Seanw12 Posted November 26, 2013 Posted November 26, 2013 My hornby dcc select wont work right.when the train should stop it keeps chugging track clean wheels are clean help please
0 heirflick Posted November 26, 2013 Posted November 26, 2013 scahalane answered in your IN NEED HELP thread
0 Garfield Posted November 26, 2013 Posted November 26, 2013 scahalane answered in your IN NEED HELP thread That thread seems to have disappeared...
0 heirflick Posted November 26, 2013 Posted November 26, 2013 his answer was to reset the controller as per the manual and reassign numbers to your locos
0 enniscorthyman Posted November 26, 2013 Posted November 26, 2013 Was your loco DCC ready or was it converted to DCC.The reason I ask is if the motor has supression capacitors still attached,this can cause poor response to loco motor.
0 WRENNEIRE Posted November 26, 2013 Posted November 26, 2013 Great hint Eamonn, I did not know that they affected performance (Just as I went to post this comment my spell check had Eamonn underlined, when I right clicked it gave me the option of changing it to Moonbeam! The spell checker must know you, man!)
0 WRENNEIRE Posted November 26, 2013 Posted November 26, 2013 I have not heard of any DCC faults with the 141's Sean, but the Hornby Select has had a few bad reviews, Change the controller?
0 Seanw12 Posted November 26, 2013 Author Posted November 26, 2013 Just got it and I don't really want to
0 Seanw12 Posted November 26, 2013 Author Posted November 26, 2013 Check my vid on youtube about it my channel is irishrail201
0 Riversuir226 Posted November 26, 2013 Posted November 26, 2013 The select is not entirely dcc compatible, I used one for a few years, it was fine while using hornby chips but other chips could misbehave If your using a bachmann 21pin chip the problem may lie there to solve it you could get a normal 8 pin hornby decoder and an adaptor to fit the 21 pin socket on your 141.
0 Riversuir226 Posted November 26, 2013 Posted November 26, 2013 The adaptors are cheap enough, the hornby decoders are not that expensive. To be honest I d change the controller as in the long run you d be better off.
0 Georgeconna Posted November 26, 2013 Posted November 26, 2013 Is the power track your using a orange coloured one?, Hornby have a DDC power track specially for DCC. If it is the Orange coloured Power track socket, then you can take off the cover and remove the Supression Capaictor in that or change it for a DCC power track which is: R8241 Also it could be the Back EMF is set wrong. Had this problem on a few baccy chips recently. Hope that helps but try the power track solution 1st. tks George
0 enniscorthyman Posted November 26, 2013 Posted November 26, 2013 Great hint Eamonn, I did not know that they affected performance(Just as I went to post this comment my spell check had Eamonn underlined, when I right clicked it gave me the option of changing it to Moonbeam! The spell checker must know you, man!) That's Gas alright.I have seen this problem before with the Capacitors,but perhaps it might be only certain types of chassis that this affects,however I always remove them from the likes of the deltic chassis. As regards the 141,the select as far as I know is very basic for DCC,but a good wheel clean could help and have you tryed a different decoder?.
0 burnthebox Posted November 26, 2013 Posted November 26, 2013 Don't actually know if this matters, but I read / heard somewhere that you must connect the black & white wire to the right side,
0 Seanw12 Posted November 26, 2013 Author Posted November 26, 2013 It's orange so how do I take it off
0 Seanw12 Posted November 26, 2013 Author Posted November 26, 2013 I fixed it guys with the help of George thanks George
0 Georgeconna Posted November 26, 2013 Posted November 26, 2013 Happy to help, Good job your threw up the piccy.
0 Seanw12 Posted November 26, 2013 Author Posted November 26, 2013 But the light on the train keep flashing when it's stopped
0 Georgeconna Posted November 26, 2013 Posted November 26, 2013 Heres the pic of the track part with the cover removed. Take out the Blue electronic component and put the track back into the layout and insert the wires. that shuold be the end of the problem for you.
0 Seanw12 Posted November 26, 2013 Author Posted November 26, 2013 Thanks sorry for asking all these questions but only turn to dcc last week and my problem came up so you no thanks
0 burnthebox Posted November 26, 2013 Posted November 26, 2013 Modelling is a learning experience, well done, glad you got it sorted,
0 Seanw12 Posted November 26, 2013 Author Posted November 26, 2013 Modelling is a learning experience, well done, glad you got it sorted, Thx
Seanw12
31 answers to this question
