Once you ballast over the foam pretty much all with give similar results noise wise. The best noise cancellation I've seem came from using gauge master/noch ballasted foam rolls. This is basically foam roll pre ballasted with noch granite made to fit standard track. You slot it into the track and glue it down. Noise reduction is nearly 100% and it looks like perfectly ballasted track. You can then get bags of matching ballast to go between lines.
http://www.gaugemaster.com/item_details.asp?code=GM200
http://www.shapeways.com/model/89699/cie-2-axle-timber-wagon-oo-scale.html?li=search-results&materialId=6
Is another option for the 20' version. I've a few of these and they are good too.
You can buy chip harnesses very readily, and to my mind they are a great way to 'future-proof' your dcc upgrade. You will be able to replace the chips down the line as needed.
The layout threads and blogs are the place, but I know what you mean in terms of a browsable gallery type listing, where you can avoid the 400 pages of chit chat and just drool over the layouts
