Hornby J15 isn’t far off. Stick a smokebox wheel on it and flying snail on tender and you’re well away. It will pass for a generic Irish 0-6-0. Try and get one in LNER livery as that won’t have a smokebox numberplate.
Let’s hope so, but I suspect it’s only because of the pruning that we have as much left as we do. I well recall Sligo in the 80s - Sligo Leitrim crews could still have brought a train in under semaphores, shunted down the quays, and then turned the loco and put it in the shed. All that infrastructure was still there. It was glorious, but it couldn’t last. Thanks to Ernie for this 1987 pic.
Early Black and Tan Livery (late 1961, early 1962)
Galteemore replied to Mol_PMB's topic in General Chat
Fabulous livery and so iconically Irish. For some reason, when I was growing up it put me in mind of a liquorice all sorts… -
Great stuff Darius. Are you switching frogs and if so, how? I used w-i-t on a layout once and used separate rockers, but I know there are various ways…
It’s so long ago, that the VS never mind the Sligo tanks had never even touched Irish metals yet. But what a design the Jeep was. Still the RPSI’s most operationally effective loco - even if 171 is the most attractive!
Galteemore replied to Patrick Davey's topic in Irish Model Layouts
And a little touch of a red fine-liner would do the trick … -
It’s not 100% right. Should be shaded red. I have an ancient 7mm set from North Star - see below But it’s very close and will look fine ! -
Numbers 145-149 is your range of choice I think Patrick, as the model is of the 1948 batch rather than 1937 (you can tell as it has 3 plugs on the firebox). You’ve made a great job of that. I’d probably use a small amount of Humbrol ‘metalcote’ gunmetal on the handrails which will relieve the colour scheme a little. -
Yes, quick smear of PVA on a fingertip should sort. Looks a great setup and some nice atmospheric shots by @LNERW1 show it off nicely
Great stuff David - always a relief to get to this stage. Taking shape nicely.
Fabulous work all round Patrick. Sad though it is to see Brookhall go, this will be a more satisfying layout to operate. The greater sense of space also tells here. The U with a healthy rake doesn’t look crowded or compressed. I think a backscene - simple sky/landscape - would set it off very nicely. -
I’m most grateful to those who post links for scarce Irish items. It has scored me a few 36.75mm locos. Including this SG2 - it’s on the workbench since last night for minor work - which arrived as a restoration project and is absolutely delightful. Other stuff I have passed on as the duty etc works against me as a GB resident. So Paul, and those like you, please don’t stop!
Don’t know how I missed this before. Am planning a layout - a proper working one rather than a diorama as before - and turned to my trusty Gauge O Guild books. And look what jumps out….from our own @Northroader Name clumsily expunged by me BTW - it’s not a fault in the original
Galteemore replied to IrishTrainScenes's topic in General Chat
Great stuff Patrick. Just need to get some coal in those tenders! -
The NCC certainly had some ex MR stock, and the RPSI had at least one IIRC. I have a vague memory that one of them had now gone back to GB. One ex MR coach, 68, has recently been restored and runs on trips within the Whitehead site.
Jet 2, Brute ?
@Paul 34Fhas been very helpful to me on GN coaches
I have zero interest in this - not my era, not my thing - but have made a donation. Why? Because 50 years ago we missed the chance to preserve the last Irish cattle wagon, a synecdoche of the classic Irish freight scene. Let’s not make that mistake again. We always say ‘they should have preserved X…’ now’s your chance!
Thanks Paul. Was thinking mostly of the inside cylinder version. I just know that many people would be happy with a steam loco that looks more or less right, given that no workaday RTR Irish steam loco seems on the near horizon ! I wasn’t even considering 21mm. If my experience in 7mm is anything to go by, when modelling 5’3 steam to scale gauge, you really need to build the whole thing as such from the get-go, such are the clearances involved. I retro-fitted a loco from 32 to 36.75 once and wouldn’t do it again .
It’s a pity that none of the chassis are generic black wheels. Would surely be an ideal 3d body print opportunity to produce something Irish. The dimensions must be a rough match for something 5’3!
Have checked out the handbook on Irish industrial locos and it certainly wasn’t a powered line. As Eoin says, perfect way to do such heavy lifting. I remember seeing such a line at the Acropolis in Athens c1984 being used for heavy stone transportation. image courtesy ‘Industrial Gwent’. Just across the Irish Sea was a fascinating line, detached from the BR system, which did similar work with ancient locos. Search ‘Holyhead Breakwater Railway’
