Everything posted by murrayec
Hi Noel That's a fantastic job, very expertly done Eoin
Hi all Another layer down, this time gorse bushes- chopped up sponge, poster paint and a bit of yellow flock. The work crew were out chopping up a fallen tree for firewood..... and of course the coffee, cake n trains Eoin & CM
Excellent David That is superb Eoin
Experimental livery - IE Freight Grey Coaching stock
murrayec replied to Noel's topic in Photos of Models
Hi Peter My N layout has r1 & r2 curves and all locos n stock go around OK, if using standard N couplers there is oodles of space to get around... Don't know what chassis your going to use for Irish diesels but the BR Class 20 is good for 121s, Class C, & 141, BR Class 66 is good for 201s, and BR Class 30 is good for Class A. All these chassis are a bit long but hard to reduce in size, they all go around my layout OK.... Hope that helps Eoin
Hi Tony It's looking great Print out your sign from a computer, a program like word allows you to draw and set up the panel for the sign and print in whatever colour you like. Before cutting out the sign from the sheet cover it with Tranpaseal, you know the transparent sticky plastic sheet for covering your school books! This will protect the printed ink... Eoin
Hi David Its looking great, sometimes I reckon the chaps that design these kits never build them! By your cataloguing of this build provides info for those that are yet to have a go.. I defiantly will, its a great looking machine and have added it to my project list Eoin
Hi John Looking good, nice little bits Eoin
Hi Nelson Good one! Yes I had, but it is a bit more of an involved turning exercise, I thought I do the wheel as supplied first and test it, if I experience shorting problems then turn version 2.... The supplied cloth with the unit wraps 4 times around the friction wheel and as long as the cloth is renewed regularly version 2 may not be required. The cloth is cut strips of J-Cloths and I saw in Lidl today they come in multi colour packs!! Eoin
Hi I tuned a lump of brass last night, I worked out the diameter to be 19.5mm by scanning the drawing from the instructions, getting it to scale and tracing it in Autocad to create a drawing. I also worked out that there is a slight chamfer required on the ends as there was marks on the chassis showing that only a centre-point was touching the sides... When pushing the unit along that little bit of track I can feel the knurl hitting the track (the instructions warns against doing this without the cloth) I reckon this is going to work quite well, I will report back when a test is done... Eoin
Hi CM Thanks, hey post up some photos I'm dying to see how the gorse dried out? Eoin
He did but unfortunately I was out for those six days, sure look at what we got.... Eoin
China Trees to Irish These shiny green China trees need a bit of attention for the layout So a bit of spraying was done and this is what I used Green & and a little brown mixed and sprayed overall, black added to the pot and sprayed here n there from underside to give a bit of shadow, and then yellow to give a highlight sprayed random from above... Eoin
Hi This was given to me yesterday, a Centerline Products Track Cleaner D36, unfortunately it's missing the friction cleaning wheel..... but a lump of brass will be turned to produce this and all will be OK again I've seen pictures of these before and now I get to fix one and try one... Eoin
Hi The Ferris shot is a bit dark and hard really to tell, Ciaran's shot on his site, is in good light and it doesn't look like black;- http://eiretrains.com/Photo_Gallery/Irish%20Locomotives/121%20Class/IrishLocomotives.html#126_196106086_0001_CC_JA.jpg and there is this stuff also;- http://irishrailwaymodeller.com/showthread.php/4218-Why-flying-snail?p=63616&viewfull=1#post63616 Eoin
Hi This discussion on the 121 livery took place some time back in another thread but I cant find it. In researching the livery for a 121 kit I'm working on(from time to time!) I came to the conclusion that its a gold line! added to the front and rear logo/numbering and not on the side, this lead me to believe it was done for visual reasons, you can see the grey and yellow have poor contrast with each other in the above photo- especially at a distance. If you check out the 121 colour photos in the Huntress book and the Boocock book you'll see its back n front only, especially the Huntress photo of the cab end in the sunshine its not black or white, its kind of brown! Eoin
untilTrain & Model Fair at Bray Wheelers Clubhouse, Schools Road, off Boghall Road, from 10.00 to 2.00
Hi Glenderg I did get paint on it tonight, its excellent, one can manipulate the chassis on the jig or move the whole lot for those hard to reach spots! Even stand it up vertically, should have made one of these ages ago... Eoin
Hi All Thanks for the great comments you all, I made a chassis painting jig for this project and more to come... See here for more photos and small description;- Eoin
Chassis Painting Jig When painting large chassis the usual option is to paint one side, wait for it to dry, and then turn it over and paint the other. I would like to paint the whole in one go- saves time and gets a better all covering coat in the one go.... So I made this- a chassis mounting & turning jig 19mm plywood base, 19mm MDF uprights- one fixed and the other adjustable, two 10mm dia aluminium rods with threaded holes- for attaching aluminium brackets from the chassis to. The MDF is drilled to a snug fit on the rods and actually holds the chassis in any position, there is a M4 pinch bolt in a threaded insert on one of the MDF uprights if needed. The brass knurled rotating knobs and brass rod stops are not fully required to make it work, but it makes a better jig and finishes it nicely. Eoin
A few shots of the chassis, trucks and bits prepared for blasting and painting. Little wood dowels are fitted into the wheel bearings so that the bearing does not get sandblasted and ruin the running surface, these are also left in place during painting. All blasted, that lovely sparkly surface is the best finish for the etch paint primer. Within 10mins of blasting three light spray coats of primer given with 20mins between each and it now looks like this. Eoin
Hi Tony I use a head magnifier nearly all the time now, the advantage is hands free and as you move around it's with you all the time- no reaching around the place and a stand getting in the way! I recommend the best type you can afford- these are the best, ground glass n all;- http://www.vikingopticalcentres.co.uk/product/optivisor-headband-magnifier-package-offer/ or, on an economy budget the Expo type head mafnifier (plastic lenses) can be got online or in your local model shop for less than £20 Do the better one if you can and they have other cheaper options Eoin
This €2.00 bargain box SanteFe tank loco came to the workshops missing its smokebox door and front hook sheared off. While contemplating what to do American Phil at the Bray Fair had the very thing to make the mould pattern- the same loco for €15.00 So off with the body and I set about making a mould shuttering around the smoke box door. I used plumbing washers n pipes to do this, as one will find these items all fit into one n another, and with a bit of sealing here n there with Stickitall and Blue-Tak I was pouring silicone rubber. The sparkly gold half spheres are there for the second side of the mould if needed- always offset the position of these so that the mould will go together only one way. Yes, they are girly things, found in Hickeys but very handy for this stuff. The moulds complete and some of the plastic cast tests. The hook mould making was not photographed! It was done with the blue moulding putty on the underside of the hook up against the buffer beam with styrene card shuttering all round and carried up well above the hook so the second side of the mould could be poured with silicone on-top of the hook. You can work it out by studying the mould. A bit of trimming is required on the hook and the smokebox door came out grand the third time, you can see air got caught in the lamp shade in the right hand door- this is removed the second time around with a pin swished around in the mould before the plastic set. This project is on the high shelf at the moment, I will post a picture when complete... Eoin Edit;- I forgot to say- I filled the light hole in the smokebox door with plasticine as I did not want the silicone to go down the side of the bulb in the lamp, this could tear the silicone when releasing the mould off the pattern!! This will be drilled out for the bulb.
