Andy Cundick
Everything posted by Andy Cundick
It used to be the practice at Swindon works,if one of your mates was getting married,that on his stag one of us with connivance would get him a priv ticket and after getting well and truly drunk got him onto the first train availablea word with the guard who was usually up for it and off he wold disappearthe record was York though God knows how he managed it,happy days,Andy.
Sounds like not enough clearance between the worm and spur gear,the point to remember is that if the gear is secured using a grub screw the gear the gear will run slightly out of true . just increase clearance between motor and spur gearAndy.
If its any help i've already built Tailte and have all the bits to do Macha if i make a start on her now i can pretty well guarantee ,an 800 announcement within the week. Andy.
That would prove my point having built both of them,Andy.
You can bet your bottom dollar that what ever it is i either won't need it or will have already built one or more,Andy.
The locos are the Golden Arrow kits which shall we say are of their time,Earl in her unrebuilt form is the first of 4 to be built the idea is to have them in both their original and rebuilt GW forms other than that the layout is finished as i have all the rest of the stock. The Cambrian stock is my chief helpers as he is doing the Welshpool in that period and you can judge who has been operating Llanfair by the preponderance of either Cambrian or GW period stock.Llanfair is after all said and done the model railway layout a Great Western branchline terminus.Andy.
The main thing is to have a go,as thats how you learn after all we all started at the same place.Andy.
The loco is probably an SSM kit as it is in its original state,i ha d to modify mine to its 1930s condition.As to the standards for wheels and tracks i don't understand why people immediately assume 21mm gauge has to be to P4 standards ,i've been modelling using 21mm gauge to EM standards for last 40 years with no problems, as for axles for the drivers i use 1/8" steel bar cut to length with the ends squared up with a file,its around an 12" long depending on the depth of the bossfor pin point wagon axles its 2mm steel rod put in a drill and the point ground on old bit of grinding or a file, 21mm w irons are avaliable from SSM and Priclkey Pear or you can just widen MJT ones coach bogies are eay just use the MJT compenstated coach bogies.As for rolling stock the problem with regaugeing British stock is usually they are narrower best to start off with perhaps a couple of MGW convertibles from SSM,its a fact of life that manufacturers seem on the hole to ignore the 100 years of Irish railway history .If you want a quickie loco conversion then if you havn't done it before then a Jinty may be your best bet nice and simple though not very appropriate Hope this helps Andy.
My next project is a tractor shed as my Fordson has been evicted from the garage to make way for my Jowett Bradford van (useful layout hauler) Andy.
The simple answer to that is yes i am,there is a slowly developing model of Marlborough along with several other projects,the sticking point at the moment is the 3 way point,there is also about 20 standard gauge locos not to mention the layout i'm taking to Warley this year is a scale model of Llanfair Caereinion in the 1930's the classic GW branch line terminusAndy.
My go to for paint stripper is Dettol it works well on metal and plastic with no harmful effects apart from the smell ,Andy
Well it looks like it might be in Model Rail soonish as Chris Nevard did the photos a while ago and they're now looking at an interview to do the article.Andy.
Castledergs last trip out this year at Thornbury Gloucestershire Sat and Sunday.Only Warley to after that but with one of the Welsh layouts this year.Andy
Private Oil Shunter in Dublin Docks?
Andy Cundick replied to Auto-Train Original's topic in Photos & Videos of the Prototype
Whats more Nonneminstre did a kit for that Hibberd model,and it can be rejigged for 21mm gauge ,been there done it,Andy. -
British stuff from the Catacombs
Andy Cundick replied to jhb171achill's topic in British Outline Modelling
And they were 3 rail as well,Andy. -
Some of my handiwork on the front of the 4 CEP,they were refurbished at Swindon,and my bit was brake plumbing in the cabs,a bit of scratchbuilding on a large scale,Andy. -
Photographs of J. Langford
Andy Cundick replied to GNRi1959's topic in Photos & Videos of the Prototype
Might sound silly,but John Langford,he's still alive and kicking as far as i know,Andy -
IRM At The Dublin Show 2022 - Just What Will We Announce?
Andy Cundick replied to Warbonnet's topic in News
Well i can guarantee that it will something i dont need (too modern) or i've already built itAndy. -
I'm there again this year but with my model of Llanfair Caereinion in 009,it looks like i may well there next year with Brucklees all being wellAndy.
Same vehicle the photo also at Strabane was taken in 1947 the only visible lettering on the van is a DR on the centre moulding on the door,though there is a small board up by the eaves on the right hand side with some indecipherable lettering on it.The caption states that its 14 which is quite posssible as the donor chassis is certainly one of the original WDR chassis judging from the grease axleboxes and brake gear so the CVR van inherited the original number makes sense though the link and pin coupling is just weird.Andy.
The point(pardon the pun) with trackwork and points especially is they look daunting until you have a go,Trackwork scared the crap out of me but i was determined to go down the 21mm route so bought an SMP point kit blew the plan up to 21mm gauge and had a go much to my surprise it worked,the second one was pants as was getting cocky.Quite agree with Phil about P4 much more work involved as its that more precise bear in mind the wheels dont have flanges just burrs.One point if you stick to EM the EM Gauge Society commissioned PECO to do basic flexi track and a couple of B6 points.I used it on my North British layout and jolly fine it is too.Andy.
