Everything posted by Georgeconna
Is it a IRM issue decoder for the A class or Generic 21 Pin?
Hi Brendan, Happened to my one too, Changed the CV's on it, worked for a bit and it now has gone back to not working again. TBH given it is 6 Wheel pick ups the Stay alive is not really needed once your track is clean. This was the advise from a FB page: "The CV value for 113 was 0, Strange as I had not done any programming on this at all. Anyway set it to 127 and it works again" No one from IRM chanced to pop onto my initial query to comment either and yes these were IRM supplied Decoders so I wonder is this a fleet issue? Happened to my Deltic too. Hope the abocve helps
Jeekers you lads have some bad luck for sure, I just got some stuff in from SCOGRAIL. Posted through RM , Came in via An Post, No hassle.
Lovely Work, Pray tell where did you source teh Chimney pots?
Claire, The box will have the product code on the end of the box, Google that code and you will see some price information on same as you can see 374-151 went for €19.00 which give a good idea. I you go through a dealer probably expect about 30% of the sell price. The Prodigy for example can be seen on hattons
What part of the country are you in Claire?
Jesus that some slap. good luck!!
Shed Heaven - Looking Back On 25 Years of the Class 66
Georgeconna replied to Warbonnet's topic in British Outline Modelling
Seems to of been welcomed by the UK Modellers from what I am reading. I'd be a tad Miffed if I ponied up for Substandard Wobbly original Hatton's one though. A 2nd Stab to sort the problems out will be welcome for sure. Reminds me of a Bit like the GT3 where I took a Stab on the Crowd funding and got one from the first run with the few niggles with pony truck, Lights etc.. A 2nd run was made and for the Fella's that sat on the fence a model with no issues was obtained. My one with the niggles is now under valued and regulated to the box now mostly. took the gloss off it. I think I will be sitting on the fence in future!- 1 reply
- 1
Remaining Class 92 and Mark 5 Delivery Update
Very nice!! Pity the Panto heads don't sit flat when down but I think a lad on RMWEB had a fix for that if you are bovvered. Well wear. -
Dont Recall ever seeing one of these models built up in the flesh at anyshows I have visited. Would be nice though but expensive.
nice does the Top Light work over the can too? Though tthat was not meant to be included or was not on the decoration samples.
yep that possibly the one dissapointment on the A TBH but as I mention take out the provided one and stick on a baccy job. sorted.
Possibly Needs to be re named to the Price Moan Thread as there are no bargins really thrown up and I would hazard a guess if there were they wont be here any how..
That is a lovely kit to make as welll.
If the couplings don't recentre then the Kaydees the uncoupling function wont work correctly. The coupling are a pain to change in those coaches. Not sure why companies where there designed so you can pull them out quite easily for replacement and then another company comes along with a slightly different solution that jut does not quite get their. piccy with the baccy coupling inserted and now no droop. the droop was going under other stock when being propelled.
I stuck Baccy Coupling into the A Class, Solved the drop and also the hook wobbling about at severe angles.
Would not be too happy looking at that silvering TBH. What I would do it take that off, Gloss the area, Fresh Decal , Re sit it properly, Gloss over again and then matt. Did good few back in the day. Should of done one for myself!
Fraud looking site, selling irish models
Georgeconna replied to WaYSidE's topic in For Sale or Wanted
Better check your Cupboard! -
I don't get it , normally you are giving out about the price that some lads are asking for other bits and bobs and then ok with this one where the price is actually over double the original selling price? Honest though! Still a good price for someone.
Mags for me will get my vote for sure , Exquisite model.
