leslie10646 Posted November 8 Posted November 8 Are you going to build York Road (as pre WW2) next - you could have ready for Bangor 2026? No shortage of volunteers to run it for you!!!! 2 4
Broithe Posted November 8 Posted November 8 3 hours ago, leslie10646 said: Are you going to build York Road (as pre WW2) next - you could have ready for Bangor 2026? No shortage of volunteers to run it for you!!!! No point in imposing unnecessary limits - just do the whole island in 00 - it will fit neatly inside Phoenix Park. 6
Darius43 Posted November 8 Author Posted November 8 22 minutes ago, Broithe said: No point in imposing unnecessary limits - just do the whole island in 00 - it will fit neatly inside Phoenix Park. But probably not my spare room - even with T gauge… Cheers Darius 5
Patrick Davey Posted November 8 Posted November 8 Love how the vertical face of the platform changes, suggesting a later extension. Superb! 1 2
Colin_McLeod Posted November 9 Posted November 9 14 hours ago, Broithe said: No point in imposing unnecessary limits - just do the whole island in 00 - it will fit neatly inside Phoenix Park. LOL,but it wont fit in Phoenix Park! Ireland is 300 miles long and Phoenix Park is 2.6 miles (measured along Chesterfiield Avenue)
Broithe Posted November 9 Posted November 9 1 hour ago, Colin_McLeod said: LOL,but it wont fit in Phoenix Park! Ireland is 300 miles long and Phoenix Park is 2.6 miles (measured along Chesterfiield Avenue) Yeah, but the rails don't go right to the extremities. Don't be dispiriting the lad - he's probably already done about a quarter of it... 5
Darius43 Posted November 9 Author Posted November 9 Canopy building painted. Columns made using 2mm sq. Plastruct, plasticard and tape strips. Supporting header beam made from 2mm thick card. The columns slot into the beam and can be adjusted up/down so that they all touch the platform surface before final fixing. Cheers Darius 8 1 1
Galteemore Posted November 9 Posted November 9 Now that’s clever. Were you some kind of structural engineer ?….
Darius43 Posted November 9 Author Posted November 9 I was a civil/structural engineer for 39 years- just retiring now Cheers Darius 3 1
Broithe Posted November 9 Posted November 9 38 minutes ago, Darius43 said: I was a civil/structural engineer for 39 years- just retiring now Oh, how much fun we mechanicals had, showing the old Yellow Pages heading to you lot.. 2
Darius43 Posted November 9 Author Posted November 9 I drew the pattern big scaleee in MS Paint and then shrunk it and printed strips of them on clear decal paper. These strips were applied to the painted valences. Cheers Darius 3 1 1 2
Darius43 Posted November 10 Author Posted November 10 Adjacent buildings constructed. Cheers Darius 7 1 1
leslie10646 Posted November 10 Posted November 10 Hi, Darius May I ask what adhesive you use with the backing board card you appear to be using? I'm impressed by the absence of corner strengtheners. 1
Darius43 Posted November 10 Author Posted November 10 Hi Leslie. I’m using neat pva. As the model station buildings are following the curve of the platform, there are very few right angles… Cheers Darius 1 1
Darius43 Posted November 11 Author Posted November 11 Windows made from acetate sheet (old report covers) with masking tape applied. The window bars are cut away with a new blade. The masked window is sprayed with grey etching primer and then white primer. Once dry, the masks are removed. Cheers Darius 5 2 3
David Holman Posted November 11 Posted November 11 Neat. Have used the reverse of this, where tape becomes the glazing bars, but can see this being more effective long term. 2
Tullygrainey Posted November 11 Posted November 11 3 hours ago, Darius43 said: Windows made from acetate sheet (old report covers) with masking tape applied. The window bars are cut away with a new blade. The masked window is sprayed with grey etching primer and then white primer. Once dry, the masks are removed. Cheers Darius That calls for a straight eye and a steady hand! Great technique, great result 1 1
Darius43 Posted November 11 Author Posted November 11 1 minute ago, Tullygrainey said: That calls for a straight eye and a steady hand! Great technique, great result To be fair, my use of a steel rule makes it a lot easier… Cheers Darius 1
leslie10646 Posted November 11 Posted November 11 1 minute ago, Darius43 said: To be fair, my use of a steel rule makes it a lot easier… Cheers Darius Ah, yes, the first tool to have in the box, the good old steel rule! Do you clamp it down where you're cutting? If I don't the (blank) thing moves! 2
Darius43 Posted November 11 Author Posted November 11 I don’t clamp it down and occasionally it does move - especially on smooth and shiny surfaces like acetate sheet. Cheers Darius
Broithe Posted November 11 Posted November 11 43 minutes ago, leslie10646 said: Ah, yes, the first tool to have in the box, the good old steel rule! Do you clamp it down where you're cutting? If I don't the (blank) thing moves! Cork-backed rules seem to be still available. A lot more friction, but the risk of a slight parallax issue, unless you keep the blade at the same angle carefully. It's not a great problem, compared to the benefit of the lack of slippiness. 2 2
David Holman Posted November 12 Posted November 12 The dreaded parallel - though I'm sure you can get some cream for that. For many years now, I've been using the knives with snap off blades. As it is only the tip that goes blunt, every snap gives you a new sharp one. 1 1
Broithe Posted November 12 Posted November 12 35 minutes ago, David Holman said: The dreaded parallel - though I'm sure you can get some cream for that. 3
Darius43 Posted November 12 Author Posted November 12 Whitehead - UTA best kept station Cheers Darius 1
Darius43 Posted November 13 Author Posted November 13 Delightful 1960’s Station Bar entrance added… And a cable marker sign. Cheers Darius 12
Horsetan Posted November 13 Posted November 13 3 hours ago, Darius43 said: ....And a cable marker sign. Will you be installing any signalling at all?
