks
  • 3 weeks later...
Hi guys
At last i got a CDU yesterday which means I can get my point motors to work, This morning I wired in the first motor and then tested it
It threw the point no problem but when tried to drive a loco over it it just shorted
The point is electrofrog, insulating fishplates on all rails, no droppers other than the wire going to the frog from the Seep PM1
So does anyone have any advice into where I'm going wrong
Here are some pictures of the point in question and 082
DFA702F7-A4FF-49EE-8BEF-A5422FC2C16E-1522-00000485F7E6DFF2_zpsf25040de.jpg?t=1360425006
21FEDC98-003D-4BB9-8AC3-1E24156CCA16-1522-00000485EC963006_zps5e98ca01.jpg?t=1360424998
97B5B802-0BF7-4416-ABC8-B57F6221451D-1522-00000485E159CDAF_zpsd479b392.jpg?t=1360424991
1A493314-E896-40E5-ABB0-FD84ED6371C7-1522-00000485CFD8B25F_zpsb7967c62.jpg?t=1360424984
and a video of 082 trying to get across the point
s1096.photobucket.com/albums/g329/brianwalshmk3/?action=view&current=92E033F1-DAD3-4D27-A015-E0517D475C45-1522-0000048603791EBA_zps6b0a44dc.mp4
