Everything posted by Mayner
Would you model in 21mm if RTR track and models were readily available?
Mayner replied to BosKonay's topic in Irish Models
I think it would be challenging enough developing a 4mm Irish rtr broad gauge track system without going down the rabbit hole of Australian, South American, Indian, Iberian broad gauge. The biggest challenge would be in developing a 'Universal" broad gauge track system that would allow a continuous run layout to be built in a similar space to the same layout in OO, without having to significantly distort the scale of the model. The track and wheel standards cannot be considered in isolation otherwise a manufacturer cannot achieve reliable running. It may be necessary to reduce the track gauge below 21mm to achieve sufficient running clearance on curved track when using NMRA 110 wheels to avoid having to increase the width of locos and stock. From experience 30" radius was the practical limit for 21mm main line diesels and bogie stock using EM profile wheels which have a narrower tyre width than the NMRA110 wheels used as standard with modern rtr rolling stock. In practice it was sometimes challenging fitting EM profile wheels to locos and stock that were designed and built for use on 21mm gauge track, it would be extremely difficult to design or manufacture a 21mm gauge steam outline loco with NMRA 110 wheels capable of running around a curve without having to increase the width of the body, and or move out splashers or outside cylinders if fitted. -
I cheated a bit and fitted handrails and ejector pipework since the last installment. Handrails and pipework are a mixture of 0.45 & 0.9mm straight brass wire from Alan Gibson and short and medium handrail knobs & fine copper wire from the same manufacturer. I drilled out the holes for the cab handrails using an 0.5mm drill and a pin chuck and opened up the holes for the handrail knobs using a taper broach, checking for size with a handrail knob held in a pin vice/chuck, the ejector pipe is held in place with split pins formed from soft copper wire, threaded through the holes in the boiler wrapper and ten soldered in place. I used a piece of thick card as a spacer between the handrails and cab side securing in place with a small stainless steel clamp while soldering the handrail in place form inside the cab. Allowing for OO and 21mm gauge is the biggest challenge in designing the cab interior for an Irish loco. I decided to design a single cab interior that could be assembled in either gauge rather than the two separate fold up interiors incorporated in the design of the MGWR 2-4-0. Splasher/seat assembly, the half etched line in the splasher top/end is for the 21mm version. OO splashers sub-assemblies I am not happy with the excessive width of the OO splashers and will revise this aspect of the design in the production version. Splashers reduced in thickness, with cab floor slotted to fit between loco main frames still not 100% With the loco detailing substantially complete its time to detail the SSM tender. 98s tender is "borrowed" from an SSM J15 kit detailed with a combination of SSM and my own detail castings I decided to mount the springs on 0.45mm brass wire so that the springs can be fitted in place after painting the tender. I drilled the backs of the springs 0.5mm before soldering the pins in place with 100° solder.
OO finescale/EM & S4 profile wheels are manufactured by Alan Gibson WorkShops (AGW) http://www.alangibsonworkshop.com/ and Ultrascale Products https://www.ultrascale.uk/. Ultrascale is basically a bespoke manufacturer and will supply 21mm gauge wheels to order difficult to predict lead time in the current circumstances. My preference is for Ultrascale wheels as they are to a higher spec. but also use AGW wheels particularly for steam loco driving wheels a AGW produce a wider range of suitable wheels. I published a tread on the pros & cons of applying EM/OO fine standards to Irish Broad Gauge in 2018. Templot "Irish EM' appears to have been developed by Martin Wynne as EM+2mm similar to his advocacy of EM-2mm to achieve improved running with current OO gauge rtr rolling stock. There may be some advantage in using the Templot standard for re-gauging Murphy Models diesels & IRM bogie wagons while retaining the original NMRA110 wheelsets, but rtr coaches and 4 w freight stock would require modifications/replacement of bogies and running gear for a wider gauge.
The smokebox design is fairly typical of etched kits with a half etched wrapper with rivet detail that fits around a fold up former. The former is designed to fold up from a single piece of nickel silver with a spacer to keep everything square, in this case I managed to solder the spacer at an angle, but the overall assembly is square and vertical. Test fit of smokebox former to check that boiler is sitting level before fitting the wrapper. Paper to protect the wrapper in the rolls. Soldering the wrapper in place, the GSWR waisted smokebox wrappers are challenging to form, I checked that the bottom edges of the wrapper were even the same distance from the bottom of the wrapper, before tack soldering the wrapper to the former at the top of the smokebox the re-checking before soldering the wrapper to the top half of the former, then repeating on the other side. I then dressed the skirted section of the wrapper to the former, using suitably sized dowel/aluminium rod as a former then soldering in place. Smokebox front waiting to be soldered in place. I thinned the front of the smokebox former then sweated the front of the wrapper in place, working along the bottom edge of the overlay and the rebate for the smokebox door, this reduces the risk of getting solder on the riveted detail. I use a similar approach soldering the wrapper to the former. Completed smokebox assembly bolted to the boiler, everything sitting level. Starting to look like a loco? Major assembly complete interior and backhead to be fitted
There was a thread on this forum on converting IRM wagons to 21mm gauge during 2018 including the ballast wagons. The modifications in the new Irish Lines article appear to be similar to those in the IRM thread. The Bubble Cement may be a more straight forward conversion as there is sufficient width between the axleguards to fit 21mm gauge EM or S4 profile wheelsets but not the wider NMRA110 profile wheelsets used in the majority of rtr rolling stock.
One of my Murphy Models 141s developed a mysterious fault which I tracked down to a dry joint between the Bachmann Circuit Board and 21 Pin Decoder interface. The locos is pretty much a 'shelf queen' in a display case and has seldom run since purchased when the locos were originally released. The loco failed to respond to the controller in any way shape or form which pretty much isolated the fault to the circuit between the wheel pick ups and relevant pins on the 21 pin plug. The biggest challenge was finding a reference to the decoder interface that provided a clear illustration of the pin out layout 21 & 22 in the case of track power. It was a simple exercise with a continuity tester to detect the fault which turned out to be a dry soldered joint between the board and in this case pin 22 On inspection it looked like the solder had not penetrated fully around Pins 21 & 22 during the surface mounting process. I re-soldered Pin 22 with a fine tipped soldering iron and a dot of multi-core solder The repair seems to have done the job, it will be interesting to see if a similar problem develops with pin 21.
The Grinch (NZ Customs) intercepted my haul of Gypsum wagons on Christmas Eve, on the plus side shipments of 121 locos slopped through under the radar.
I have been scanning my collection of slides and photos from the late 70s to early 2000s and concur with JHBs observations with very few photos of dirty or run-down locos or stock before 2000. Although both classes of Metrovicks tended to get dirtier quicker than the pure bred GM Classes, I struggle to find a photo of a dirty 001 in my collection. The effect of weathering is tied up with viewing distance a loco or train may look quite clean from a distance and quite dirty close up.
I didn't get far with the new layout apart from replacing the stationary decoders on the staging/branch line baseboard with a Triang lever frame which I last used about 14 years ago! I had successfully used the Lenz Decoders to operate Peco point motors, but the Seep motors have a heavier current draw and could potentially exceed the current rating on the Lenz Decoders. The baseboards were successfully re-located to the house on the weekend to free up space in the workshop to start work on a 4mm 21mm gauge layout, which is a good incentive to get the N gauge working and complete some basic scenic work. The big decision at this stage is whether to model the background in the down town area as a typical Appalachian steeply wooded hillside or as a more industrialized area with more large structures and buildings. Unbalanced. Balanced Digital vs 60s technology. Digitrax "Duplex" walk around radio control for running trains and Triang level frame for controlling switches (points) The Mission Control Office, Workbench, Keadue and archive. Keadue is firmly in the Analogue age, points are operated by "Blue Point Motors" (push-pul rod with built in auxilary switches). Trains are controlled by simple hand held Gaugemaster & hand built controllers that plug into DIN sockets mounted on the fascia, one for the main line one for the yard. Section switching is through the 'Blue Point" auxilary switch using Stewart Hine's "linked section control" concept which basically eliminates the requirement for a control panel or separate section switches, a couple of section switches are used for isolating locos in the loco shed coal stage area. Back to where it all started Dublin c2001 Kato D&H RS2 switches the warehouse complex on the old Binghampton layout.
I built a whitemetal MIR 141 in Supertrain livery in the mid 90s. Solder assembly with added detail on a simple brass chassis with shortened Athearn GP35 drive, would pull any train with the combination of all metal body and all wheel drive. I also built a pair of 121s in IE livery but whimped out and used Athearn SW1500 Chassis, the 121s were let down by my crude attempt at the IE Tippex stripes. I sold them before heading South, would make an interesting time capsule I wonder are they still about? Before the days of DCC or sound! my attempt at 132 assembled from a whitemetal MIR kit a little worse for wear and crude Tippex stripes.
The 23 & 72 goodness gracious David! As a kid in the 1960s my mother used to take the 23 to visit her elderly aunts in North Richmond Street and the 72 to visit her sister off the Oxmontown Road usually R or RA busses, for me the highlight of the 23 was a brief glimpse of the railway at Island Bridge Junction though I didn't get to travel upstairs unless my father came along.
The Christmas bottle of whiskey or brandy to important clients and customers was pretty much an expectation in the construction industry in Ireland and to a lesser degree the UK. Quite a different culture in New Zealand where there is no similar expectation and clients appeared genuinely surprised to receive a Christmas present.
A classical historical/heritage building dilemma, no income stream to offset the cost of owning/maintaining the building. A Civil Damages claim would probably cost a lot less than restoring/renovating the old station. Perhaps Kilkenny City Council or a local historical group could take over responsibility for maintaining the old station if CIE are unable to find a tenant.
1100 & 1101 later B113 & 114 were built with oil fired steam heating boilers similar to British Railways diesels. The boilers were removed at some stage after the "Tin Vans" were introduced in the mid 1950s. The UTA heating van looks like a shortened version of the self-propelled armored trollies built by the NCC during WWII. The trollies were disguised as bulk cement wagons and fitted with a Leyland engine, gearbox and transmission and were intended to patrol the NCC lines to detect sabotage.
- 35 replies
- 2
The brake van roofs are slightly lower than the H Vans a distinctive feature of the prototype. The decorated sample was to test whether the printers could achieve the required standard before producing the more complex post 1963 scheme with CIE roundels and ducket wasp stripes. 23580 Grey Post 1963 B23586 Red Oxide late 1960s Unfortunately the project experienced a set back this week, our printer received notice to vacate their premises in February which is likely to have a knock on effect on production. I hope to make an announcement once I have clarity on the printing situation.
Mayner replied to Glenderg's topic in Photos & Videos of the Prototype
P J Flannigan's theory for "The King" retaining its nameplate was that the loco seldom left Ballinamore Works yard as the loco tended to spread the track on the curves. No 8 is supposed to have 'lost' her nameplates at some remote spot on the Arigna Tramway. I wonder did the GSR melt down or sell the plates. -
The Heritage Officers main role appears to have been protecting IEs interests in connection with maintenance, alterations to or demolition of Protected or Listed buildings and structures. A lot of his work was tied up covering off the "Heritage" aspects of major rail projects during the late 90s early 20s. Such as the Kildare Route Project, Heuston Station re-modelling and improvements to stations like Kilkenny, Mullingar and Dromod where existing heritage buildings were retained in the new station design rather than being demolished and replaced with more utilitarian buildings.
We received the decorated sample of the van in the CIE Flying Snail scheme today, so could not resist doing an update this evening! Working with an Auckland based pad printing business & SSM to produce the graphic design was the final piece in the jigsaw to produce the Brake Van as a rtr model as opposed to a kit. We have finalised the 3D CAD work for the model including a re-designed roof and removable NEM coupler pockets to allow modellers to fit their personal choice of couplers. The van will be supplied in OO with either Markits or NorthYard NMRA 110 profile wheels and tension lock couplers, the van is designed to be re-gauged to 21mm either by pushing out the stock wheels on their axles or replacing with EM or P4 wheelsets. The brake shoes are a push fit into rebates in the chassis. The production version will be 3D printed in resin using SLA technology as the numbers did not stack up for a plastic injection moulded model and resin casting was not an available option. There are a few issues related to the limitations of the 3D printing process which we hope to resolve including those little dimples visible in one balcony end. We expect to start marketing the model through on-line media and the Model Press during the first quarter of 2021 for potential release in Mid-Late 2021
- 10 replies
- 17
B125 & 126s arrived this afternoon 7 days after shipment from IRM in Dublin & just a day late for my birthday.! Meanwhile B131 is on its way from Rails wonder when it will turn up? B121 was fine after its journey 126s with a broken leading vacuum pipe and damaged snatcher on the 2nd mans side. The big question is whether they are re-gaugable to 21mm and to find a space in the display case for them along with my other Murphy Models diesels
There are several photos of B121 Class in as delivered condition in the IRRS flickr album The B121 appear to have been delivered with twin marker lights on both sides same as the Metrovicks and B101 Class Sulzers. The G611 & B141 Classes appear to have been delivered with the 2+1 arrangement. In practice locos seldom ran with the marker lights illuminated (in day light hours anyway). On CIE/IE loco head lights were not used in daylight hours until an instruction went out in the 1990s to run with headlights illuminated in daylight hours. Light locos would have carried a separate tail lamp to indicate the train is complete rather than depend on a single red marker lamp.
New Ross must have been an interesting place to shunt in loose coupled days and an interesting model especially if you like corrugated iron buildings. A single long siding served the goods shed loading dock and cattle bank accessed by the pair of crossovers outside the goods shed all movements to and from the main line to cattle bank out of the photo on the right would have involved a reversal. The 'head hunts' to the right appear to have served the turntable and loco shed in DWWR/DSER days.
The instruction to operate the B121 Class cab first and the cutting of louvers in the cab doors arose as a result of an incident involving a p.w. trolley at Straffan shortly after the class were introduced. Restricted visibility running long hood first and an insulated cab contributed to the incident, the driver apparently did not hear the detonators the p.w. gang had placed on the line exploding when the train entered the possession. Apparently drivers really liked the comfortable sound insulated cab with American AAR style control stands when the locos were first introduced, some apparently preferred to run long hood first and for a short while ran their locos accordingly. Drivers were less happy about the drafts and increased noise levels after the levers were cut in the doors.
The paint shops were busy in recent weeks with the RSL saddle tank. After considering a number of different liveries including Black, Dark Blue and Crimson Lake the workshops settled on red (from a Ford aerosol) to match the companies Austerity 0-6-0ST and the preserved example Isabella https://www.eorailway.co.uk/enthusiasts/rolling-stock/isabel/ though with a less complex (cheaper version) of the livery. The main components laid out for assembly, one set of driving wheels swaddled in masking tape. I first spray painted the loco in maroon and left of a week for the paint to cure before masking with Tayima tape before spray painting the running plate, and other components black. I then gave everything a coat of clear laquer and left to cure for a day before starting the final assembly. Chassis with most of the wheels fitted, showing inside valve gear and compensating beam. I usually build sprung/compensated locos with all axles running in removable horn blocks, but assembled this loco in the traditional manner for a compensated loco with a fixed rear axle. Chassis with cylinder crossheads and motion bracket & lower boiler sub assemblies fitted. Everything is designed to slot in place, though I seem to have mislaid the brake gear during the 16 years the loco has spent in storage1. Loco with cab running plate and saddle tank test fitted. There are a number of dings and dents in the tank as I over annealed the saddle tank wrapper when I initially assembled the loco. The handrail needs to be straightened on one side as I managed to damage it while removing the masking tape. The kit was designed for the cab, running plate and saddle tank to be assembled as a single unit, I am planning to modify this to bolt the saddle tank to the cab with some form of latch fixing in the smokebox. I managed to destroy the original coupling rods by boring out the holes oversize during the initial assembly and had to make a replacement set of rods which will be fitted at the next stage of the assembly.
I didn't have time to do anything on the modelling front during the past three weeks, but made some time to do some work on the 52 Class this afternoon. The kit is based on a locomotive with a raised round topped firebox, which adds a number of challenges to both the design and assembly. The boiler and firebox is designed as a sub assembly, with a bayonet fitting of the firebox into the cab and a bolt fixing to the smokebox, so that the whole sub assembly can be removed for painting. The firebox and boiler sections are joined by a cast brass step ring. The step ring was cast from a 3D printed pattern. I used a tool makers clamps to secure the step ring to the firebox during soldering. I used phosphoric flux (home mix) 145° solder and soldering iron (55watt)with a chisel tip to solder the casting and sheet parts together. One of the challenges of building Victorian locos with large wheels and small low pitched boilers in OO! I basically offered up the boiler and firebox to the running board checked that everything was level then scribed the splasher outline on the boiler wrapper and cut away the metal that would foul on the driving wheels using a fine toothed piercing saw. I soldered the step ring to the boiler once I cut away the surplus metal from the wrapper, I again used a toolmakers clamp to align and secure the boiler to the firebox while Soldering, the step between the boiler and firebox is approx .5mm and used a piece of metal cut from the boiler wrapper as a packing shim during soldering. While the cut outs in the boiler worked reasonably well I need to remove more metal from the firebox wrapper to achieve sufficient running clearance for the wheels. Thankfully the large cut outs in the boiler are not really noticeable of the partially assembled model thanks to the combination of large splashers and low pitched boiler. The circumference of the boiler wrapper and diameter of the boiler front former needs to be increased to eliminate the gap between the two sections.
