Everard Junction's tutorials
Some of you may be familiar with 'Everard Junction' on YouTube. For those of you who do not know, he's currently constructing a layout in his loft and is documenting the build on YouTube by posting a series of excellent tutorials as he goes. While he focuses on a UK theme, most of what he does is also applicable when building an Irish-outline layout. Highly recommended for beginners and seasoned modellers alike.
Link to his YouTube channel here: http://www.youtube.com/user/EverardJunction/videos
Does anyone know where he gets those yokes he uses to connect wires to the bus wire as he said a shop in one of the video's comments section but I couldn't find them on the site
I don't recommend using these on DCC as they can cause resistance with some systems causing the system to trip. Always better to solder your bus wires
There's always a risk with insulation piercing connections - soldering will always be better, though a bit more work. There seems little point making disconnection possible, unless it's necessary..
Another vote here for soldering, if you need the flexibility to be able to move / disconnect, then solder links to the bus and the track, and connect both with a choc block / terminal.
